  • July 12, 2025, 10:27:48 PM
Author Topic: What I like to do when I'm bored (a new sketch)  (Read 25284 times)
Online Matt Colan
Re: What I like to do when I'm bored (a new sketch)
« Reply #50 on: May 03, 2010, 03:23:25 PM »
Thanks Louie!!!  We're looking foward to your stuff!!!
Edit: Louie, grandpa just told me we got your stuff today!  I'm going to head over after I eat dinner, and poke through the stuff you sent us!!!  H^^
This looks very cool! The rudder shape looks disconnected . You have this beautiful curve on the wing plan. Perhaps you can incorporate a sweep like that into the rudder. This is just my two cents. What do I know: the cowl shape on my Stoli Special looks like the top of the fuse has a major overbite(dentist talk). I am VERY close to redoing the cowl.
I hadn't really looked at the cowl much, but now I'm going to be looking at that cowl to see what you are complaining about...
Thanks for the comments, I basically copied the rudder shape from Buso's Jaguar, and put the wing tips that I like on it.  I've even already come up with a paint scheme for the plane already if I were to build it (minus the wings), I like the shapes of this one that much!!!
maybe I will build it after the Cobra, who knows the future is yet unseen...
« Last Edit: May 03, 2010, 03:54:03 PM by Matt Colan »
« Reply #51 on: May 03, 2010, 09:54:00 PM »
That's the idea Matt. I can see the influences that are affecting you. Later, you'll look at these sketches, and be inspired to modify them more.
They look good, I prefer a little more of a slender fuse, but then I don't run a pipe. I do use a rear exhaust engine with a muffler.
Here's a project I'm involved in right now, to illustrate the process a bit.
The first iteration looked lean and mean in the concept stages.
Once I started working on it, I had to apply some aerodynamic rules. The design started to look "portly" to me. Here's where taking those art courses Denny mentioned comes to bear fruit.
It's getting there, and I believe the finished project will have much of the visual impact that the concept drawing does.
The first drawing is the concept drawing, the second is after applying some of the rules, then I realised that I needed more seperation between the wings.
Of course, mine are done on the computer, but what you are doing on paper is every bit as good.
As soon as I can convert my latest on this plane, I'll post where it's gotten to at present. This is not to compare our work, but rather to illustrate some of the design exercises one can go through.
Edit, I've conveted a couple of the drawings to jpegs.
The third one shows the portly, porky looking version when I increased the wing seperation. I felt that the fuselage had to also expand vertically, as the top wing being so much higher didn't look right.
The latest ,or last pic shows me trying to get the "look' back by changing perceptions. This is where that art training can help Matt.
So far, all I've done is changed the size of the spinner. This fools the eye, and makes the fuselage appear to be more in line with the concept sketch.
I'm considering making the fuselage wider so the design has balance, and appears more in proportion to the rest of the design.
These are the advantages of making sketches as you are doing. It gives you a direction, and a visual goal to shoot for.
Keep it up Matt. I think you may have a future in the best non-paying sport out there.
John,
Really cool bipe. i want one. Hey, you know there is a twin engined Stunter named Two Bits, Right?
Chris...
Offline Tom Niebuhr
« Reply #52 on: May 04, 2010, 08:00:58 AM »
Hey,
John is into twins and bipes... How about a twin bipe... now that would be different! How's that for a challenge John?
AMA 7544
steven yampolsky
« Reply #53 on: May 04, 2010, 07:57:32 PM »
I am talking about the up curve on the bottom front of the engine cowl on my Stoli Special. The curve on the plans was less aggressive but I thought it would look better. By making the curve up more aggressive than Rick drew, I made two mistakes:
1) While design numbers are Dave Cook's Lighning, the look was penned by Rick Campbell. Rick draws beautiful lines and by not following it, I made a messed up "the look". No one ever told me the model doesn't look good and I try to be objective and be happy with the look but I know the line is wrong and it glares at me every time I fly.
2) This one cost me several contest wins. By making the curve up too aggressive, I ended up with a small intake openning. Not enough air gets through to the engine which causes it to overheat and prevent any kind of consistent engine run during hot days. Another downside is the fact that the small openning gets blanketed by then nose on inside turns and causes the engine to overheat. if I wind them up too hard on inside turns, it takes too long for the motor to settle back to normal temps. Granted, the issue is non-existent if the temps are below 65 but that precludes any kind of summer flying.
