CLICK HERE--><--CLICK HERE
Will sealing flap hingelines affect sensitivy?
Started by Paul Van Dort, April 16, 2026, 01:06:30 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Paul Van Dort
I am in the trimming process of my new design. Saito 72 powered and a bit heavy. It flies already decently, but It can do with more lift in the 120 degree corners coming out of the triangles and hourglass. On the other hand I don't want to reduce the sensitivy of the model by increasing the flap throw wrt the elevator. I have not sealed the flap hingelines. Would sealing the hingelines increase lift capability without jeopardising sensitivity?
Ken Culbertson
Quote from: Paul Van Dort on April 16, 2026, 01:06:30 AMI am in the trimming process of my new design. Saito 72 powered and a bit heavy. It flies already decently, but It can do with more lift in the 120 degree corners coming out of the triangles and hourglass. On the other hand I don't want to reduce the sensitivy of the model by increasing the flap throw wrt the elevator. I have not sealed the flap hingelines. Would sealing the hingelines increase lift capability without jeopardising sensitivity?
Assuming you have the typical hinge line, try this.  Seal the bottom of the inboard wing gently with some strong tape so that it will be easy to remove.  Now carefully fly the plane and see if you get roll in the corners.   Most planes that I have flown will benefit most from sealing relative to hunting.  Lift is another issue and each airfoil and flap setup will be different.  Some will, some won't.  I have no clue why, probably has to do with the airflow separation point.  Some swear by it, but I have never been happy with 1:1 for corners.  I tried logarithmic but the improvement was not enough to justify the weight and complexity.  If moving the CG is off the table then My solution is to increase elevator travel.  Perhaps as much as a 3:4.  I don't think sealing will solve your issue BUT do it anyway.
Brett Buck
Quote from: Paul Van Dort on April 16, 2026, 01:06:30 AMI have not sealed the flap hingelines.
   Why oh why would you skip that?  And, are the *elevator* hinge lines sealed already?
   Generally, sealing the hinge lines makes the surface more effective. Since the tail has a 22-24" lever arm and the wing has a 1/2" lever arm, it usually *increases* the sensitivity. How much depends on the hinge line geometry.
Paul Van Dort
Quote from: Brett Buck on April 16, 2026, 06:58:42 AMWhy oh why would you skip that?  And, are the *elevator* hinge lines sealed already?
I think I was lazy :-) . All my previous models have the flap hingelines sealed. But I never did it on the elevators (yet)
Brett Buck
Quote from: Paul Van Dort on April 16, 2026, 07:18:33 AMI think I was lazy :-) . All my previous models have the flap hingelines sealed. But I never did it on the elevators (yet)
   OK, seal both hinge lines, then you can start trimming it and diagnosing any issues - basically, you never finished the airplane.
   Anticipating the next step - what sort of prop and engine setup are you using? Particularly, how much pitch? Because running at low revs with lots of pitch probably makes the engine happier, but does not give you as much speed stability in the corners, which increases the tendency to stall since the airplane slows down excessively.
   And, as the other threads - keep a good eye on stuff getting stress cracks or damage from the vibration, this can be a serious/fatal issue on these giant 4-strokes.
Paul Van Dort
#5
Quote from: Brett Buck on April 16, 2026, 07:31:52 AMOK, seal both hinge lines, then you can start trimming it and diagnosing any issues - basically, you never finished the airplane.
To be honest, I was at first very focused on getting the Saito 72 to run reliable. My first experience with 4 strokes. A different game. Finally I am able to manually start the beast consistently, the tank works perfectly: a soldered tin tank with clunk with a tunable uniflow setup (tank can be setup from standard until fully uniflow. So far the best setup is uniflow until the tank is about 70% empty) . The original carb is adapted for stunt and I am able to control the power by choking the intake with calibrated inserts. So now I can focus on the flying. For now the prop is an APC 14-5 narrow blade. About 5.2 sec laptime on max length cables. Tomorrow testing with sealed hingelines. I might consider adding turbulator strips later on. One step a the time.  Nose construction is like the original Skywriter of Arden, not as shown in some simpler Skywriter drawings.
