  • July 19, 2025, 03:05:05 PM
Author Topic: Shorter outboard wing panel  (Read 3207 times)
Offline TroyMartin
« on: April 26, 2017, 08:58:03 PM »
I have noticed that some stunt planes have a shorter (half a bay or so) outer wing panel and was curious why?????  Thanks!
Re: Shorter outboard wing panel
« Reply #1 on: April 26, 2017, 09:09:13 PM »
To carry the weight of the LINES !
If a plane ' comes in ' on equal panels , they tend to ' roll up the lines ' ,
whereas a longer inner will lift the inner ( upright or inverted ' and tends to fly the lines TIGHT , of its own accord .
Though thats outside the design criteria of ' pro '  :-\ F2B / P. A. , where 1/2 assymetry seems to be preferred ,
being theyre Supposed to stay out there full time . Thus they carry more tip weight .  S?P
 H^^
« Reply #2 on: April 26, 2017, 09:24:34 PM »
lots of technical explenations are appropriate but the simplest answer is that as the plane flies, the inboard wing covers less distance and slower so it is longer to create a semblance of symmetrical lift to the outboard which is moving faster but farther
Offline TroyMartin
« Reply #3 on: April 26, 2017, 09:26:46 PM »
Thanks !
« Reply #4 on: April 26, 2017, 09:43:56 PM »
   Since the airplane flies in a circle, the outboard wing travels a little bit faster than the inboard. To get the lateral (left-right) center of pressure in the middle, the inboard wing has to be slightly longer.
     It's not extremely critical. The right difference for typical 40-60 sized stunt planes is about 3/4", but an inch or so is OK, and zero is also workable. If you make it the same length on each side, the CP will be shifted over about 1/4-3/8" to the right, and you have to add a bunch of tip weight to shift the CG over that far, too.
