  • July 13, 2025, 11:44:04 PM
Author Topic: which P-47 ?  (Read 19761 times)
Offline t michael jennings
  • AMA 83322
which P-47 ?
« on: July 27, 2009, 02:27:49 PM »
Gentlemen,
My next aircraft probably be a P-47.
Which is the best flying PA CL P-47 that is a:
     full fuselage design
     sized for a 0.40 cubic inch engine
Thanks for the information.
t michael jennings           :!
knoxville, tn
Offline Matt Colan
Re: which P-47 ?
« Reply #1 on: July 27, 2009, 03:20:42 PM »
I would probably say Charles Parrot's P-47, and that one is classic legal.  My grandfather is finishing a P-47 that he designed back in 1967.  Grandpa's is a razorback and I think Charle's is a bubble canopy.
Hope this helps a little
Edit:  If you are interested in plans for Don Herdman's P-47, send me an email and I'll tell him, and we'll make copies of the plans and send them off to you.
« Last Edit: July 27, 2009, 08:15:41 PM by Matt Colan »
Offline Bill Hummel
Re: which P-47 ?
« Reply #2 on: July 27, 2009, 03:29:33 PM »
I've built three of the Parrott P-47's, all flew very nicely...with a ST 46. The fuse is fairly massive; my experience with using a .40 engine was not good. With the ST 46(or similar) the Parrott P-47 flies much better than it should...One was later fitted with a RoJett 51, and continues to make great patterns!  Don Herdman's looks pretty good, too, for something bigger than a .40.  Great choices of a warbird legend!
ama 72090
Offline Matt Colan
Re: which P-47 ?
« Reply #3 on: July 27, 2009, 05:15:33 PM »
Don is putting an LA 46 in it.  His original drawing, one of the copies you have Bill, show a Fox 40 in it, and I would think it would be a little underpowered.
Re: which P-47 ?
« Reply #4 on: July 27, 2009, 07:22:15 PM »
Gentlemen,
knoxville, tn
  if you want the plans for the Parrot P-47 let me know.  alos Pat Johnstons P47 is probably one of the best flying designs - he can scale the plans down AND laser cut you the parts if necessary
Offline Martin Quartim
    • StuntHobby
Re: which P-47 ?
« Reply #5 on: July 27, 2009, 11:44:17 PM »
Pat's P-47 with a 72 4S has an awesome sound. The wide body makes it look mighty and reverberates a bolder engine sound then a regular model, it adds a lower tone to the engine sound.
mARTIN
Re: which P-47 ?
« Reply #6 on: July 28, 2009, 10:52:42 PM »
I much prefer the Razorback P-47 for looks. Even so, I would contact Pat and get a scaled version of his '47 and modify it. He'll probably suggest 550 sq. inches for a .40/.46LA. Be sure you can adjust your flap/elevator ratio.
 y1 Steve
Re: which P-47 ?
« Reply #7 on: July 29, 2009, 09:15:05 AM »
T michael jennings,  just read your articale in CLW last night and really enjoyed it.  I suggest going with one of Pat's designs.  Unless you go with Billy Werwages P-47 from Model Aviation.  Then learn how to mold balsa and build a lost foam wing.  Have fun,  DOC Holliday
  • AMA 83322
Re: which P-47 ?
« Reply #8 on: July 29, 2009, 04:53:00 PM »
Doc Holliday,
Thanks for the kind words about the CLW article.
Us, old farts, need to help each other every chance we get.
t michael jennings
knoxville, tn
Re: which P-47 ?
« Reply #9 on: October 28, 2009, 11:54:13 PM »
HI t Michael,
I have a Parrott P-47 and have flown it off and on for 12 years.  Started off with the Fox .35 and after a season went to a retimed FP-40.  Have used a McCoy 40RH in it also.  If I extended the LG a touch, I would definitely use a ST .46 in one.  I will build another, one day, a *little* lighter and with a .40-.46 to start with.  it is a very, very good flying Classic era plane, and suits your criteria.  I am not aware of another P-47 in that size.
Pat Johnston can scale plans, up or down, and at last word only charged an extra $20 to do it above the cost of the plans (from the Brotherhood of The Ring website).
Mongo
  • AMA 83322
Re: which P-47 ?
« Reply #10 on: November 10, 2009, 04:38:00 PM »
Mr Hummel,
Mr Little,
Decided to build the Chas Parrott P-47 as the next project.
The above answers lead me to use a OS LA46 power plant.