Brett Buck
Quote from: Paul Van Dort on April 16, 2026, 02:04:52 PMTo be honest, I was at first very focused on getting the Saito 72 to run reliable. My first experience with 4 strokes. A different game. Finally I am able to manually start the beast consistently, the tank works perfectly: a soldered tin tank with clunk with a tunable uniflow setup (tank can be setup from standard until fully uniflow. So far the best setup is uniflow until the tank is about 70% empty) . The original carb is adapted for stunt and I am able to control the power by choking the intake with calibrated inserts. So now I can focus on the flying. For now the prop is an APC 14-5 narrow blade. About 5.2 sec laptime on max length cables. Tomorrow testing with sealed hingelines. I might consider adding turbulator strips later on. One step a the time.  Nose construction is like the original Skywriter of Arden, not as shown in some simpler Skywriter drawings.
  All sounds like a good starting point, good luck!
Paul Van Dort
#7
Testing is ongoing. The sealed flaps give a general feeling of extra control and predictability.  Good feeling all around (pun intended). 2 points for improvement: 1. I would like a bit more sensitivity (solution path: wooden prop and/or c.g. shift to the back and or less overhang at the handle) and 2. The outside corners are showing some yaw/ roll issue. I will install an inboard cam pointing to the center to assess the exact movement of the model. The Rabe rudder obviously needs some more trimmming.
Quote from: Paul Van Dort on April 21, 2026, 06:16:26 AMTesting is ongoing. The sealed flaps give a general feeling of extra control and predictability.  Good feeling all around (pun intended). 2 points for improvement: 1. I would like a bit more sensitivity (solution path: wooden prop and/or c.g. shift to the back and or less overhang at the handle) and 2. The outside corners are showing some yaw/ roll issue. I will install an inboard cam pointing to the center to assess the exact movement of the model. The Rabe rudder obviously needs some more trimmming.
   By wanting more sensitivity, do you mean slightly faster controls? a couple of things to try. One is simply moving the balance point back, by adding some tail weight, maybe 1/2 ounce at a time. Can you adjust the elevator pushrod closer to the elevator hinge? Just a little bit and then test fly. Also, what is your line spacing at the handle? Is it adjustable, where you could space them out about 1/4" apart? Again, little bits at a time. Make one change at a time and test fly.
Bad Spelling Bad Spelling x 1 View List
Ken Culbertson
Quote from: Paul Van Dort on April 21, 2026, 06:16:26 AMThe sealed flaps give a general feeling of extra control and predictability.  Good feeling all around
This is exactly what I encountered when I first started sealing. It just seemed easier to control. I have yet to determine if the plane flew better or if I just flew the plane better, does it really matter?  It makes the plane much easier to trim, however, on my planes it has not had any effect on the turning radius with one exception, a classic Nobler where I was able to seal the elevator.
Careful with the Rabe rudder, they have an temper.  Be careful as you trim it to observe what it is doing to the rest of your pattern. It is very easy to have too much throw and to avoid opposite rudder on the insides.  Start with very little and work up till you see a change.  A cam rudder is better but you have to build that into the plane's design and nearly impossible to add on or put on a profile.  That way you can control offset either direction.  There are places where the insides can use a bit of rudder if you don't have an active timer, or maybe even if you do.
Good luck with the testing - Ken
Paul Van Dort
Quote from: Ken Culbertson on April 21, 2026, 07:34:42 AMThis is exactly what I encountered when I first started sealing. It just seemed easier to control. I have yet to determine if the plane flew better or if I just flew the plane better, does it really matter?  It makes the plane much easier to trim, however, on my planes it has not had any effect on the turning radius with one exception, a classic Nobler where I was able to seal the elevator.
I use a completely different principle for the rabe rudder. The rudder is pulled against a stop by a small elastic band during neutral and up elevator. On down elevator, a wire is pulling the rudder.  Adjustability is easy for threshold (When the rudder starts moving: length of the wire) and ratio ( Length of the Rabe control horns on the rudder and elevator) . Adjusting basic rudder offset is done by setting the rudder stop. On advise of Igor in this forum, I am planning on having more rudder offset and less leadout bias wrt the c.g.
Ken Culbertson
Quote from: Paul Van Dort on April 21, 2026, 07:42:02 AMI use a completely different principle for the rabe rudder.
Interesting adaptation.  Do you maybe have a pix?  Dallas is Rabe country and most of the group that I fly with knew him.  There has been a lot of interest recently in his rudder ideas.   Yours may offer an easier and better adaptation.  Especially as an add on.
Cheers - Ken
Brett Buck
#12
      OK, *did you seal the elevators*, too? If not, seal the elevators, start over again. If you did, the usual effects have to be sorted through :
if it is merely not sensitive enough, increase the handle spacing, and nothing else.
