  • June 15, 2025, 03:52:03 PM
Author Topic: Reducing control forces using spades  (Read 38051 times)
Offline Mark wood
« on: November 14, 2021, 10:46:21 PM »
I flew the first flight tests of of the SV11 with spades today. Then there was another event
Sorry about being long winded.
« Last Edit: November 15, 2021, 02:05:31 PM by Mark wood »
Life is good AMA 1488
Offline Mark wood
Re: Reducing control forces using spades
« Reply #1 on: November 15, 2021, 08:34:47 PM »
These are something I have brought up from time to time when in conversation regarding the reduction of control forces on the aircraft particularly as result of adding flaps. It isn't often I try something which turns out as good as I hope or better. Unfortunately, I don't have an alternate pilot to fly the airplane in an A-B test to confirm my assessment. We have had a fairly large discussion on another thread which this discussion departed the intent of that thread. Because of that, I thought it would be good to separate this into a new topic.
It is and remains my opinion that an offset hinge is a superior method of reducing the hinge moment at the surface. The down side to this is that it is very difficult to make changes to the configuration. In the 4/4 arena the aerobatic airplanes use this offset hinge and often we see a small spade in use to supplement the surface. My opposition to using spades is more practical than technical. They stick out and can be easily damaged. On my test plane I put them on the top of the wing and they aren't purdy either. I spose a master artist could do something about that. That's not me.
There is really no super science aerodynamic calculations I performed to get to the solution I used. I did rely a lot on previous work on 4/4 airplanes. Here's the concept of a spade. The spade is a thin plate surface mounted ahead of the hinge line and has some vertical separation which in necessary to allow the spade to pivot with the surface it is attached to. The shape of the plate is somewhat important in that it's desired characteristic is that is produce a linear change in lift and drag with angle of attack. This is a characteristic of delta planform wings which produce their lift primarily from the vortex rolling up over the top or bottom of the wing. Other low aspect ratio plates can work as well but the delta configuration has been implemented with great success. So start any effort with that as a baseline.
To design the support struts I did some layouts of the wing and flap. This is a necessary as you need to prevent collision of the spade with the wing. What I found when I was doing my layout is that is would be very difficult to make this work correctly with a flap having 45 degrees deflection. In that case the arm would have to be very long which isn't necessarily bad but out of my experience zone. The moment generated by the spade is a combination of lift and drag from the spade times the combined arm.
Think of a spade as a small canard in front of the flap or other surface. Some 4/4 aerobatic planes have them on the rudder too. That canard provides a counter moment to the surface moment because it is on the opposite side of the hinge. I made three calculations in preparation of designing the spade and it's attachment to the flap. First is the mean aerodynamic chord MAC of the surface. I actually just did a layout on this as it is simple to do with CAD but a pencil and paper work okay too. The surface can be treated just like a wing and we can assume the center of pressure works through the 25% point measured from the leading edge of that chord, we say 25% LEMAC.
The reasoning behind finding the MAC is that is where I planned to place the spade. There are other places they can go on a surface for other reasons such as mass balance for flutter prevention. The other is that I know that in balance, 25% of the area will be in front of the 25% LEMAC location and if I size my spade less than 25% of the total area of the spade - flap combination I run a good chance of not having bad things happen. The caveat / assumption is the force generated by the spade being linear. So my other two calculations I made were the area of the flap and the sizes necessary to create the spade which I made less than 10% of the flap area. Easy peasy. No big rocket science involved.
The structure configuration was a bit tough to get and make right with the amount of area necessary and keep fairly compact. So I designed my spade in a manor that has worked well for me in the past. I have to say we did see one airplane where it didn't work as good as on mine. The front is truncated with 60 degree sweep angles. The sharp corner edge generates a strong vortex that stays in place quite well. There is a span / aspect ratio where this doesn't work but below 2:1 it seems to be consistent. The TE of the spade is located directly over the hinge line. It is there because of the geometry but with long struts it could go farther forward.