To guide my building efforts, what are the weights of your P-47's.
t michael jennings
Knoxville, TN
Offline Bill Hummel
Re: which P-47 ?
« Reply #11 on: November 10, 2009, 06:06:11 PM »
The P-47's that I built were 45 to 52 ounces, much depending on the finish. This was with good but not "great" balsa.  Someone laser cut the ribs for me, just can't seem to remember who?...
ama 72090
Re: which P-47 ?
« Reply #12 on: November 11, 2009, 07:11:47 PM »
I would ask these guys.  They have P-47 experience.
  • AMA 83322
Re: which P-47 ?
« Reply #13 on: November 11, 2009, 07:34:09 PM »
Mr Rush,
Who are these guys?
T michael jennings
Knoxville, TN
Offline Bruce Perry
Re: which P-47 ?
« Reply #14 on: November 11, 2009, 08:49:54 PM »
They are the famed offspring of Butch Cassidy when he and the Sundance Kid went to Brazil....
Well that would be a good story, they are the Brazilian "team" that shows up at the Nats or brodaks.  Bene Rodriguez is a ring leader and Mr Thomas Case is the financial backer.  Either would be great to discuss the merits of the P47 with.  Two very fine gentlemen that may or may not be related to Cassidy or Sundance.
But does make you wonder....
B
Re: which P-47 ?
« Reply #15 on: November 11, 2009, 09:18:38 PM »
That picture was at the 2007 Nats.  Here is Windy Urtnowski preparing to fly one in Sao Paulo.
Offline Balsa Butcher
  • High Desert Flier
Re: which P-47 ?
« Reply #16 on: November 11, 2009, 11:14:13 PM »
Don't know if you would be interested but Action Hobbies/Lazar works are advertisers on this forum and offer a partial lazar cut kit of a P-47. It is listed as P-47 from Tom Dixon plans but I'm pretty sure it is the Parrot design. Easy enough to check with them and find out for sure.  8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
Re: which P-47 ?
« Reply #17 on: November 13, 2009, 06:58:16 PM »
These were published in the magazines.
Republic P-47 Thunderbolt     1966 AM Ja-Fb p35   52.00   596.50   .35   Classic Stunt   166   Parrott, Chuck W.
Republic P-47 Thunderbolt   1962 FM Jn-Jl p18   57.00   460.00   .19-.35   Scale   CF152   Del Gatto, Paul E.
Republic P-47 Thunderbolt   1961 AM Sep p18   42.00   331.00   .40-.60   Scale   961   Musciano, Walt A.
Republic P-47 Thunderbolt   2006 MA Jul p33   62.00   706.25   .60-.65   Stunt Scale   989   Werwage, Bill
Republic P-47B Thunderbolt   1954 AT Annl p28   35.00   222.70   .15-.35   Scale       Musciano, Walt A.
Tom Wilk
Re: which P-47 ?
« Reply #18 on: November 22, 2009, 11:27:44 PM »
........except the guy in the front row holding a P-51D. ;D
Offline Shultzie
Re: which P-47 ?
« Reply #19 on: January 02, 2010, 07:12:11 PM »
Nevanuff Jugs!!!
I can't even begin to imagine all these beautiful models gathered together in this photo...
Charles Parrott....Wow! Again...I will neva-eva'  forget the first time that I saw the traced and inked plans that Aubrey Kockman so beautifully rendered into one of the most beautiful plans ever produced in a magazine.
Don Shultz
Re: which P-47 ?
« Reply #20 on: January 03, 2010, 12:36:48 AM »
Hi Donaldo,
I bought that issue just because that P-47 was in it!  LL~  It took me many years before I finally built one, though.  I really like the way it flies with the proper power.  I am pretty sure that if/when I build another one, I will be using an Aero Tiger 36 in it, or possibly even PA 40UL. ;D
Mongo
Offline Shultzie
Re: which P-47 ?
« Reply #21 on: January 03, 2010, 09:43:48 PM »
Hi Donaldo,
Mongo
What a beautiful wing platform and I really O.D'd on that beautifully detailed inked plan.
Don Shultz
Offline John Sunderland
Re: which P-47 ?
« Reply #22 on: January 05, 2010, 03:50:47 PM »
The lightest one with the most power initially! H^^
Offline Matt Colan
Re: which P-47 ?
« Reply #23 on: January 05, 2010, 05:24:57 PM »
Grandpa's P-47, which is classic legal and will be published sooner or later, has about 575sq inches, and weighs about 52 ounces, along with about a 54 inch wingspan.