If it is turning "awkwardly" in the sense that it appears to sweep into corners, increase the elevator throw
if it is turning with excessive control loads, then move the CG aft -
   It is pretty difficult sometimes to tell the difference between these conditions, and it takes a lot of experience to decide. If you are flying with people with a lot of experience with "neutral"/"clean" trimming techniques (as opposed to old-school ideas (like Rabe rudders and more line tension is better), they can probably shorten your efforts. But always keep track of your changes, and entirely by yourself, you can try the variations *as long as you can for sure put it back the way it was). What you are shooting for is for the line tension to be as steady as possible throughout the flight, that is, you don't get wild variations in the corners (that also causes the control forces to change). For instance the usual Rabe rudder maladjustment causes the line tension to jump up in corners, which also causes the corner to tighten up - which you then have to fight at the handle.
Unfortunately the engine is a complicating factor, too, and it is doubly difficult with a 4-stroke since tiny changes in the settings are hardly detectable by sound but can have massive effects on the power,
      If you have a Rabe Rudder, I very strongly recommend you disable it, fix it *dead straight ahead* so that there are no offsets trying to yaw it either direction. Then trim the airplane for minimal yaw reaction in the corners. Then and only then, add just enough rudder motion to null out the residual. Essentially everyone who has ever used it has vastly too much travel and has the effect of greatly increasing the line tension in corners, because it "pulls my arm off". You have a Saito 72, the last thing you are going to run out of is line tension, so jacking it up or having it vary in flight is not to your benefit.
    I very strongly suggest you *do not try to trim with a significant static yaw angle*. Essentially every attempt at this I see turns out the same way - badly. The difference is while a someone with immense experience can tell when it starts hurting you, most people who try it do it blindly and can't tell when it is hurting them. Windy Urtnowski was a Top 5 NATs competitor for decades, and he couldn't tell at all. If he can't manage it, I don't think those will lesser experience have a chance.
   Do as you will, of course, but this is a very very familiar situation.
p.s. I note that "too much overhang" is going to cause higher control loads (turn VS control torque"stick force")  not reduced sensitivity (turn rate VS deflection angle). I think you should usually use the smallest offset you can manage without running into practical consideration (line carriers hitting your fingers, etc) to reduce the conflict with the other factors and get a more honest evaluation of the CG and/or elevator WRT flap.
Paul Van Dort
Thanks all for the great feedback.
Sealing the elevators is still on the to do list of this week. I first wanted to feel the effect of the sealed flap line on its own.
For me "sensitivity" is a combination of control load and "turn rate VS deflection angle". Clearly 2 different things, but they interact for me. I think the 3th effect, hinge torque, is probably much less of a force to deal with than the "overhang" torque due to line tension. Especially with my 5 inch bellcranks. My next stunter will have an "unstable" bellcrank to reduce the overhang torque even more. A little overhang torque helps in finding neutral more easily, but in excessive wind I don't want it to be too dominant. I have several identical handles but with different overhang to cope with the wind conditions.
I try to trim for zero yaw. I used to achieve this with zero rudder and correct trimmed leadout adjustment. I will definitely try the suggestion of Igor to use more rudder and less leadout offset to achieve the same. All is reversible, so why not. The onboard camera gives a clear view on the yaw/ roll movement of the model with respect to the pilot. Much better than what can be observed from the center or from outside the circle. The cam is ready for the next test flights.
For me the Saito 72 is definitely an improvement compared to the ST51. Very steady and reliable. 5.3 seconds laptime. Good line tension all around .
I will disconnect the Rabe rudder as a start and dial in more Rabe action (Threshold/ Ratio) when required. My fuselage side area is less yaw stable than most so the Rabe rudder effect can come in handy.
I think in Flanders I am the most experienced F2B pilot, so I will do my best to do it properly.:-) Being an engineer I try to approach stunt in a rational way. I want to understand cause/ effects and act accordingly. I am convinced that several different approaches can work for different reasons. That is the beauty of our sport. E.g. The Avanti of Baron appeared very difficult to fly according to Ted, but Baron himself was happy with the setup and managed to place high. I have heard the same about the Berringers models. I think that is wonderful. Testing continues. Reporting as well.
Paul Van Dort
My Rabe rudder . The rudder hinges at the right hand side and cannot pass neutral. Putting shims in the gap is the way to adjust the neutral setting.
