CLICK HERE--><--CLICK HERE
New Control Line Timer Active by Fiorotti
Started by Rogerio Fiorotti, January 14, 2014, 02:50:10 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Rogerio Fiorotti
Cris.
Are distinct thing, the accelerometer adds and reduces the rpm depending on the acceleration exerted on the model.
The addition rpm with the nose-up does not depend on the model acceleration adds only a small amount  rpm of which can be adjusted.
Rogerio.
Crist Rigotti
Quote from: Rogerio Fiorotti on February 01, 2016, 04:37:21 AM
Cris.
Rogerio.
Thank you.
Rogerio Fiorotti
Dear
I'm always working to offer a product that meets all and made some changes in the firmware to improve the performance of the Timer, nothing big just a few adjustments.
The Timer provided to his friend John Tate basically is the same and their operation is correct, but the manual he posted only serves to release the timer he has.
The new version is in www.metaenergia.com.br site - in the files folder.
With the understanding of all I will always be available for any question.
Rogerio Fiorotti
Steve Hines
Is there a way to set rpm for lap times.
Rogerio Fiorotti
I measure the lap time and change the rpm for the desired time, if you have an rpm set for your setup will have to use a tachometer to adjust.
Rogerio.
Rogerio Fiorotti
Rogerio Fiorotti
New website up and running
www.cltimer.com
Rogerio Fiorotti
Rogerio Fiorotti
#32
C / L Timer with new firmware v4.X available in cltimer.com
News.
Using the programming box JETI Model - JetiBox
Wide RPM adjustment and more accurate with 400 steps and (1.200 at 2,000ms PWM)
Compatible with ESC's Jeti Spin Pro and Castle Creation in mode Governor Hi
Wire super flexible accelerometer.
Rogerio Fiorotti
Fred Underwood
Rogerio,
The links in this thread and your email are down. Perhaps a temporary site update?  Just letting you know.
Fred
Fred
352575
PerttiMe
Rogerio Fiorotti
Sorry, the provider was in maintenance.
Rogerio Fiorotti
Joe Yau
TDM
Mr Fiorotti is there a chance to have the timer without the plugin pins for accelerometer programming and servo removed. I was thinking to have them placed remotely. The idea is to solder wires instead of the pins and have those in other places.
TDM
What is a good way fasten this in the plane?
Rogerio Fiorotti
TDM
My first go to idea would be to put a rectangular slot in a piece of plywood, where the size of the slot would be the width and height of the PCB board, slide the timer in the slot and glue the plywood to the fuselage skin.
It would be nice to have some mounting holes in the PCB. Another idea is hot glue put the timer in place then pack some hot glue to fill in the gap (hopefully i do not glue the switch in the process) and call it a day.
That being said I was asking you as a developer and user to what are your ideas and what are your recommendations.
Thanks Traian
TDM
Rogerio
If the accelerometer is disconnected can you still program the timer?
I understand that at the time of programming there is no fedback from the accelerometer for last step (check for level). But that is a one time need to do thing.
I have received the timer thanks.
Rogerio Fiorotti
Quote from: TDM on March 13, 2018, 08:40:48 AM
Rogerio
Hi,
Yes you can program without the accelerometer but not recommended because you need it for leveling.
usually fixed the timer board with double sided adhesive maybe help.
Rogerio