Re: which P-47 ?
« Reply #24 on: January 06, 2010, 08:25:39 PM »
 Theres a fifties film called " Fighter Squadron " if im correct , with some rather polised ground attack / flying .
 A.N.G.  , Ex WW II  pilots preumably. AND the aeroplanes arnt all grubby .
  • AMA 83322
Re: which P-47 ?
« Reply #25 on: April 08, 2010, 06:02:10 PM »
Gentlemen,
Setting here studying the plans to the Charlie Parrott's P-47.
Have not started any building.
The Center of Gravity (CG) is located above the wing at the spar location.
Is this the correct vertical CG?
It just does not look correct.  Shouldn't the leadouts should be at the intersection of the vertical and horizontal CG.
t michael jennings            ~>
Knoxville, TN
Re: which P-47 ?
« Reply #26 on: April 19, 2010, 06:52:35 AM »
Hi T Michael,
Sorry, I missed this one.  :-[
That is the suggested horizontal CG.  I don't remember any plans from back then showing the vertical CG.  ???
Big Bear
Re: which P-47 ?
« Reply #27 on: April 19, 2010, 04:11:21 PM »
And most of those P-47s in the Brazilian shot are the Pat Johnston design.
Re: which P-47 ?
« Reply #28 on: April 23, 2010, 08:08:45 PM »
That is true, and didn't Pat go down there for a while to help them out?
Big Bear
Re: which P-47 ?
« Reply #29 on: April 24, 2010, 08:33:43 AM »
If I remember reading about the Brazillion Team,  Pat designed the plane and made short kits for them.  I think he also helped with the trimming of them as well as the building.  Pat is one of the greats and maybe he could repeat his experience on here.   H^^
Offline Shultzie
Re: which P-47 ?
« Reply #30 on: April 24, 2010, 09:36:00 AM »
Here are a few photos...from Bob Hunt's collection that I just have to share with you.
Neva nuff Jugs!
Thanks Bob Hunt, these shots of Billy's beauty are priceless.
Don Shultz
Offline Shultzie
Re: which P-47 ?
« Reply #31 on: April 24, 2010, 04:12:45 PM »
Hey Glen...
Check your E mail...(sent  you Higher resolution article shots?)
Don Shultz
  • Gravitywell
Re: which P-47 ?
« Reply #32 on: April 24, 2010, 11:39:38 PM »
Hi Don....got them.  And had a good chuckle at how you titled the email! LOL LL~  You cracked me up! H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline Shultzie
Re: which P-47 ?
« Reply #33 on: April 25, 2010, 09:52:33 AM »
Bye the way....NEVA NUFF GOOD LOOKING JUGS photo that I "borrowed" that expression from was from an E mail from the  Head Hunt Gruntmaster who sent me this shot showing Billy's Body Guards....(I have heard that both Billy and Bob are like ROCK STARS...especially in European countries.
As you can see these "BODY GUARDS"  (Ron  O'Toole and Jim Vornholt) are quite well known in all kinds of circles (Arron Circle Burners?) DV^^
« Last Edit: April 26, 2010, 09:58:06 AM by Shultzie »
Don Shultz
  • AMA 83322
Re: which P-47 ?
« Reply #34 on: January 18, 2011, 08:38:34 PM »
Gentlemen,
The progress is slow.  Too many interuptions and too much life in between.
Attached are two photos of the Chas Parrott P-47 as it goes thru the building cycle.
T Michael Jennings            /DV
Knoxville, TN.
Offline Pat Johnston
Re: which P-47 ?
« Reply #35 on: January 19, 2011, 07:18:12 AM »
Mr. Jennings and all.  This is Pat Johnston checking in.  Yes I did design the Brazilian P-47, and yes it can be dropped down to a nice 40/46 sized package.  I would think something in the 560 inch range would be good.  I can do it in both the bubble canopy or razor back version.  I drew plans for both.
Here is the flying impression as I recall from Thomas Case.  He thought that the plane was difficult to fly in the wind and that a thinner wing would be better.  As a result, Bene made up another wing and Thomas was happy with that.  I flew his plane with my original wing and while the turn was very good, it took a lot of muscle to make the corner.  This identical problem was encountered with my big 60 sized Bearcat.  The very easy, simple fix was to slide the elevator connection point up on the horn about 1/8" and then it felt like the plane had power stearing.  For some reason, this trim adjustment suggestion fell on deaf ears and sure enough, in the wind, the plane was tough to fly.  What can I say?