« Reply #54 on: May 05, 2010, 09:51:56 AM »
Steven,
>>...I ended up with a small intake openning.<<
I suspect the problem was not too small an opening, but too small an exit. If you have decent flow through the engine compartment you can get away with a very small opening, but you need air exhaust area at least twice as big as the intake. Three times is better. It creates a vacuum in the cowl and draws out the air.
My current plane appears to have a very large intake opening in the cowl. But in truth, the engine is shrouded and the only opening is directly around the lugs and through the cooling fins. However there is a monster opening at the rear of the cowl. Air is sucked through really well. Makes for interesting fluid dynamics.
« Last Edit: May 06, 2010, 11:55:43 AM by Randy Powell »
steven yampolsky
« Reply #55 on: May 05, 2010, 01:37:32 PM »
Any ideas on how to open up a piped engine cowl so that there is enough air flow? Got pictures drawings? Anything!!! I don't want to loose Mass cup to Matt due to engine overheat! I'd rather make him work for it! I have no problem loosing when the other person outflies me but loosing due to things like a poor engine run absolutely infuriates me!
Last fall, I went through a lot of headaches to be able to go to Palisades Park contest. I really wanted to put my skills up against people we don't get in Massachusetts such as Mike Palko and Danny Banjock. I put up a practice flight 5 mintes before the official and when I launched, the engine overheated right away. A was so pissed at myself, I packed everything back in the car and went home. I don't want a repeat of this again!
Online Matt Colan
« Reply #56 on: May 05, 2010, 07:15:44 PM »
And I don't want to lose the Mass Cup to you for having the grass being too high, at least I will be able to take the wheelpants off the Oriental Plus.
« Reply #57 on: May 06, 2010, 11:59:02 AM »
Steve,
I think it was Frank Williams that had an article in Stunt News a couple of years ago outlining ways to cool an engine and pipe in a fully enclosed system. Small opening in the cowl for air intake and a huge opening over the pipe exit. The rest of fully enclosed and he had very consistent runs.
I have done this and it works. I've also had systems that had this with the addition of additional air intake directly over the front of the pipe (and the header connector) with another large exit just before the pipe tunnel exit. Really help with cooling.
Offline Shultzie
« Reply #58 on: May 06, 2010, 07:10:23 PM »
U bet..."HEATED AIR...ALWAYS EXPANDS and that old speed demon rule...teenie cowling inlets and LARGE EXIT OPENINGS.
Don Shultz
« Reply #59 on: May 29, 2010, 12:53:05 PM »
Weren't you mentioning that you'd gotten your hands on a new motor recently, and wondering what to do with it?
Given that you're churning out these sketches, isn't it obvious?
Get thee to a drafting table, sonny!  Flesh those sketches out, and build a model to your design!
(Hint #1 -- I've been a professional design engineer for decades now, and the way to make successful designs is to boldly put in only as much new stuff as is really necessary, and to shamelessly steal the work of others for all the rest.  So for inner structure and whatnot, I suggest you find a model that you feel holds up well and is easy to build, and copy it within your external shape)
(Hint #2 -- cover it with all your leftover scraps of plastic film, or by whatever quick method you want.  Chances are you'll be cutting into it and changing things; when you're done fiddling with it you can strip it down and re-do it, or build new).
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
« Reply #60 on: May 29, 2010, 01:59:13 PM »
When I was 10, I moved to New Mexico and found a good friend just down the street named Rex Reed. Rex and I had a common interest in model airplanes, 1/2A stuff, and we were inspired by the Scientific models. I remember Rex's Stunt Master, which I admired greatly. I had a Zig Zag which didn't fly as well.
When Rex moved away, we wrote each other regularly, and began including sketches for model airplane fantasies. Rex was a pretty good artist, and we both fed off each other. Over time, we both had explored a lot of interesting model airplane shapes and treatments - noses, cowls, cockpits, gear, rudder, wing and stab were all fair game for experimental renderings. Feeling that requirement each letter to include some new "thinking" led us to some very interesting (and sometimes silly) model airplane shapes.