The strategy of spade testing is to start off small and make them bigger testing the flight envelope at each iteration. On my Laser as on the SV I did the first tests with only the strut, on the laser this was because some critical mass was collocated there. The first spade I made turned out a bit larger than I wanted because I printed out a drawing from autocad to pdf and a scale error occurred which I didn't catch until after I had cut the 1/16" plywood and drilled the holes. The day was getting late and I wanted to fly so I cut the spade down a bit and it turned out  to be between the 5% and 10% sizes I was planning to iterate. It's Kansas. Today was a Unicorn day where the winds were forecast to be less than 5 mph. I rarely fly into my own wake but this evening I did and I was making really good wakes.
My test flights today were a full length flight with just the struts in place. The holding plate for the spade is about 0.8" x 1" which surprisingly made a detectable difference. I flew the airplane through the pattern to check it's behavior and all was fine. The next flight I attached the spades and cut the timer down to 1 minute as I didn't want to fight a bucking bronko for a long time. I wasn't worried, just cautious. During the take off a line connector straightened out and startled me pulling out an inch or two off the ground from about 14". I did some gradually increasing aggressive pitch up, pitch down and duplets to check for any bad behaviors. There weren't any. And better, the control gradients were discernably lower.
I will often refer to stick force gradient which is the term used in flight test for the slope of the moment at the stick for the pilot. It is the measure of how much resistance the stick produces and we generally want to see a positively increasing force from neutral to full stick deflection.  Doesn't have to be a lot, it just shouldn't reverse it's direction and get lighter with deflection. The reduction in this was flight was obvious and I detected no gradient reversals.
After the first flight I increased the flight time to 4:30. I began with just some basic wing overs and then reverse and loops. And squares. Yeah I suck at pinning the trajectory of the squares and the lighter stick forces made the corner much easier and the exit just as sucky. With low control moments, control with lower line tension is much better. This is a place where this configuration definitely works. I did some interesting test maneuvers such as square vertical eights and hex loops and hex eights, I didn't try square overhead eights but they would work. Of course those would be turning in the zone where line tension usually isn't an issue.
After that flight I went back and flew the pattern. I still suck at all the parts I always suck at. But it was easier to suck at those parts.
Bottom line, I'm calling this one a successful first flight and don't see a roadblock to more development. I'll probably make another larger spade but I'm thinking if larger is necessary then adding another one further out would be a better approach than a large single spade. The rational for that is that the higher aspect ratio spade will at some point start behaving like a normal wing and stall around 20 degrees causing a nonlinear force curve. I'll also be putting the tail and fuse cams on to see if any badness happens.
« Reply #2 on: November 16, 2021, 09:38:13 AM »
What ever happened to balance/counter-balancing the control surface?
You EAA guys always, always thinking. A good thing actually.
CB
« Reply #3 on: November 16, 2021, 12:22:50 PM »
To clarify, are your spades only on the top?
Online Trostle
« Reply #4 on: November 16, 2021, 01:31:31 PM »
And if only on the top, Why?
« Reply #5 on: November 16, 2021, 02:30:08 PM »
PJ, Keith, and I used balance tabs.  I think they were more effective near neutral than at higher flap deflections.  I switched to Igor's nonlinear flap mechanism, which increases leverage over hinge moment in addition to its other virtue.
Offline Mark wood
« Reply #6 on: November 17, 2021, 05:22:55 PM »
Yes, only on the top. Think of the spade as a canard of sorts. If the flap were in the wind all by itself trailing behind the hinge, it would take a moment equal to the lift force acting at the Center of pressure times the distance to the center of pressure from the hinge line to displace it. Now if we put a small surface out front of the hinge line, it would create a countering moment similarly. The unfortunate situation is that we can't exactly place the spade straight out in front of the hinge because the wing airfoil gets in the way so we displace the spade vertically in order to prevent collision with the airfoil contour. It's no different than the stabilizer vertical separation on the fuselage or a T tail. It would not necessarily be necessary to have them on the bottom as well although it could be if the drag component of the moment created asymmetry in either the positive or negative directions.  I did not notice that when flying so, if it is there is wasn't much. The only magic to the decision to place them on the top of the wing as opposed to the bottom is entirely due to how I transport the airplane in my POSburban which is full of junk which creates a damage risk.
I made a video.
