  • June 14, 2025, 12:01:52 PM
Author Topic: Sig Acromaster spearmint  (Read 9321 times)
« on: January 13, 2017, 07:49:32 AM »
I built this model.  It's not overweight and the LA15 runs OK.  But I've been unsatisfied by the square-turning performance.  Tail weight and additional flipper travel haven't helped.
I did the usual trick of extending the wing to the full extent of the LE & TE.  Maybe I have too much wing area for the tailplane.
So now I've begun spearmint.  I'm going to build a bigger tailplane and see what happens.  Results in April.
A similar fix did wonders for a Sig Twister with the same problem.
Offline Chris Brainard
Re: Sig Acromaster spearmint
« Reply #1 on: January 13, 2017, 09:13:33 AM »
Is it nose heavy? The last one I built balanced well with a TD .09. Plenty of power for the weight (18 oz.), but not very good squares, maybe due to our elevation (Denver, Co one mile above sea level). The next one will be scratch built with a goal of 12 oz. and a Big Mig .061. These are more the size of a 1/2A stunter.
Chris
« Reply #2 on: January 13, 2017, 09:58:39 AM »
On this and a couple of other planes, I got the feeling that the tailplane was being pushed to its limits and the nose wasn't coming up enough.  I've added tail weight with no results other than jumpiness.
I'll make the tail enough bigger to see if it helps.  I can always cut it down if it's too big.
Downsizing planes to 15 size can end up with things like an undersize tail.
Offline paw080
« Reply #3 on: January 14, 2017, 02:56:28 PM »
Hi Paul, what does your Akromaster weigh?  I've had an Akromaster for a couple of decades.
It weighs 17.5 ozs and is a flying mini elephant. It also does wide radius 90 degree direction
turns.  The answer is simple, the wing loading is too high.   It is powered by a Chinese Yin Yan
plain bearing 5oz diesel engine. This same engine has flown a Dumas Tomahawk on 60' X .015"
lines which weighs the same 17.5 ozs.  Yet, it fly's a much better stunt pattern. The reason is
the Akromaster has a 10.5 oz/sq' compared with the Tomahawk's 7.6 oz/sq' wing loading.
About seven years ago, I went a bit crazy and scratch built another Akromaster, shortening the nose moment for
 the MP-Jet 1.0cc diesel engine and much smaller fuel tank required. It has a 6.65 oz/sq' wing loading and
 pops square turns like a Combat ship.  I changed nothing but the nose moment.
Tony :)
« Reply #4 on: January 14, 2017, 03:04:48 PM »
If you're not too far along on the replacement plane, try extending the rear fuselage.  You have more than enough elevator, but the tail moment arm looks a bit short.
« Reply #5 on: January 15, 2017, 08:40:44 AM »
That would be another approach.  But more work than I had in mind.  I upped the tailplane span from 13" to 15".  I'll check the weight when I get it back together.
« Reply #6 on: January 15, 2017, 02:34:32 PM »
I measured it up:
Wing area: 282 sqin
Old tailplane: 42 sqin
New tailplane: 52 sqin, a 25% increase.
I'm know if it works, probably some time in April.
I doubt that a 15-size stunter with this size wing will ever be great, but I hope it's better.
« Reply #7 on: January 15, 2017, 03:34:40 PM »
It may work better if you move the elevator hinge line back.  All of my flapless stunters have about 1/5 to 1/3 of the total horizontal area in elevator: contrast that to 1/2 or so on a flapped stunter.  You just don't seem to need as much, and if you have too much then you'll hit the Netzband wall.
« Reply #8 on: January 16, 2017, 10:16:03 AM »
It's ready to fly.  A little under 20 ounces with the LA 15.  I might be able a save a few tenths by going to a Max III, if it runs.
Offline Target
  • C/L Addict
« Reply #9 on: October 02, 2018, 01:56:05 PM »
And what was the result of the larger tail? Did it improve things?
Target
Chris
AMA 5956
Offline MikeyPratt
« Reply #10 on: October 08, 2018, 03:36:29 PM »
I measured it up:
Wing area: 282 sqin
Hi Target
Total area of the stab & elevators should be at 20% of the wing area (282=54.5) is good place to start.
Mikey
Offline Target
  • C/L Addict
« Reply #11 on: October 08, 2018, 06:02:08 PM »
Thanks Mikey.
Would still like to get a report from Paul Smith on if the flight was improved or not.
On the stock Akromaster, do YOU think if built light, and stock, that a Cox Medallion .09 is a suitable engine for it?
Chris
AMA 5956
« Reply #12 on: October 14, 2018, 04:41:39 PM »
I test flew it again.
The bigger tailplane helped, but it's still just a decent sport plane.  Not a stunter.  No square corners.
« Reply #13 on: October 14, 2018, 04:59:48 PM »
     It's smaller than a lot of 1/2A stunt planes, but is built for shakers like McCoy 19's, etc, so its also heavy. And check that LE radius! Do I recall correctly, this is a machined LE about 3/4" chordwise, right?  Not that this will solve the issues entirely, but, you might get better performance if you blunted the LE a bit more.
   This seems to be a recurring problem with all of these "Jr" models from ancient times, they are too small for a modern engine, and too heavy to use .049s on.
A modest proposal
« Reply #14 on: October 14, 2018, 05:24:49 PM »
Seeing as how this business with "15-sized" airplanes keeps coming up, people must be interested in them. If you want it to work with a 15LA, I think you want about a 18% scale-up of the the Akromaster, to give you 350 square inches instead of 250, use something close to a NACA 0016-0018 for an airfoil. Use the same 25% tail and make the tail moment about 17"-18" from the CG to the hinge line (assume the CG is at 15% of the chord).