Eventually Rex and I stopped writing each other, and now I truly wish I had kept some of our sketches.. They fueled a general interest in airplanes and models which neither of us quite got over. Kids nowadays should be so fortunate!
Keep it up, if nothing else you can end up with some pleasant memories.
L.
"You can take a horse to water, but a pencil must be lead." -Stan Laurel
Online Howard Rush
« Reply #61 on: June 10, 2010, 02:58:16 PM »
A drafting table?  Hey, we're in the 20th Century now.
23 skiddoo.
« Reply #62 on: June 10, 2010, 03:09:45 PM »
Here's a spline sample, on my fantasy "Stealth Stunter" fuselage "design" (which currently violates 3D
topology..).
Looks like the Bugatti race plane (that never flew, unfortunately -- they could have at least taken it for one test hop, just for the benefit of all the scale modelers out there).
I don't see the violation of 3D topology -- or does that not show in the 2-view?
Online Matt Colan
« Reply #63 on: July 19, 2010, 03:17:56 PM »
I've always liked the look of Lambroghini's.  I think they just have a mean and aggressive look, and IMHO would make a good looking stuntship if restyled right.
I named it Reventon because it's the name of the Lambroghini I used for inspiration.
How did I do?
« Reply #64 on: July 19, 2010, 04:18:57 PM »
You go, Matt!
My new one will look more like a 59 Chevy Impala low rider.   ;D
Howard,
>>A drafting table?  Hey, we're in the 20th Century now.  <<
Watch it, boy. Some of us still like putting pencil to paper.
Online Matt Colan
« Reply #65 on: July 19, 2010, 06:25:30 PM »
You go, Matt!
Howard,
Thanks Randy!
a 59 Chevy lowrider sure sounds cool!  No chance you could share that or is it relegated to secrecy in your skunk works!  ;D
« Reply #66 on: July 20, 2010, 10:40:18 AM »
Matt,
One of the problems with using an actual drafting table is it's tough to share plans   ;D
I could shoot a picture of the plan on the wall I guess. When I draw plans, I generally draw them so I can build the plane. An expect builder could probably take the plans and generally know what I was up to, but I look at them and know what I was thinking. A lot of times, I'll start building then figure out that something isn't going to work the way I envisioned it so I will change things on the fly and if I'm paying attention, will do things like trace parts onto the plan on the wall so I can make changes in the plan if I decide to build another one.
I've only actually gone to the trouble of doing a complete, you could build it from this, plan a few times when someone wanted to build a plane I'd done. That's what's making having Walter Umland do a kit of my Ringmaster Deluxe so interesting.
« Reply #67 on: July 20, 2010, 09:49:31 PM »
I came up with a minor detail idea this week (at work, duh!), that somebody might like. IF you have problems fitting a decent fuel filter into your cowl, anyway. My idea was to essentially run the fuel hose flush with the cowl surface (in a slot) and put as  big a filter as desired behind it...even one for an R/C car. Cover it with a scoop that's open on both ends, to camouflage it. Randy would probably stylize it with a widow's peak on the front and bifurcate the exit. Maybe some louvers over the filter? Ghost flames and pin striping to set it off... LL~ Steve
Online Matt Colan
« Reply #68 on: July 21, 2010, 07:24:36 AM »
Matt,
Yeah that is definitely the tough part in terms of sharing.  I'm thinking with this plane here, of attempting to make full size plans that I could build off of because I really like the way this thing looks.  I am trying to figure out a way in my head to get those panel lines that are on the car.  The way I think of it is to glue sticks onto the fuselage sides then just sand them in.  I think it would add to the appeal of this plane a little bit.  I also got an idea for an air scoop like the Reventon.
All these ideas and i don't even know if I'll even build the plane but it's nice to think about this stuff!
« Reply #69 on: July 22, 2010, 10:44:06 PM »
Matt,
Trust me, I design planes in my head all the time. Weird what may give you an idea.
Online Matt Colan
« Reply #70 on: July 23, 2010, 09:04:13 AM »
Matt,
Couldn't agree more Randy!  And I do see what you're saying about what gives you an idea.  I've had this idea for awhile and it looks like it could come to fruition at least on paper, but I still am not sure if I would build it.  But you never know!