Offline Mark wood
« Reply #7 on: November 18, 2021, 06:25:25 PM »
I made another video of a flight I did today. I had troubles getting all of the cameras working but this wing cam perspective is pretty interesting. I pretty much was just hacking at maneuvers as the sun was really bright and right where it was getting in to my eyes. Watch for several directly overhead square corners.
I have a  tail cam also I'll post soon.
« Reply #8 on: November 18, 2021, 09:29:09 PM »
   That's very interesting. Do you notice any asymmetry in the effect? Looks like it gets very close to the wing on "down" and is far away on "up".
   The other interesting thing is that you are using a lot more control deflection than I have usually seen trying to capture still pictures.
p.s. an observation - if you put them near the tips of the flap, you could get a ballpark estimate of the torque they are applying by noting how much the flap twisted. I would not want them there for normal applications, obviously
Offline Mark wood
« Reply #9 on: November 18, 2021, 11:15:27 PM »
 No asymmetry that I have noticed. If they were out towards the end of the flap result is opposite of what you think. When you drive the flap from the middle there is a twisting of the flap due to the lift over the span. With a balance tab like this the twisting is reduced. Simple physics. The control forces are much lower with the spades installed which gives the airplane t he ability to maneuver aggressively overhead. Obviously technology not invented from within isn't worthy of being used. Why are you like Brett?
« Reply #10 on: November 18, 2021, 11:30:48 PM »
That’s why I have stiff flaps. I don’t have to keep track of signs.
Offline Mark wood
« Reply #11 on: November 18, 2021, 11:44:13 PM »
LOL I seriously doubt your flaps are stiff. Heavy in flight maybe. Tail cam video is posted.
Offline Mark wood
« Reply #12 on: November 18, 2021, 11:45:47 PM »
Here is a video from the tail cam. My Gopro SD card died mid flight so there isn't any video from inside. My new DJI gimble camera arrived and it has much better zoom and tracking so we'll see if we get another flying day.
« Reply #13 on: November 19, 2021, 01:20:08 AM »
« Reply #14 on: November 19, 2021, 01:24:40 AM »
    I didn't  say which way.
Offline Jim Svitko
« Reply #15 on: November 19, 2021, 06:53:05 AM »
Regarding the tail cam video:
When the flap is deflected down, tufts on the flap and on the wing trailing edge move inboard.  Is this happening along the entire length of the surface or only in the region where the spade might have an influence and cause it?  Is this detrimental to performance?
I could not see very well if the tufts were moving sideways with the flap moving in the opposite direction.
Offline Mark wood
« Reply #16 on: November 19, 2021, 07:15:01 AM »
I have another thread showing just the plain wing and the inward flow along the TE is in both configurations with and without spades installed, A-B tests. It is very interesting and if you look at the reverse maneuvers you can detect the opposite happening and the flow is moving outboard. This is the result of the pressure field and vortex flow on the wing. A vortex is rolling up at the tip and at the wing root which you can see if you look carefully at tufts located in their proximity. This only occurs to this degree at high angles of attack and not elsewhere in the flight realm. It is very curious and at greater angles of attack the flow reverses showing the inflow of high pressure air to fill the turbulent bubble created from the unset of stall.
I was surprised by how little influence the spade actually seems to have with the airflow on the wing. The surface flow on the wing doesn't appear to be disturbed until the nose of the spade gets very close and you can see one of the tufts begin to pull inward behind the spade. During testing of full sized aircraft I have noticed, as have others, that when this condition occurs sometimes the spade wants to "dig in" and we call that snatching because the stick wants to pull out of your hand or stick in place. In that testing this phenomenon has not been global with some planes doing and others not with the same spade configuration or closely the same.
Online Trostle
« Reply #17 on: November 19, 2021, 08:43:25 AM »
Interesting comment by someone who probably has not seen Howard's airplanes.  He has an almost unique method for flap construction with carbon tubes.  His flaps are probably the "stiffest" you will find on a control line stunt model.  (I would not doubt that Paul uses the same method.)
Offline Mark wood
« Reply #18 on: November 19, 2021, 09:40:28 AM »
My interpretation was different referring to the the hinges. Torsionally stiff is a good thing but the flaps on the SV don't appear to twist much as seen in the videos.  The design I am working on will more than likely use D tube LE on the flaps similar to a modern FF stabilizer. It's fairly easy since I am already in possession of the necessary forms and materials.
