  • August 02, 2025, 05:37:09 PM
Author Topic: Fuselage Area  (Read 3239 times)
Fuselage Area
« on: May 21, 2015, 11:16:58 AM »
Is there a general rule for side area of a stunt fuselage? Is it critical at all?
Online Howard Rush
Re: Fuselage Area
« Reply #1 on: May 21, 2015, 03:32:37 PM »
There probably is, but like lots of stunt lore, it's probably based on a bogus assumption.
Offline Chris Wilson
Re: Fuselage Area
« Reply #2 on: May 21, 2015, 07:02:29 PM »
Would it be fair to say that the fuselage area gives the judges (and pilot) a better, more accurate silhouette to follow?
MAAA AUS 73427
Re: Fuselage Area
« Reply #3 on: May 21, 2015, 08:44:56 PM »
I'm about to make my first full fuselage. If I can just make it functional that would be easy. Is the thrust line and the stab always above the wing?
Re: Fuselage Area
« Reply #4 on: May 21, 2015, 09:10:47 PM »
You want it stiff in both torsion and bend.  And you want it light.  That implies either some cross-sectional area, or some carbon fiber tubing.
Re: Fuselage Area
« Reply #5 on: May 21, 2015, 09:50:44 PM »
If you can manage to build a small cross sectional area and still get the necessary stiffness, it seems like it would be less susceptible to being blown around by wind than one with a taller wider fuselage. At least I get that impression from my profiles, like the Ukey, which resembles a primitive TEOSAWKI with a foam wing and a much smaller stab. Its fuse is actually just a 1/2" wide pine(yes pine) board, barely tall enough to cut a hole for the wing to pass through.
Rusty
EDIT: Correction, I don't think the wing actually passes through it, just the joining dowels. That's what makes it so indestructible.
« Last Edit: May 25, 2015, 09:53:46 AM by RknRusty »
Offline Igor Burger
Re: Fuselage Area
« Reply #6 on: May 25, 2015, 06:44:15 AM »
not at all ... until wind or turbullence starts :- )))))