I still need to "correct" the lousy paint job. :-)
Ken Culbertson
I see how it works.  Very ingenious.  I hope you don't suggest needing that much movement.  Just for reference my cam adds 1/16" on insides and 1/8" on outsides.  If the yaw is visible to an observer, it is probably too much.
Brett Buck
Quote from: Paul Van Dort on April 22, 2026, 12:21:44 AMMy Rabe rudder . The rudder hinges at the right hand side and cannot pass neutral. Putting shims in the gap is the way to adjust the neutral setting.
   I think this illustrates the issue very neatly. Gyroscopic precession, which is supposedly "corrected" by the Rabe rudder, is *symmetrical*, that is, it would require right rudder on outsides, and left rudder on insides. If all it was doing was correcting for precession,  it would require the same deflection right and left.  Almost all of them end up with a huge neutral offset toward "right" rudder and lots of differential.
   If you have lots of neutral offset, then it is easy to explain why you also need differential - because if you have a lot of neutral offset, you are counting on the lines "fighting" the tendency to turn to the right. As the line tension changes due to maneuvering, how big an angle you need to try to limit the motion is definitely not symmetrical - nose-out yaw adds to the tension which reduces the required "crab angle" required to overcome the torque you are creating with the rudder, nose-in yaw reduces the line tension and requires larger "crab angles"  to correct the same torque. So it takes much more right rudder to maintain the same crab on outsides than it does to maintain the same crab on insides.
   The problem with this arrangement is that you *can't fly through corners cleanly* if you are crabbed to the right all the time, or, at the very least, not without some other very unlikely combination of other torques being applied to keep it the same crab angle through a corner. Effectively, you are no longer attempting to merely pitch the airplane around the corner, you are trying to rotate it around some vector skewed to the principle axes which requires all sorts of torque applied by something.
    It is my considered opinion that you cannot have adjustments "fighting" each other like this, and particularly not the lines fighting the rudder offset. There are plenty of other forces that the lines have to fight (like keeping the roll angle near zereo as you shift the direction of the "orbit"/circling angular momentum), but you need to minimize this to this to the extent possible - the lines are not rigid poles, the are heavy and floppy compliant springs.
    What always happens in practice, aside from rare cases of dumb luck, is that it *doesn't* rotate around this skewed axis, what it does it wobble through the corners like a drunken sailor. Or, in some very famous example cases with Rabe rudder afficionados, the wingover looks like a salmon trying to jump up a waterfall - flop-flop-flop-flop.
    I did some back-of-envelope calculations, and some testing, and I figured that the amount of rudder torque I needed to neutralize the 170 in-lb has requires something like 1/8" or so of rudder travel, and it would be symmetrical about neutral. Some of them might require much more travel if they are less effective lifting surfaces, but it would always be symmetrical.
    If your Rabe rudder is moving a lot more than that, or only moves one way, it certainly is not compensating for precession. In  nearly every case I have seen, for 50ish years, it is doing something bad that prevents the airplane from flying cleanly through corners.
Old Old x 1 View List
Paul Van Dort
Quote from: Ken Culbertson on April 22, 2026, 11:06:58 AMI see how it works.  Very ingenious.  I hope you don't suggest needing that much movement.  Just for reference my cam adds 1/16" on insides and 1/8" on outsides.  If the yaw is visible to an observer, it is probably too much.
I am still in the process of adjusting. A lot depends on the size of the rudder. The rudder on the Seafury of Al Rabe was huge and his article contains the rudder throw he implemented. The rudder on dragqueen II is tiny in comparison. In any case I will use the rudder to solve issues, not to create issues. I will re-assess the writings of the specialists on the subject.
M Spencer
On your rudder,
How Much engine offset are you running on the saito 72 ! ? , please .
NOW , theres rudders & theres rudders . Now Thats a Rudder ( now we see the picture ) .
to digess , Frank Battams Bearcat , Saito , NOT running interconected rudder ,
" How does it go slamming the corners " . ? ' I dont fly like that ' etc . to cut it short .
Rudders - Kieths camplate set up - HE runs a little out on inners , going in , then out more on outsides ( try SEARCH )
A plywood horn on a few things, knock offable in car ( sometimes ) reglued differant ( some times ) I concur . With Kieth .
you can , as a rough guide , use T E offset - as opposed to DEGREES ! . about neutral - but thers ' P ' & Gyro . neutral or a notch out .
http://www.machineconcepts.co.uk/aeromodelling/rabe_rudder/rabe_rudder.html this ones fairly clear .
