Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
---->Stunt News click here<----
July 06, 2025, 06:16:10 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
Rib thickness
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Rib thickness (Read 1578 times)
Geoff Goodworth
Trade Count:
0
Captain
Rib thickness
on:
August 23, 2008, 06:48:08 PM »
Hi folks
I notice that most stunt models up to the 40/46 engine size use 1/16" ribs. I expect that using 1/16" on smaller models is for durability but then, some of the larger models use 3/32" thick ribs.
Can anybody suggest guidelines for when the rib thickness should be increased?
Cheers
Geoff
Logged
Jim Oliver
25 supporter
Trade Count:
0
Admiral
Re: Rib thickness
Reply #1 on:
August 23, 2008, 07:18:04 PM »
Geoff,
My Strega kit (big model, 700++ sq. in. almost 3 inchs thick at the root) uses 1/16 inch ribs-----but many of them. Something like two inch centers, I think.
With cap strips, rib thickness may be less critical.
Cheers,
Jim
Logged
Jim Oliver
AMA 18475
21 supporter
Trade Count:
0
Admiral
TreeTop Flyer
Re: Rib thickness
Reply #2 on:
August 25, 2008, 08:48:06 AM »
It also depends largely on the weight and grain of balsa. You can get away with thinner ribs if you are using heavier "C" grain balsa. If it is lighter stuff, it will probably need to be a bit thicker to avoid crushing. Ans as Ty notes, capstrips add resistance to crushing.
Logged
don Burke
2014 Supporters
Trade Count:
0
Admiral
Re: Rib thickness
Reply #3 on:
August 31, 2008, 10:17:31 AM »
As noted the ribs are there just to give the airfoil shape. 1/16" is good for just about any size airplane AS LONG AS there are capstrips. The capstrips turn the rib cross section into an I-beam and contibute to the "hangar handling" strength and help control warping of the wing and the ribs themselves from covering. The bending strength of the wing comes from the spars and shear web and in most designs the LE sheeting.
A few years ago I built a Cardinal and had nothing but trouble with the wing wanting to crush from handling as well as being very weak in bending. There was basically nothing left of the ribs vertically due to the cutouts for the leadouts. Instead of putting in full shear webs I put 1/8 sq strips between the spars at the ribs, and 1/8 x 1/4 diagonals in place of shear webs between the ribs. The strength of the wing was immensely improved. I finally pancaked it in inverted, pilot error, and the wing did break in half but it was due to overzealous sanding of the center section sheeting. Nothing happened to the rest of the wing.
Logged
don Burke AMA 843
Menifee, CA
M Spencer
Trade Count:
0
Admiral
Re: Rib thickness
Reply #4 on:
September 24, 2008, 09:04:02 PM »
stiffer stuff to the middle and load bearing (u/C mounts )and tip ribs.
Same selective shear web game . max lods at center.
If your in a windy area a bit of glue here and there
stiffens it to.
Gets into the old "how much is 10 Gs argument,
Stiffer and a bit of weight stop gusts getting the upper hand.
Lighter (and an extra rib bay or increased spacing ) for
hotter dryer ares.
Something to do with ralitive air density.
Good to have a heavy dunger that can take a few knocks for the
flying for fun or relaxation after work,
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
Rib thickness
