CLICK HERE--><--CLICK HERE
XF-91 Wing
Started by George Fruhling, May 16, 2023, 08:38:23 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
George Fruhling
The Republic XF-91 Had swept wings that flared out with the cord widest at the tip. I wonder how that would work with a C/L stunt plane with straight wing.
Dave Hull
You might not like it in gusty or turbulent conditions
M Spencer
#2
Our REJECT peacemaker , The Aeromudler one , had too quick cut rejects . SOMETIMES . Dont think we were sucked in more than once ! .
However , with a no nitrate Yin Yan  , if you whipped it  hugely for five laps , clibing in the last two , then dived -
You Might get a loop. If you kept whipping !
If you didnt you didnt .
The Field was three football fields , with 80 foot 45 degree banks , between levels . ( all remodelled now  >:( )
A outside loop from level , it'd PULL Somewhat . Unexpectedly . On a good day you might get it back up to ' ground level ' again .
At least once or twice I DID .
SO , Dont use a Yin Yan ! other than that , im not sure Its entirely Relevant ,  HOWEVER . Some current dwelling on WINGS might help .
The old YARDSTICK undercarrage mounts . A PINE Stick across , to ' catch the loads ' .
You might figure the Center of Area , on a side . And run a fancy Caron Backed or somesuch , cross spar . Anchored securely in the fuselage .
This'd sort of ' get ' the thing evenerish stressed - and you can put the wings on the other way round , if it dosnt work backward !  S?P  LL~
ACTUALLY , This could look darned good .
Hunt Thunderchiefish or that blokes MURAT ish , if you went sorta scale . STYLE .
https://outerzone.co.uk/plan_details.asp?ID=6183
George Fruhling
You lost me there, Air Ministry.  Anyway, I was thinking of a straight, not swept wing design.  You a big Devo fan. "Whip it, whip it good!"   ;D
M Spencer
Yin Yans and solid foam wing ' flite steaks ' ( peacemaker ) have a performance that may not be described as invigorateing .
The FOAM WINGS they cut TOO QUICK sagged ( the cutting wire ) in the middle . So gave the effect you mentioned . Amougst others .  n~
IF you had a say 1 1/2 x 3/8 STRONG ' stick , going across say 30 inches or three feet , with slip on wings . Ply Ribs at root and spar end - or a box spar sliding over the ' stick ' ,
You could have slide on detachable wings , and then , if the thick tips  roll it 90 degrees when you hit your slipstream , offsett . You can put em on normal , later .
After youve explored all the avenues of performance . IGNORE the Foam Peacemaker , Wasnt a ' Comp. ship . We built better before we met that lot !
Youll never know till you try it . A X in -planform - winged thing , closed across'd have very wide chord way out . !
Was a British ' Martin Baker maybe , Design sketch of something akin to youre idea . NOT THIS .
maybe in here or there . w t h .  >:(
coulda beena Saunders Roe rocket plane - Think it was never built - theyed draw myrid concepts for evaluation . AS Control Lines TEATHERED , you can try stuff inapropriate to free flight !
Wake in the middle should be less than conventional ships , maybe giving it sharp precise controls .  ;D
FLOYD CARTER
It might work.  But it would be ugly as hell.
92 years, but still going
john e. holliday
Really, if that had worked we would have more develop of the design. D>K
M Spencer
But it Wasnt Control Line ! .  VD~  S?P
With lucky box slots and removable wings , he could try them BOTH WAYS , for a DIRECT Comparison .
George Fruhling
Quote from: john e. holliday on May 20, 2023, 07:33:16 PM
In a video about the XF-91, it was said the plane performed fairly well. The design was supposed to prevent or minimize  wingtip stalls.  Now if that's an issue with C/L, not sure. Seen video of RC planes crashing from tip stall.