This P-47C/D wing used an airfoil very similar to an Impact airfoil so has a very good performance potential.
Back to the 40 sized version.  I may just go ahead and design one to have in the inventory.  That should be a fun plane and one which would be an interesting subject for many fans of the P-47.  I'll start with the "D" model with the bubble canopy and do the simple mods for the Razor back so all can have what they want.  Give me a couple two or three weeks.
Pat Johnston
Mad Designer
Skunk Works
Online RandySmith
Re: which P-47 ?
« Reply #36 on: January 19, 2011, 09:47:52 AM »
Pat Johnston
Mad Designer
Skunk Works
Hi
What Pat described above as a trim fix for flying in winds is very common for most all planes, Not just a specific one.  The P-47 Pat  designed is an excellent FLYING  plane and great looking !
Another thing that will help turning in winds is to make sure you do not have too much handle overhang. That makes require a lot of pressure on the handle to turn in higher winds
Re: which P-47 ?
« Reply #37 on: January 20, 2011, 06:29:25 AM »
Thanks for your nice comments on my designs, Randy, and all others.  I just started the new 40/46 sized P-47 design.  I am making the wing area just a little larger since the fuselage will be in the 4.5" wide range through the wing.  This takes a functional bite out of the wing area so it is calculated to be 579 squares which makes it a realtively close equivalent to my prefered size of 560 squares.  So far, so good.  If a comparison to the Werwage P47 is desired, my 60 sized version is relatively close to scale, which gives the fuselage a much rounder look.  This improves the look over practically all other P-47 designs, which to me all look like they were put in a vise and have had an inch or more squished out of them.  My version also has the wing located in the scale location and dihedral installed to raise the wingtips to the vertical CG.  Overall, the appearence is quite scale looking.
BTY, I flew one of the Werwage P-47's in Brazil and it did fly very nicely.  Power on that was a OS70 4-S.
I'll keep you all posted on the design developments as they proceed.
Pat Johnston
  • AMA 83322
Re: which P-47 ?
« Reply #38 on: January 21, 2011, 04:43:36 PM »
Gentlemen,
Starting to pick up pace.  It is also starting to pick up some weight.
Have the Fuselage Pan, Turtle Deck, and the Top Cowl Deck in place and sanded to shape.
(Beat it to fit, painted it to match in accordance with ASME Pressure Vessel Code.)
The pan and decks are two formed pieces of 1/16 balsa.  Over the engine is a solid block.
Not sure if the solid block is needed with today's engines.  Seems like it is heavier that needed.
Any suggestions to lighten the solid block over the engine?
Is a solid block needed with today's engines?
Knoxville, TN.
Re: which P-47 ?
« Reply #39 on: January 22, 2011, 04:44:28 PM »
Unfortunately, the carved, hollowed block technique is very common with a lot of classic planes which wanted to create the illusion of a round plane.  My method is to get the shape of the fusleage projected and use 3/32" skins over the formers.  Stringers are installed in the top ridge and 45 degree quadrants of the formers which supports the formerd sheeting nicely.  No "strarved horse" look and the weight is amazingly light.
Here's the latest update on the new P-47 design:  The wing is drawn with a wing area of 579 squares.  The flaps are a little smaller than usual which will make the Tail Volume Coefficient (TVC) functionally act a little larger than it is.  The TVC is approximately .450, which is very normal for a modern design.  The turning capacity will be way up there.  The airfloil is a little different than the Brazilian version which is the same as my Bearcat/Mustang wing.  This new airfoil is just a tiny bit thinner and uses an actual elliptical front with the back part of the airfoil transitioning from the tangent point of the ellipse in a stright line to the trailing edge.  We have been using this on the High Performance Ringmaster series and the lifting factor on them is amazing.  The tips will have the arifoil thinner for a more efficient ability to buck the wind and turbulance.
The fuselage side and top views are done.  That will allow me to project the formers.  As described above, this will use 3/32" sheeting for the majority of the fuselage.  An interesting little twist is to use a 1/4" slab for the first 14" of the fuselage sides, which splices into the rear 3/32" sides.  The thicker front side sheeting allows rounding so the nose looks quite scale-like.  In fact, the nose is a little over 4 1/2" wide.  How's that for realistic?  Not a nose in the vice with this one.  I'm excited to see how the whole design comes out.  This P-47 will be a fun plane.  The Razor back version is a simple matter of modifying the rear formers to make up the difference.