  • Red Hot Lover
    • Stephanie Miller
« Reply #71 on: July 30, 2010, 09:03:16 PM »
I'm dating myself here (no one cares) but a long time ago Steve Allen hosted the Tonite Show.
One of Steve's many talents was "on the spot" song composition. He would ask an audience member
to play a few notes on the piano, and then compose a song around it, and give it a humorous name
(for copyright..).
It looked very difficult, yet some of the most unlikely inputs yielded good tunes. Evidently, the
challenge itself turned out to be a fine stimulus.
So what does this have to do with designing model airplanes? I'm suggesting that some novel
and interesting ideas might be spawned from a few nearly random shapes and lines, which become
a "theme" for a finished design.
To guide such efforts, I heartily recommend an article called "Design and Formation" by Claus Maikis,
which I had the privilege to transcribe for PAMPA Stunt News back in 1997 (I think). Claus is a
well known talented industrial artist as well as model airplane designer and flyer - one more Renaissance Man
in our hobby.
Claus' article discussed (with beautiful illustrations) how designs can incorporate themes: important information
for anyone desiring to learn to "design" themes for stunters.
Using a "Steve Allen" approach - taking inspiration from an almost random input might well result in
a fresh creative design. And we pretty well know how to "imprint" our theme or design on a practicable
stunter. We have easy access to the "numbers" associated with successful models. Styling can be less
constrained.
And we might well incorporate the newest "best practice" features to yield an excellent performer. Create
our distinctive styling around the well established technical mode.
Mr. Maikis and a dozen other superb designers and finishers (guys like Al Rabe and Randy Powell..)
show us everything from construction techniques to worthy paint and trim schemes.
With a winning design in hand, all that remains is to learn to FLY like these mentors! I left the hard
part for last..  ;->
A final attraction added to the rich set of technical and artistic experiences is simply "hanging"
with a diverse and interesting group of people. It's what keeps guys like me playing with CL Stunt.
L.
"Everything has been said, and we are more than seven thousand years of human thought too late." -Jean de LaBruyere
Online Matt Colan
« Reply #72 on: March 06, 2011, 08:39:32 AM »
It's been awhile since I've posted a new 1/4 scale sketch of a potential new airplane, so here's one I drew up last night!
This time I took the scientific approach with designing this stunter since I've read some of Ted Fancher's etchings about what to do when designing a new stunter.  I also read his Imitation article, which that helped out a lot with understanding why I should have a high drag low aspect ratio stab and elevator etc.
Some numbers for this plane are:
Wingspan: 59"
Wing Area: 660.0625 sq Inches
Aspect Ratio: 5.3:1
Flaps: 16.7% of wing area, and not full span
Nose moment: 9 1/2"
Tail moment: 18 1/4"
Total length: 45" 48 with spinner
tail area: 175.5 sq inches (26.5% of wing area)
Aspect ratio for the tail: 4.2:1
I like it  ;D
Offline Tom Niebuhr
« Reply #73 on: March 07, 2011, 06:17:03 PM »
Larry,
When I was playing in piano bars, I would ask the pretty girls for their telephone number and make a song out of it. Actually it was easy to do. I had a LOT of fun!
AMA 7544
Offline Peter Nevai
    • C3EL
« Reply #74 on: April 23, 2011, 11:57:42 PM »
Free 3d application, google "Blender 3D". Not a Cad design program, a 3D modeling and rendering application like those used for television and motion pictures.
« Reply #75 on: April 24, 2011, 10:15:48 AM »
If you ever have to do a year-long science project for school (like, if you go into aeronautical engineering and need it for a senior project), think about building a take-apart plane that'll let you swap wingtips and wings, and maybe even empennage.  Then do a series of experiments on how each change affects the handling of the plane.
If you go to someplace that does senior projects in teams (like WPI in Massachusetts), then maybe you'd have enough members on the team to do wind tunnel testing, to put numbers to the changes in "feel".  I think CFD is still fantasy for model-scale efforts like this, but maybe not -- computers just keep getting faster, after all.
Online Howard Rush
« Reply #76 on: April 25, 2011, 07:22:54 PM »
Why should you?