WHEREAS my set upspurloined from viniees Sttrega etc , ( recomends on 12 inch & over props. In its POSITIONING . as in let into elevator underside LE , at full down , 45 degrees , its against the vertical elevator face .
the pull rod must be under the root fairing . Inboard of the elevator inner edge. If only just . moreor less straight back to rudder aft of elevators . about 1 cm out and 3.5 ( m.m. ) aft of rudder hinge line . outboard of fuse.
Theres a thing . THATS how THEY doit . you could of course reinvent the wheel . ( how about some square ones . And then there mousetraps . they tell me .
Ive found when ive lost a little initial ( out ) rudder on insides , iots ' looser ; Particularly on low wing diheadraled types . Which show up FLAWS more .
a 1/4 sheet elevator with tube for light wire , let in  , where the 45 degree 'V' front  , hits the underside . ( Copied after neumerous observations )
so pivot point of wire is aft of hinge pin , and down . a bit less . ( something like 50 degrees aft off verticle from elevator hinge pin line , 1/4 inch .
THIS with a standardish horn with three holes , will get the reqired movement ' curve . - a bit of out  initially on UP , More Out withmore down . initial
0 or 1/8 out at rudder T E . USING not a lot of movement .
NOW I dont know if Al ' slams ' ( slammed ) the Sq Corners ! ? . Hitting Hard Full Control , at the ' turning points ' But THIS is where you use  rudder to control gyroscopic yaw ,
" For every action theres . . . , etc .
A counter on the initial full up , or down , gyroscopic instant yaw reaction , to the instantaneous full handle deflection . IF you can do it . @!S?P ( Bob Hunts ping pong training ! )
Brett Buck
Quote from: M Spencer on April 23, 2026, 10:08:20 PMNOW I dont know if Al ' slams ' ( slammed ) the Sq Corners ! ? . Hitting Hard Full Control , at the ' turning points ' But THIS is where you use  rudder to control gyroscopic yaw ,
  Except that it doesn't do that, Al's included, per the description above. Most are kicked far over to the right and asymmetrical, if it was correcting for precession alone, it would move symmetrically, have no null offset, and move only as little bit.
   Al never "slammed" a corner and many/most  of his airplanes were not capable of anything like a currently competitive corner. It's not exactly his fault, you *can't* with 70's-style power. Al was always stymied by lack of power of the various engine available and many of his engines were highly modified to get more power - but nothing like the lowliest piped systems or electric.
Paul Van Dort
#20
Quote from: M Spencer on April 23, 2026, 10:08:20 PMOn your rudder,
No offset so far. I have been playing with static rudder offset, ratio(throw) and treshold of the rudder. I can tell that too much left rudder on down is creating roll like you would expect from too much tip weigth. Makes sence as the rudder is on the top of the fuse. So the fun of trimming continues. :-)
Btw Mr Spencer, I don't always understand what you mean in your writings, but I appreciate your reaction.
Brett Buck
Quote from: Paul Van Dort on April 26, 2026, 02:39:52 AMNo offset so far. I have been playing with static offset, ratio(throw) and treshold of the rudder. I can tell that too much left rudder on down is creating roll like you would expect from too much tip weigth. Makes sence as the rudder is on the top of the fuse.
   That is the "short-term" effect.  It will generally affect the "tweak"- giving an indication of a slight warp, which you want to take out with a flapo tweak to get the wings level both ways.
    But in the slightly longer term, giving it left rudder also results in a nose-left sideslip - which will roll it to the left. In that case, you would think you needed *more* tipweight. This is the inverse effect of "Twister Disease", with similar ill effects.
    The real evil is that you have to pick one effect or the other to try to correct, and you can't correct both at once. So you always have to just live with it rolling one way, then the other, in quick succession. You can minimize your "aileron" effect by centering the rudder on the X axis to make it a sort of cruciform arrangement. This means the aft fuselage has to be pretty deep, or have a ventral fin, etc. You want that even if the rudder is fixed - any sideslip from other sources will also cause the lift on the fin to change, and potentially roll the airplane with the aileron effect.