Offline Mark wood
« Reply #19 on: November 19, 2021, 09:44:35 AM »
Here's an analogy of the impact of adding spades. Without spades the steering is like driving a truck. With spades the steering like driving a Camero. The capability to make the steering like an F1 is there. That is in the realm of hinge line offset.
« Reply #20 on: November 19, 2021, 03:18:27 PM »
Cool video.  It was interesting to see the flow separation at the wing root.  Maybe we should festoon that area with VGs.
« Reply #21 on: November 19, 2021, 03:38:59 PM »
Did you have trouble locking out of corners?  I measure, at least I think I measure the backpressure on the controls to nail my exits.  Sort of like letting the steering wheel slide as you come out of a turn.  Have to ask my subconscious about it.  Do you loose the feel?  I am assuming you don't loose tension.
Offline Mark wood
« Reply #22 on: November 19, 2021, 03:58:00 PM »
I'm considering making some and adding them to my tests, which I actually think translates to planning on but wasn't going to mention the intent until after I had some data in hand. I think it would be interesting and worth the effort. The intersection vortex is what fillets are used to counter but it's worth trying VGs just to see if they can make an impact. The trouble is, I feel, the vortex starts at the LE juncture and VGs would simply add energy to it. One way to find out.
I need to find a better small yarn. The 280 Denier thread didn't hold up to the abuse but early on you could see them swirl in the vortex on the spade which made me really happy to see. In the past I only had anecdotal confirmation of the flow pattern by the dust impingement witness marks on the 4/4 spades.
Offline Mark wood
« Reply #23 on: November 19, 2021, 04:23:21 PM »
I'm not sure what locking out the corners means. The control moments are lower which means it has power steering of sorts. Locking out sounds like what we generally call snatching as in sticking at the extreme or pulling. During testing I have or one of the folks I have worked with has experienced these effects. In the SV current configuration the control forces seem to be linear but about 1/3 - 1/2 the baseline. I plane on going larger spades for testing.
Make the spades large enough and the control forces will go away and eventually reverse. The interesting element to the flapped CL airplane is the elevator provides some moment also so if the flaps get to a zero point there will remain some centering from the elevator. If you have followed some of the efforts I have going in terms of bellcranks and such you'll find I have centering cranks in my arsenal for this reason. As Howard found with the geared tabs these treatments tend to reduce the breakout forces around neutral, those are how we feel neutral.
Leo Laundeslager, he was the guys who mostly started this whole spade thing, worked really hard to make a spade that took the control moment away but preserved the centering breakout forces. He never fully succeeded at that. What he had was a trailing surface hinged to the rear of a delta spade and was allowed to float around neutral and it caught in around 10 degrees deflection and started helping.  Photo attached but it is difficult to understand it's function.
My current effort on the spades was simply a demonstration of their functionality. They are a bolt on option. Once this beast was let out though, some limitation should be determined. For science. Since I'm here might as well explore some.
Offline Mark wood
« Reply #24 on: November 19, 2021, 04:36:22 PM »
Line tension above is "normal" as in not a lot. Without the spades, I could not make the square corner at the very top of the circle. It didn't show in the video very well but the corners directly overhead are as tight as the ones 8 feet off the ground. It's not likely that more spades will improve the corner tightness only the ability to have more control with lighter tension which is what the overhead demonstration is showing. Think diamond eight. Enter a reverse triangle loop with a 60 degree pull, 120 degree pull to inverted level at 45 degree azimuth, push 120 degrees to complementary 60 angle to the apex of the sphere, push down 120 degrees to the 45, push to level pull to the 60 and then to level.
« Reply #25 on: November 19, 2021, 05:40:01 PM »
Please do that away from the crowd! LL~
My "Why Not" is the overhead cloverleaf.  I just think it would be cool from the outside.  A square clover would be cool too.
Is there any loss of "feel"?  I "finger fly" and the control pressure through the corners tells me when it has finished turning.  Less is not necessarily bad, inconsistent would be.