Online Howard Rush
« Reply #77 on: April 25, 2011, 07:26:55 PM »
Not because the air expands.  Remember PV=nRT?  What were you doing during that class?
edited for assholicity
« Last Edit: April 25, 2011, 07:53:13 PM by Howard Rush »
Online Matt Colan
« Reply #78 on: April 26, 2011, 03:37:17 PM »
Why should you?
It creates less load on the control system to get the plane to turn, and also makes it easier on yourself.  Furthermore, it allows you to have a more aft CG than a conventional classic ship with the smaller tail sections.
Online Howard Rush
« Reply #79 on: April 26, 2011, 07:40:33 PM »
I didn't notice the "etc.", which I guess says to have a big tail.  A big tail allows the CG to go back, which reduces hinge moment (control load).  I thought you were referring to reduced hinge moment, the capablility to move the CG back, and drag as virtues of a low-aspect-ratio tail, which they are not: elevator hinge moment is approximately proportional to elevator area x chord.  Tail effectiveness is a function of size and shape.  (I can send you a spreadsheet that gives a better answer than tail volume, but is still easy to find the numbers for.) Textbooks say, for good reason, that you can ignore stab drag for stability purposes.  I have been pestering people to explain why they use low-aspect-ratio tails, because I am planning not to do so on my new dog.  I haven't read Ted's article, so I was curious as to what it said.
Using the aforementioned spreadsheet, I figure that the tail on my current airplane is 82% as effective as a standard Impact's.  The one I intended to put on my new dog would have been about 113% as effective as a standard Impact's tail.  However, I sanded the tips backward: roundy at the TE and tapered toward the LE.  This wouldn't have fit the elevators, so I recarved the tips, reducing the aspect ratio and reducing the tail effectiveness to 106% of that of a standard Impact.
Best I can figure, a low tail aspect ratio gives a stiffer tail, which is good.  Also, a large stab chord makes the Reynolds number higher, which could keep the laminar-turbulent transition point from misbehaving, if I correctly understand Igor.
« Reply #80 on: April 27, 2011, 11:23:58 AM »
And in the end, you'll have an Impact.   ;D
Online Howard Rush
« Reply #81 on: April 27, 2011, 03:18:30 PM »
That would be good, but as you know, it's hard not to stray off the path.
« Reply #82 on: April 27, 2011, 11:46:42 PM »
Howard and I figured out how to reduce control loads 10 years ago.....
« Reply #83 on: April 29, 2011, 10:23:23 AM »
Curls?
« Reply #84 on: April 29, 2011, 07:57:06 PM »
Well I cant speak for howard but curls are part of my stunt fitness regime - Rush-boost tabs
Offline Brian Hampton
« Reply #85 on: April 29, 2011, 08:27:28 PM »
Back in about the mid '70's I built this huge 6 foot span stunter powered by a Taipan 61 that I used to fly at Moorabin airport with Peter White and the rest of the mob. It was a handfull so I fitted boost tabs to the elevators in an attempt to ease the loads. I got the idea from a large RC aircraft I used to work on at Woomera...the Jindivik :).
« Reply #86 on: April 29, 2011, 09:54:51 PM »
I have tried multiple configurations over the past 15 years - I found no signifgant improvement in reduction of stick force running them from the elevator. There simply is too much load from the flaps.
The reasons it works for rc to reduce servo load is that the elevator is running independant from the rest of the system. Our planes are coupled flaps to elev, so the effectinvess must be taken into consideration as a full package force load reduction system.
I flew the lancaster with Boost tabs fitted ,it was as easy to fly as any classic ship inregards to stick force - pull load was another story, I estimated during manouvers pull loads went close to 30 pound. We estimated this rather crudely, just after a flight I had someone hold a pull test machine and i had them pull whilst I was blindefolded and when I felt the load was that of what I experienced in flight it read 26.7 pounds. Im convinced in wind It moved a little higher.
We are taking 121 oz 2 m - 4 engined monalith. Boost tabs were extremeley effective in stick force reduction.
Conversely its proportinate to model size - I have run them on something as small as a 1951 Nobler, and noticed no improvement or reduction over standard. yet on my .81 sized 620sq 62 oz sq ship they work perfectly.
Nice to hear your experiences also. Elevator force reduction effectiveness? Not in my experience.
