  • June 16, 2025, 02:01:45 PM
Author Topic: A twin engines tail feathers  (Read 4549 times)
Offline dennis lipsett
« on: August 05, 2012, 08:23:51 PM »
I'm just curious about something that I might need to redo. In production twins the rudder and fin is usually larger then a single engine model and I believe that the stab and elevator has increased area. If doing a twin engine variant of a single engine model do the surfaces have to be enlarged and what would be a reasonable percentage.
Thanks in advance for any info.
Dennis
« Last Edit: August 05, 2012, 08:53:58 PM by dennis lipsett »
Re: A twin engines tail feathers
« Reply #1 on: August 06, 2012, 12:03:53 AM »
Dennis
In a full size twin engine aircraft, the vertical tail must be large enough to provide sufficient lateral stability and control for single engine operation, meaning the vertical tail must be able to handle the assymmetric thrust when one engine is out.  For our control line stunt models, vertical side area is good to a point but it is not necessary to be increased just because there is a second engine, assuming that both engines will be running during the flight pattern.
« Last Edit: September 04, 2012, 01:44:39 AM by Trostle »
« Reply #2 on: August 06, 2012, 07:23:29 AM »
Thank you for the information. I was hoping that I didn't have to redo the back end.
Dennis
« Reply #3 on: August 31, 2012, 03:47:12 PM »
Thank you for the information. I was hoping that I didn't have to redo the back end.Dennis
Dennis,
It may be fashionable, for appearance sake only, to increase the span of the "back end."
The extra sq's could make a difference in performance?
That could be hashed over.
You didn't mention the model?
Charles
« Reply #4 on: September 01, 2012, 08:23:55 PM »
(Clip)
(Clip)
Charles
Why?  And in what way?  What "difference in performance" are you looking for?  Yes, it looks like you are just wondering about the question, but why suggest it if you have no real technical reason for doing so?
Offline Chris Wilson
« Reply #5 on: September 02, 2012, 07:46:05 PM »
In a full size twin engine aircraft, the vertical tail must be large enought to provide sufficient lateral stability and control for single engine operation, meaning the vertical tail must be able to handle the assymmetric thrust  when one engine is out.
I never knew that!
Good reply mate.
MAAA AUS 73427
Offline Steve Thomas
« Reply #6 on: September 03, 2012, 07:31:27 AM »
I did know that, but didn't consider it all that important for CL, and made the mistake of designing a twin-fuselage thing (for a couple of Norvel 061s) that had smallish, low aspect-ratio tail fins.  It flew great, up until the point where the inboard engine quit early for some reason.  It was still flying very nicely, so I pulled it up into a wingover.  About a 12 kt tailwind as it went over the top, speed dropped below Vmca, and all of a sudden the thing was in a flat spin, dropping straight towards me.  Minimal damage, luckily.  If I do another one I might rethink the tail surfaces.  ;)
« Reply #7 on: September 03, 2012, 09:30:14 AM »
Ah, suggest not trying to do tricks with a CL twin with only one engine running. HH%%
« Reply #8 on: September 03, 2012, 05:02:12 PM »
Is not a flat spin a trick in itself?
(Sorry Steve.)
MAAA AUS 73427
« Reply #9 on: September 03, 2012, 08:28:59 PM »
Well, I thought it was rather good, once I got out from underneath it!
« Reply #10 on: September 06, 2012, 10:05:05 AM »
... speed dropped below Vmca...
I like that description.
« Reply #11 on: September 06, 2012, 07:25:28 PM »
Do we need a 'Like' emoticon now?
MAAA AUS 73427
Offline Douglas Ames
« Reply #12 on: October 29, 2012, 03:50:41 PM »
I never knew that!
Good reply mate.
Chris , here's a video of a Arthur Godfrey and an Eastern Super Connie flying on ONE engine.
The triple tails weren't for looks, but the were very efficient for dealing with asymmetrical thrust!
The engine out demonstration starts at time stamp 6:40
AMA 656546
« Reply #13 on: October 29, 2012, 07:42:46 PM »
Thanks Doug.
MAAA AUS 73427
« Reply #14 on: October 29, 2012, 09:08:13 PM »
There were several factors that went into the triple tail design of the Constellation.  Yes, there may be some advantages to multiple vertical tails in a multi-engine aircraft to deal with various engine out operations.
The Constellation had some design heritage from the P-38 Lightning.  The Constellation wing is basically an enlarged version of the P-38 wing in planform and airfoil  The P-38 had twin vertical tails (yes, it it obvious that there was no other way to do it on the P-38) so why not go on with the idea of multiple vertical tails on the Constellation.  But one of the main factors was the vertical height that would be required with a single vertical tail on this airplane.  The basic design for the Constellation was laid out before the war as a commercial venture (involving TWA and Howard Hughes).  At the time, the Constellation would have been one of the largest commercial airliners and even with the relative short vertical tails, it was taller than most airliners at the time and few commercial airfields/commercial carriers had hangars that could handle anything taller.
Offline Chuck_Smith
« Reply #15 on: October 30, 2012, 04:45:05 AM »
Bingo! It had to fit in the hangar.
AMA 76478
