  • June 18, 2025, 03:28:51 PM
Author Topic: TUT-HR Available NOW 2021  (Read 43374 times)
Offline Tom rammel
« on: September 07, 2021, 12:41:40 PM »
Tim Wescott is the designer of the TUT-HR and Howard Rush provided the specification.
Tim Wescott is allowing me (Tom Rammel Senior Electronic Engineer) to build the TUT-HR and make it available to those that want to purchase them at a cost of $ 80.  These initial builds will only be shipped to the continental US and will have a long lead time due to the chip shortage.
YouTube link:
If you would like to purchase a TUT-HR send a check to:
Tom Rammel
2502 Oliver Ave SW
Cokato, MN 55321
Email     rammel@centurylink.net
« Last Edit: January 30, 2022, 12:22:56 AM by Tom rammel »
Offline John Paris
TUT-HR Available NOW 2021-installation orientation
« Reply #1 on: November 30, 2021, 08:10:30 AM »
Everyone,
Since this board has sensors on it, orientation will have some importance.  Howard graciously shared a picture of his world beater with a TUT-HR installed.  It is probably best to orient your TUT-HR in a similar manner.  Looks like the board needs to be vertical with the pins facing forward and the electric components facing the pilot (inboard) for people flying the standard CCW rotation.
John Paris
269
Re: TUT-HR Available NOW 2021-installation orientation
« Reply #2 on: December 01, 2021, 04:01:49 PM »
Everyone,
Actually, this has been anticipated.  You can tell the TUT what orientation it's in, and it'll adjust to work correctly.  There's 24 possible positions (not my fault!  I didn't give this universe three spatial dimensions!); you can set them in the "sensor setup" menu -- although the default is the orientation in Howard's plane.
I owe y'all some detail in the instruction manual on this -- but it's there.
Offline John Paris
« Reply #3 on: March 30, 2024, 08:24:41 AM »
Tim,
I finally got back to the TUT since I put together something for it to ride in.  The sensor orientation configuration was not too difficult to figure out if I have my reference frames right.  I used airplane L(eft), R(ight), F(ront), B(ac)k, up and dn for direction and face as the side of the board with the components.  The initial (as shipped) configuration I believe was J1=F, face=L which should align with Howard's TUT orientation.
« Last Edit: March 30, 2024, 11:44:45 AM by John Paris »
John Paris
269
