  • July 30, 2025, 11:21:46 AM
Author Topic: XF-91 Wing  (Read 16215 times)
Offline George Fruhling
XF-91 Wing
« on: May 16, 2023, 09:38:23 PM »
The Republic XF-91 Had swept wings that flared out with the cord widest at the tip. I wonder how that would work with a C/L stunt plane with straight wing.
Re: XF-91 Wing
« Reply #1 on: May 16, 2023, 11:08:53 PM »
You might not like it in gusty or turbulent conditions
Re: XF-91 Wing
« Reply #2 on: May 16, 2023, 11:31:48 PM »
Our REJECT peacemaker , The Aeromudler one , had too quick cut rejects . SOMETIMES . Dont think we were sucked in more than once ! .
However , with a no nitrate Yin Yan  , if you whipped it  hugely for five laps , clibing in the last two , then dived -
You Might get a loop. If you kept whipping !
If you didnt you didnt .
The Field was three football fields , with 80 foot 45 degree banks , between levels . ( all remodelled now  >:( )
A outside loop from level , it'd PULL Somewhat . Unexpectedly . On a good day you might get it back up to ' ground level ' again .
At least once or twice I DID .
SO , Dont use a Yin Yan ! other than that , im not sure Its entirely Relevant ,  HOWEVER . Some current dwelling on WINGS might help .
The old YARDSTICK undercarrage mounts . A PINE Stick across , to ' catch the loads ' .
You might figure the Center of Area , on a side . And run a fancy Caron Backed or somesuch , cross spar . Anchored securely in the fuselage .
This'd sort of ' get ' the thing evenerish stressed - and you can put the wings on the other way round , if it dosnt work backward !  S?P  LL~
ACTUALLY , This could look darned good .
Hunt Thunderchiefish or that blokes MURAT ish , if you went sorta scale . STYLE .
https://outerzone.co.uk/plan_details.asp?ID=6183
« Last Edit: May 17, 2023, 11:25:07 PM by Air Ministry . »
Re: XF-91 Wing
« Reply #3 on: May 17, 2023, 03:44:05 PM »
You lost me there, Air Ministry.  Anyway, I was thinking of a straight, not swept wing design.  You a big Devo fan. "Whip it, whip it good!"   ;D
Re: XF-91 Wing
« Reply #4 on: May 17, 2023, 11:38:43 PM »
Yin Yans and solid foam wing ' flite steaks ' ( peacemaker ) have a performance that may not be described as invigorateing .
The FOAM WINGS they cut TOO QUICK sagged ( the cutting wire ) in the middle . So gave the effect you mentioned . Amougst others .  n~
IF you had a say 1 1/2 x 3/8 STRONG ' stick , going across say 30 inches or three feet , with slip on wings . Ply Ribs at root and spar end - or a box spar sliding over the ' stick ' ,
You could have slide on detachable wings , and then , if the thick tips  roll it 90 degrees when you hit your slipstream , offsett . You can put em on normal , later .
After youve explored all the avenues of performance . IGNORE the Foam Peacemaker , Wasnt a ' Comp. ship . We built better before we met that lot !
Youll never know till you try it . A X in -planform - winged thing , closed across'd have very wide chord way out . !
Was a British ' Martin Baker maybe , Design sketch of something akin to youre idea . NOT THIS .
maybe in here or there . w t h .  >:(
coulda beena Saunders Roe rocket plane - Think it was never built - theyed draw myrid concepts for evaluation . AS Control Lines TEATHERED , you can try stuff inapropriate to free flight !
Wake in the middle should be less than conventional ships , maybe giving it sharp precise controls .  ;D
Re: XF-91 Wing
« Reply #5 on: May 20, 2023, 06:48:06 PM »
It might work.  But it would be ugly as hell.
Re: XF-91 Wing
« Reply #6 on: May 20, 2023, 08:33:16 PM »
Really, if that had worked we would have more develop of the design. D>K
Re: XF-91 Wing
« Reply #7 on: May 23, 2023, 10:05:48 PM »
But it Wasnt Control Line ! .  VD~  S?P
With lucky box slots and removable wings , he could try them BOTH WAYS , for a DIRECT Comparison .
Re: XF-91 Wing
« Reply #8 on: May 24, 2023, 12:21:55 AM »
In a video about the XF-91, it was said the plane performed fairly well. The design was supposed to prevent or minimize  wingtip stalls.  Now if that's an issue with C/L, not sure. Seen video of RC planes crashing from tip stall.
