  • August 01, 2025, 07:09:59 AM
Author Topic: Pre or new post disapears after warnings  (Read 102812 times)
Offline eric david conley
« on: April 12, 2016, 12:03:57 PM »
  #1   I have had trouble while replying to a previous post. I write my reply, I go to post and there is a message that says that someone has posted and do I want to look at it before I post my reply? "NO", I don't want to read it because I'm replying to the post that I had read already not the one that came in while I was typing my reply. 9 time out of 10 my reply then gets lost or disappears and I'm never able to post it?
  #2    Then there is the message that says my reply is to big to post (usually involves picture size) and below it is "BACK" so I hit back thinking I can go back and do something to my post so I can post it again and then find that my post is gone, disappeared, blank, and I look for it and can never find it?
     With #1, I would like to never see that warning and just have my reply posted. I'm replying to a particular post, not one that I have never seen.
     With #2, I usually check my pictures to make sure I don't go over and my posts are OK but ever once in a while I screw up. I'm sure there must be some way to go back and remove material so the size is OK but I don't know what it is other than hit "BACK" and that sure didn't work for me. I'm a little windy on my reply's and when there wiped out many time I just through up my arms and don't reply.
     Maybe I'll just have to live with #2 but I would hope that maybe you could just get rid of the message on #1 and let the reply's go through. Why would I not want my work of art not go through (jest).  Eric
Eric
Re: Pre or new post disapears after warnings
« Reply #1 on: April 12, 2016, 09:58:10 PM »
Until whatever whatever solutions you may find, try this:
I always use Windows Notepad to save a current post as I go. Mine too, are sometimes lengthy, so I open Notepad(Icon on my taskbar), and when I feel the need, I right click in the forum text editor, select all and copy, paste it in notepad & save as I go. It's saved me from screaming many times. Adding Notepad to the taskbar is the first thing I do when customizing my computer.
Rusty
