  • June 16, 2025, 09:59:52 AM
Author Topic: New and Old  (Read 2881 times)
Offline Jim Pollock
New and Old
« on: March 16, 2009, 12:45:54 PM »
Here is the Old one....
The new one under construction
Offline Jim Pollock
Re: New and Old
« Reply #1 on: March 16, 2009, 12:48:59 PM »
Didn't get it on the last page soooo, here it is again the old one - 1969
Offline Shultzie
Re: New and Old
« Reply #2 on: March 16, 2009, 12:55:38 PM »
Jim...
Thanks for setting the Akromasta' building date that your model was before Lew's model. You set the appearence point goals pretty high for any other following Ackro builders..That is one BBBBEEEUUUUU TEEE FUL model of yours James...and this new one will surely become another piece of great looking sky art for sure.
« Last Edit: March 16, 2009, 01:30:40 PM by Shultzie »
Don Shultz
Re: New and Old
« Reply #3 on: March 17, 2009, 02:32:47 PM »
Curiously, are there plans for Lew's Akromaster around?
Offline Jim Pollock
Re: New and Old
« Reply #4 on: March 18, 2009, 09:56:44 PM »
Randy,
I don't know about plans, but you can call Lew up and ask him about anything you want to, I have.  Maybe he has some plans to his Akromaster version.
Jim Pollock
Online Gordon Tarbell
Re: New and Old
« Reply #5 on: March 20, 2009, 06:44:47 AM »
Is this similar to the Sig Akrobat kit (sistership to chipmunk)? Is this one larger. Always liked the Sig plane.
Gordon Tarbell AMA 15019
Offline Jim Pollock
Re: New and Old
« Reply #6 on: March 20, 2009, 11:48:44 AM »
Gordon,
Short answer to you question is NOPE!  Mine has a 52" Span and is basically a disguised Gieseke Nobler.
Lew's is larger and has about a 57" span with a ST .46 for power.
Both are scratch builds from similar ideas, mine was circa Oct 1969 and Lew's was circa 1973 - So mine squeaks
in as classic and Lew's doesn't.
Jim Pollock, hope that helps you out a little bit?
Offline Jack Pitcher
Re: New and Old
« Reply #7 on: March 20, 2009, 04:22:04 PM »
Lew's Acromaster stunter was published in the Nov. 1974 issue of the old American Aircraft Modeler magazine. Seems to me it was it was shown with options to be built in both UC and RC versions. I have that magazine around here somewhere. Tom Dixon lists the plan in his modern era plans section on his web site.
Jack
Jack Pitcher
Vortex Stunt Team
AMA 65309
Re: New and Old
« Reply #8 on: March 20, 2009, 11:41:29 PM »
   I saw the Acromaster fly many times. Lew said he would practice a lot with the Acromaster, then, shortly before the NATs, change to the Shark. Theory being, the Shark flew better, so for a while after the switch, everything seemed really easy. I've done stuff like that, too, and it seems to work!
Re: New and Old
« Reply #9 on: March 21, 2009, 11:47:29 AM »
Here is my R/C Acromaster. 60" span with an Enya 45. Built back in the early 70's before Lew's came out. It was built off of Sid Morgan plans. Ah! The memories.
Offline Geoff Goodworth
Re: New and Old
« Reply #10 on: March 22, 2009, 12:23:05 AM »
Jim Pollock. Are there plans for your Akromaster? It's a great looking model.
Cheers, Geoff
Offline Jim Pollock
Re: New and Old
« Reply #11 on: March 22, 2009, 08:59:50 PM »
Geoff,
I only have one original plans set, it's drawn up from some measurements of the 1969 plane in pencil format.
Jim Pollock,  I'd like to get them on Cad someday?   :!
Re: New and Old
« Reply #12 on: March 23, 2009, 11:23:01 AM »
Jack
Plans for the McFarland Akromaster are avaialble from the AMA plans service.  The plans show that it can be constructed to CL or RC.  It is a capable CL stunt design
Re: New and Old
« Reply #13 on: March 24, 2009, 09:00:44 PM »
   Lew's flew pretty nicely, as I recall. I guess I couldn't tell from the outside that it wasn't as good as the Shark. I also saw him enter Scale, and do pretty well, with the same airplane he flew in stunt.
Offline Jim Pollock
Re: New and Old
« Reply #14 on: April 25, 2009, 11:27:46 PM »
GOSH- - -
Then I need to practice with the Shark before I fly the Akromaster.  It does fly better than My Shark in actuality.
Jim Pollock   y1