Offline Mark wood
« Reply #26 on: November 19, 2021, 10:02:05 PM »
The answer to that one is the question of the wind. Slack lines are slack lines and there is a point where the control is gone. In a calm wind it probably isn't a problem. The real problem is keeping track of the geometry and not getting lost. Part of the tricks I've done with the SV on spades are square bottom loop round top and round bottom square tops. Not really that spectacular as my non flapped airplane will fly them as well, just not as sharply. An overhead clover isn't any different than a overhead eight with more sides.
« Reply #27 on: November 20, 2021, 11:19:24 AM »
T An overhead clover isn't any different than a overhead eight with more sides.
Try one without moving!
As to the Feel, I was more concerned with the lower altitude squares.  As I am coming out of a corner it is the feel through the handle that tells me when the plane is completing the corner and it is time to lock the flat.  I wouldn't want to lose that.
Offline Mark wood
« Reply #28 on: November 20, 2021, 12:47:58 PM »
One of the pluses over using offset hinges is the ability to tune the forces. If you were to incorporate spades, they can be made larger or smaller to decrease or increase the feel as desired. Another trim capability in other words.
Offline Mark wood
« Reply #29 on: November 28, 2021, 06:13:13 PM »
I made a few flights today with VGs added to the wings at the 8%-10% position. The video shows some improvement in the flow. See what you think.
« Reply #30 on: November 28, 2021, 06:33:59 PM »
Leave all your taped yarn in place.
Remove that thing.
Do whatever you have to do to counter balance the flaps and you might as well do the elevator while your at it.
See what this accomplishes.
Offline Mark wood
« Reply #31 on: November 28, 2021, 09:12:33 PM »
Remove that thing.
To what thing is it you refer? The spades won't leave. The positive impact is too good. They may and probably will change size. I made new struts with a more durable material specifically so they can stay. Ultimately the next airplane will use offset hinges and may need the use of spades as well. There is a level of too little hinge moment leaving the control forces less than that of a combat plane.
 The yarns are a test to see where the transition happens and separation on the flaps occur. That answer is also determined. For that the yarns are likely finished doing what I set out to learn and will likely leave.
« Reply #32 on: November 29, 2021, 06:32:15 AM »
"Thing" being your "spades"
Then just balance your control surfaces. That alone should make an improvement.
« Reply #33 on: November 29, 2021, 07:59:21 AM »
    Why don't you explain why??
Offline Mark wood
« Reply #34 on: November 29, 2021, 11:22:33 AM »
As in add weight in front of the hinge line? Care to elaborate how that might be possible on a plane hinge surface hinged at it's very forward edge?
« Reply #35 on: November 29, 2021, 11:47:15 AM »
Gold-leading-edge spades
Offline Mark wood
« Reply #36 on: November 29, 2021, 12:04:37 PM »
Or depleated uranium maybe.
« Reply #37 on: November 29, 2021, 12:46:16 PM »
Yes, to balance a control surface, the proper weight must be added forward of the hinge line AND, to do this correctly the control surface should be removed and "jig" set up so there's little resistance with all the hinges.
An "arm" must be added with weight possibly at the tip but doesn't have to be. The farther the arm is from the hinge line, the less weight is needed for balance.
Google "balanced control surface on an aircraft."
Simple science and aerodynamics 101.
« Reply #38 on: November 29, 2021, 01:47:06 PM »
Not simple for me.  It’s aerodynamics 3-something. What will that get us?  Few control line models have a flutter problem. I have wondered whether balancing our control systems could help us fly more accurately. I suspect it’s not worth the weight, but I haven’t put any effort into finding out. I’d be interested in seeing some ciphering.
Edited to reduce assholicity.
« Last Edit: November 29, 2021, 03:06:50 PM by Howard Rush »
Offline Mark wood
« Reply #39 on: November 29, 2021, 02:59:10 PM »
As Howard says, there is more to it than simple mass balance. The spades actually do add mass in front of the hinge in fact on some of the 4/4 airplanes we also add lead to the retaining plate for the spade itself. On my laser there was 1 1/2 pounds of lead along with the spade 2 1/4 pounds total. That was there to counter a wing flutter issue the Lasers have and Dr Tolve sorted out.  Kermit Weeks recently posted a video of Tolve conducting a ground vibration test of the Gee Bee R1 of his in order to determine the flutter characteristics of he R1. He pretty much determined the cause of the original airplanes' demise.
