Tiss wonderous , ive spent 5.000 years looking at Me 110s for stunt .Theres a Gloster Twin ' shragemusic ' fighter near the same , but fastback & Lanc. like cowls if V-12s. . . anyway . . .
Looks good , Id tend to run a piece of 1/2 x 1/4 @ 30 deg along under the top block to get the canopy frame less than full fuse width . ( have a look at a few of sheeks plans ) & either that & the 3/8 triangle to the bottom edge.
to get a near scale cross section .
The Old ' Yard Rule ' trick ( 1/4 x 1 1/4 spruce ) between nacelles to take landing gear , or two seeing its takeing landing gear , engines and suchlike .
The thing can be built near scale , but im off nazi pant jobs. Had the eyetalian airfarce book last week ( Library )
nice black one with I think pale blue fuse band and sfa markings .
Though the Wasps eye , & dark green battle of britian schemes are o.k. ( have a look at sheeks skyrocket
seeing you insist on the Detroit bit.
Templates and fully sheeted'd look more autentic, but a good bump could end its days, the way youve got it
should have a bit of spring or give .
Side mounted engines could be smart .
Built a diesel 110ish thing thousands of years ago , probly my sixth plane. Was like a pommy cartoon .
so much vibration there wasnt much that wast blurred or flapping . So use a Stiff Spar .