   This is just another reason to *not* have the rudder moving in flight, it greatly complicates the matter of trimming to accomplish a pretty dubious stated goal - replacing a simple minor problem (precession) with a complicated big problem (heavily coupled roll/yaw motion)
Howard Rush
I proposed using differential elevator for 777 high speed roll control.  Gary Letsinger, who once had the best overhead eights in Seattle, said that was a bad idea, because it would affect the pressure distribution on the vertical stabilizer, causing unwanted yaw.  Wouldn't rudder deflection likewise affect pressure distribution on the horizontal stabilizer?  I don't remember much aileron effect from rudder.  Tim Just would know:
Brett Buck
Quote from: Howard Rush on April 29, 2026, 12:51:30 PMI proposed using differential elevator for 777 high speed roll control.  Gary Letsinger, who once had the best overhead eights in Seattle, said that was a bad idea, because it would affect the pressure distribution on the vertical stabilizer, causing unwanted yaw.  Wouldn't rudder deflection likewise affect pressure distribution on the horizontal stabilizer?  I don't remember much aileron effect from rudder.  Tim Just would know:
   Tim has ailerons to help!
      I learned my lesson on this one long ago - that "3 billboards in formation" fuselage was no accident. When I put a Rabe Rudder on my 1986 airplane, the aileron effect of the rather high-set aft fuse and rudder, it started doing what was suggested above - acting like an aileron - rolling the airplane in the direction you would expect an aileron, the rapidly rolling back as the sideslip rolled it back.  The solution was to add a ventral fin and extend the rudder. Then there was only the side-slip effect and the general defect of having a Rabe Rudder, with ever-more-elaborate external mechanisms to try to get rid of the slop at the *extremely small* travel that was required. This was the first time I used ball links on a stunt airplane, trying to get a reliable +-1/32" rudder movement. Everything else was so sloppy that the slop was larger than the intended movement.
The pressure distribution on the stab is interesting, too - I note that on in-liners, the stab is set so low that all the fin/rudder is above the stab, particularly the shark-style arrangement. So it affects only the flow over the top, not the bottom. Taking my own arrangement (classic stab/elevator position near the top of the fuse), while the fin is a little higher than the aft fuse, it is much closer to centered on the stab. I don't know if that matters very much, but it evolved that way trying to get the rudder to just be a rudder
M Spencer
#24
After 100 hours of Contemplation , the thought occured , a HANDBRAKE TURN emulates the load patterns . IF its ' 90 ' degrees .
However , as we had a austin rover MG montego or two ( barff - But theyre like the Tardis . Twice as big inside as out . Fit FIVE F2B models , and driver , and sundry other . Simultaeneously )Tended to 270 .
Whereas a 63 Mk 1 twodoor Cortina , offered very prcise control . Fitted V4 with 6 & 7 inch rims . Etc . As the weight distributions superior , to a Loutus M1 ,
Mustang , Camaro , VW 911 , etc .  ;D    %^@    S?P
Try 1:30:30 here . and remember to turn on the fuel pump .
ANALOGY -> Yr ' Square Turn ' is comparable to a ' Handbrake - 90 ' turn . Use somebody elses car . In case you put it on the roof .
Maybe its the next year ( 1984 ) theyre trying ' handbrakes ' at the top , as its quicker . But there should be a few in there .
ROLL CENTERS - adheshion - Traction . Brake action & release .
SO , one can pussyfoot around a Square Turn , jiggly pokey turning it , warilly .
Or , like ' many ' things , - HIT the Turn . " SLAM " it , on off on . or is it off ON OFF . Full Deflection from level straight off .
Release off Full - a GOOD plane will do a ' clean exit ' . . . mostly . . . , timing & such . then theres ' Air . ' .  :(
THERFORE : Slanig control get ' Tourque Reaction ' , Where , Your wobbly Rudder , if setwright , holds the A.C. in true trim . No Yaw . Nose same to coicle , no matterwhat .
H^^
Of course . These Notes refer to the Rudder . rather than the title " Sealing Inges " (  available comercially . "  Future Automation - CH - Marine TV Ceiling Hinge " ) :-X
o.k. in a proper ' 90  turn , handbrake , the ' pilot ' is jigling , picking , and prodding . Whereas , the ' Auto rudder ' should pretty much DO all that . For you . In F2B .
( which should be good traing for rally driving . All the locals adopeted the World Champs tecniques for dealing with obstacles , out our way . After theworld cup ralley .
TIMING - Balance - inetia . for a straight ' flight path . the Instant of ' catching it ' on throttle / steering , for warp factor 10 . on gravel . Like the school bus ! .  :o
driver . Milk Tankers . and Cattle trucks . Or avoiding them . Just like flying , in ' a bit of Air ' ..
Scuse ; a few letters feel off . im sure youll cope . Entertaing anyway , Olde Chap .
