Design => Stunt design => Topic started by: W.D. Roland on August 11, 2009, 08:43:37 PM
This looks like the place for this.
My last few control line stunt type airplane are done this way, so far I like it.
Cures a few problems
1--The old Dang it,knocked the rudder off on the car door HB~>
2- adjustable
3-Easy
4-holds adjustment with "normal" bumping and abuse.
Made from .030 soft aluminum.
Measure offset with strait edge on inside of fin to check setting if bumped.
Regular R/C type hinge slots.
Pictures are of light weight Shoestring practice/fun plane.
Looks like All up weight will be 23-24oz with fox stunt.
David
51336
G'day David
A similar arrangement using 1/16" dia brass tube is used by John Miller and was included as an option on the drawing for the Brodak Shoestring.
It works well.
Cheers, Geoff
That might be even easier just making holes instead of slots.
Brass rod or tube?
David
51336
I've used both, as well as copper wire and tube. Works well, simple, and the rudder is ground adjustable.
I've made ground-adjustable rudders using a strip of K&S plastic sheet of about .010 or .015" as hinge. Almost invisible and no clearance is required, as with pinned hinges.
I think there is more stress on the rudder than you might think. I prefer the rod adjustment that will hold steady even in heavy wind.
I had that exact aluminum tab setup on my Avanti, they fatigued and snapped. At first I kinda liked the idea that it would flex in flight. I jokingly called it my "infinately adjustble load sensitive rudder", thinking that if the wind was blowing hard enough to straighten it out, then I didn't need much rudder at that moment anyways. The idea may still have merit, but with a limited travel coil spring over rod type setup. Rabe rudder would probably be better still.
I replaced them with pinned hinges, a small section of threaded rod and small 2/56 snap on type ball link setup. works much better and finer , more precise adjustment if all you want is an adjustable fixed rudder.
EricV