More drawing Monday and more to follow...
Pat Johnston
Design Studio
Skunk Works
Offline Jim Oliver
Re: which P-47 ?
« Reply #40 on: January 22, 2011, 07:28:33 PM »
Pat,
I have your large Bearcat and Hellcat plans; is there or will there be a large P-47?
Jim
Jim Oliver
AMA 18475
Re: which P-47 ?
« Reply #41 on: January 22, 2011, 11:01:53 PM »
Pat,
Jim
Hi Jim,
Pat already has the "big" P-47.  That's the one he designed for the Brazilians, AFAIK.  Similar size to the Werwage P-47 in wing area, etc..
Big Bear
Offline Jim Oliver
Re: which P-47 ?
« Reply #42 on: January 23, 2011, 06:42:54 AM »
Bill,
You're right, of course.  I was wondering about a lage version of this "more scale, smaller P-47".  I haven't seen the Brazilian P-47; does it have the more round fuse?
Jim
Jim Oliver
AMA 18475
Re: which P-47 ?
« Reply #43 on: January 23, 2011, 12:58:58 PM »
Jim,
Generally, the big P-47 has the same overall shapes as the new, smaller version.  The flaps are more of a standard size and the flap hingline is swept forward to get the wing shape right and the flaps to work that way.  With care, this design can be made to come out in the mid 60 ounce range.  The wing area is in the 687 inch area, pretty well in the classic 60 sized class.  Personally, I am enjoying planes in the 560-625 inch range and keeping the weight down in the mid 50's and lower.  This sort of package is so much easier to fly and delivers a lot of fun, because of that.  Bob Hunt writes of this at times.  Smaller planes are less fatiguing and because of that, a person can fly them more and get good practice in.
Pat Johnston
Skunk Works
Re: which P-47 ?
« Reply #44 on: January 23, 2011, 01:06:24 PM »
Jim,
Pat Johnston
Skunk Works
HI PAt,
I agree 100%!  Although I have no "strength issues" flying a "BIG" plane, it isn't as enjoyable, and the smaller, lighter planes are more enjoying to fly.
The "Special" F-4-F is going to hit in the range you are talking about, and I really think I will enjoy it......... a LOT! ;D
Big Bear
Re: which P-47 ?
« Reply #45 on: January 25, 2011, 07:43:45 AM »
Latest progress on the 46 sized P-47 for Tuesday morning.  The 1/8" formers are all developed.  Since there are 13 of these bad boys, the laser will be the only reasonable way to cut all of these out accurately.  One new trick I developed, is to install little 1/64" slots in the formers which correspond with the top of the side sheeting.  A little scrap of plywood is slid in and the former is attached to the perfect location.  This allows the formers to be indexed for perfect position in relation to the top of the side sheeting.  The rudder and fin will be very light 3/8" stock.  The tail feathers will be 1/2" stock with ribs.  I need to do all the ribs, yet, but the basic plans are drawn.  Of course callouts will go on.  This sort of thing takes some time.  Drawing is fast and easy.  Detailed callouts take time.  This plane will really look good.
Pat
Offline Jim Oliver
Re: which P-47 ?
« Reply #46 on: January 25, 2011, 08:12:25 AM »
OK, Pat----you got me!  When the plans are ready, I want a set; better yet, a kit.
BTW, the profile P51 I built from your plans really flys well.
Jim
Jim Oliver
AMA 18475
Re: which P-47 ?
« Reply #47 on: January 25, 2011, 12:14:56 PM »
Jim,
Thanks for the report on the P-51 Profile.  I suspected that the Mustang would be a great flyer, as my larger one is amazing.
I E-mailed you a PDF file of the P-47.  Almost done, but a few details to finish.  I'll get back to work on it when I finish woofing my sammich.
Pat
Re: which P-47 ?
« Reply #48 on: January 25, 2011, 12:52:14 PM »
Jim,
Pat
Shame on you, Pat...... shame, shame, shame!!!!
LL~ LL~ LL~
You keep cranking out more and more designs I would love to build, but you don't send along anymore "years" to add to my lifetime so that I can! ;D
Offline Jim Oliver
Re: which P-47 ?
« Reply #49 on: January 26, 2011, 07:48:24 AM »
Pat,
Thanks for the pdf.  Looks very good......
How was your PB&J?
Jim Oliver
AMA 18475