There is some hinge moment created by the mass of the surface that much is true but it is not that much with these very light surfaces. Flutter is like a spring mass system where the spring comes from the aerodynamic force generated by the displacement of the surface. Of course in the case of being around the hinge it becomes the rotational version and it's torque versus moment of inertia. When the center of mass is at the hinge, the opportunity for flutter is eliminated. This same spring force which is caused by the surface displacement is what the spades offset. End of the day, mass balancing will not create the same hinge moment reduction as do the spades.
If you wish, you could compare the spade with a horn balance which is most often located at the end of the wing.  Another way is to offset the hinge further back in to the surface which will be the approach of the new airplane. Some airplanes like the Cessna Citations use both a balance horn and offset hinge. If you are interested, I can provide tons of good literature on the subject. Bottom line is mass balancing is for flutter prevention while balance horns and spades are for moment reduction aka control stick force reduction.
I have not measured the force at the handle. Perhaps a creative EE would step in and help but I can provide a qualitative analysis. Unfortunately I have not been able to convince any of my local other pilots to fly the A-B test on my airplane despite my most insistent efforts. So my estimate is that the no spade installation is at something like 5 pounds differential up to down. I have no clue what it really is, maybe it's 2 but for discussion use I'll say 5 pounds. Adding just the strut with the retaining plate which has about 1 square inch surface area changes that a bit noticeably to about 4 - 4 1/4 pounds differential. Adding the spades brings that down to around 2 - 2.5 pounds differential. I am planning on taking the total area of the plates up to 20 (10 each) square inches and hope that they remain linear. If not the impact is that I go back to the initial or intermediate state. Here's one point of caution I have to remind myself of is that elevator is a contributor also and I will not shoot for the zero moment point and solely the plateau zone where the hinge moment of the flap nears zero.
I realize that your objection has nothing to do with the flying or handling qualities and everything to do with the aesthetics.  Personally, I don't care what it looks like as long as it works well.. I am a performance oriented individual and I'm not a lemming. I am both scientist and engineer, therefore I am always in a research and development mode. I make these inputs, even if they aren't received well as I think they are interesting. From the PMs I get, I won't stop. The airplane these are flying on will continue to have the spades installed for it's foreseeable future.  They are that good of a change and I'm going tell you I have tried dozens of the you gotta try this'... Most are "meh". There's  simple way to prove me wrong, put some on your airplane and try it. I'll even help you.
Offline Matt Colan
« Reply #40 on: November 29, 2021, 03:05:38 PM »
Dave de-tailed elevators with counter balances in his de-tails article for stunt news. They don’t work as you think they would
« Reply #41 on: November 29, 2021, 03:08:45 PM »
Not simple for me.  It’s aerodynamics 3-something. What will that get us?  Few control line models have a flutter problem. I have wondered whether balancing our control systems could help us fly more accurately. I suspect it’s not worth the weight, but I haven’t put any effort into finding out. I’d be interested in seeing some ciphering, but not some imposter waving his arms, balanced or not.
One of you guys, maybe even a few, claim you have single wired control surfaces which are removable. Unlikely, but it's been repeated many times.
So, how easy is this. Remove the control surfaces and balance the things. If the model flies without improvement continue to troll, bully and treat me like I don't know anything, you will anyway.  LL~
If this makes an improvement, no one will hear about it because it probably won't be shared.
Read about balanced control surfaces. I just looked, there's plenty of info on line.
Offline Matt Colan
« Reply #42 on: November 29, 2021, 03:13:55 PM »
Here is Dave’s article with a removable tail, balanced and done scientifically
https://stunthanger.com/smf/open-forum/copy-of-the-david-fitzgerald-article-'de-tails'-from-the-marapr-98-stunt-news/msg511851/#msg511851
I don’t have much to contribute to the discussion other than I think aerodynamic devices look cool on airplanes, kinda like the modern F1 cars, and have enough of a basic knowledge of aerodynamics to understand how the spades work and it seems like they are. The talks have been fascinating!
