Id found the negitive offset leadouts , definately , when ' it was blowing ' so the handle was ' loaded up ' -
That , in rounds , the pulled line had way more load , than the other . SO you let the bottom off the handle do the ' fine toonin ' . i.e. de egging .
as it was way more sensitive & lighter . than the one trying to pull you over .
( Bobs ' top & bottom ' control ! )
This thing had a heavy 3/8 thick wall aluminum pushrod . As a ' damper ' . And Ears on the elevator ends . To balance control loads .
Flying light in clean air , there was alost a ' schnick ' ( as it were ) as you ( with familiarity ) threw on or reversed control .
As in ' 8 ' intersections , etc . more dicernable .
As this one never hit the deck , despite flying in 20 / 25 mph winds , at times . And downdrafts & turbulance from trees . I thought it o.k.
Sort of winds that hold it down & delay vertical turn downwind . WHICH brings up ' Tracking ' & ' Groove ' which it'd do . Even on an aft C G .
( High Point of airfoil / AT bellcrank pivot .
So theres a thing .
Flaps & tail were TOUGH New Guinea Quater grain , so stiff . Tho I thought the elevator horn coulda been stiffer . Re the ' Hold Down ' mentioned .
This thing atb 70 ounces twanged 7 strand steel 18 thou. lines in lower Sq turns , when you needed two hands ( and golf shoes on the damp field )
and stretched .016 solids discernably . When the gales off November came early . as it were . was .
BUT . the Bellcrank - gave that ' schnick / schnick ' control precision /in ordinary conditions . When the lines wernt stretching .
On the 16s in gales it gave the elastic rubbery feel , under duress ( working hard manouvreing . Did the full schedule nearly all flights )
SO . Ya gotta watch yer rubbery lines arnt attributeinng to your ' control issues ' . Missdiagnoseing darting dodgeing flight as aircraft . When its actually your control wires .
Pitcher offittr , for the reckoid .