Offline Mark wood
« Reply #43 on: November 29, 2021, 03:27:25 PM »
It's clear that you haven't understood what spades do. Nothing you read about mass balancing control surfaces tell you that mass balancing reduces the stick force gradient. Mass balancing is all about flutter reduction. On the models the surface is very light and the need for mass balance isn't there generally. There are two moments on the hinge of a surface. Mass and aerodynamic. One is what the mass balance is about. The other, aerodynamic hinge moment can interact with the mass balance and cause flutter. We are not talking about that. My hinges are pinned with a single pin and pulling that pin would allow the surface to be put on a balance fixture as are 99.5% of the model airplanes. The trouble is that the surface will hang vertically form the hinge as the hinge is at the furthest forward edge of the surface. There is physically no place in front of the hinge to add weight without making some sort of extension like the very "thing" you suggested removing. Look at the horizontal of the P38 Lightening. Those little bomb looking things on the struts projecting out like the "thing", those are weights. They are there to prevent flutter and were a afterthought much like why we use spades except with spade we are after the other hinge moment reduction, the aerodynamic one.
Photo added
« Last Edit: November 29, 2021, 04:40:17 PM by Mark wood »
Offline Mark wood
« Reply #44 on: November 29, 2021, 04:32:50 PM »
Sorry, I just couldn't let it be. So I took one of my non single wire hinged surfaces and hung it by the single hinge pin wires to see how much lead it would take on the wing side of the hinge to balance it. And I compared it with the spade strut I took off of the SV in order to replace it with a more durable material strut for a permanent installation. The result is that it took  730 grains ( 47.3 gr) just in front of the hinge line to balance. I have no clue where this will go, maybe cut a big hole in the TE. I could save some weight and install some of those gaudy looking spade struts for 103 grains (6.7 gr)  and get the aero benefit too.
Note the spade comes fairly close to balancing the flap. Granted this one is a small flap, however....
Offline Mark wood
« Reply #45 on: November 29, 2021, 05:03:43 PM »
Just for the record, in case it comes to a debate, here is an aileron being mass balanced with a spade in 2013 for my 4/4 scale Laser 200. In this state the aileron is in the no surface flutter state. However, due to the torsional properties of the wing, the horn on the end has to have more mass added to stop the aileron from responding to a torsional bending mode the wing might have. That's what I am in the middle of doing in this photo, making the lead weight.
« Reply #46 on: November 29, 2021, 06:28:07 PM »
   I just have to ask, what makes you think that this hasn't been thought of, tried, and rejected by people who actually fly their models in competition? I think you should quit while you are behind, sit back, open up a can of STFU and follow along quietly. Don't ruin it for the rest of us, PLEASE??!!
« Reply #47 on: November 29, 2021, 08:05:19 PM »
   So now you are calling the rest of us liars? When anyone can easily look and check on it? Many people on this forum (you know, the ones that actually fly model airplanes with other people) have seen the system as implemented and seen flaps and/or elevators removed. It was on published plans for 30 years ago.
   No one has ever trolled or bullied you, because, to be honest, the ideal situation is that you go away completely. Since you don't know the meaning, "trolling" means to post in such a way that people are goaded into responding. It is what *you* do incessantly. The rest of us would be very happy if you never posted again, which is about as far away from trolling as could be imagined.
  You *don't* know anything and you have never accomplished even the first steps in this event. The rankest beginner who just managed to fly their CG Wizard for a full tank is infinitely more accomplished than you are and more worthy of our time.
   Many people, almost all of them in fact, have told everyone time and time again exactly why they did something, exactly how they think it works, and how you can do it yourself. This includes multiple national champions and world champions. There are no secrets.
       You, naturally, ignore it all because you can't admit your own astounding ignorance, and the fact that you are so busy gassing on about your own nonsense that you don't hear it.
Offline Mark wood
« Reply #48 on: November 29, 2021, 08:43:59 PM »
Well, this one went south...  8)
« Reply #49 on: November 29, 2021, 09:17:47 PM »
Lasted longer than most.  It was getting somewhere too.
