  • June 27, 2025, 09:58:34 AM
Author Topic: Pictures  (Read 2813 times)
Pictures
« on: December 20, 2007, 10:02:24 PM »
any one know how to pull the little pictures of my little aeroplanes of the Barton thingo.  ? ?
under "pictures " - 'aerobatics '. to put here to keep you lot ammused  ( particularly Mr Adaminson of high A R )
and place here also . please , etc .
we will avoid the computor lecture .
These wonderous contrivances might cheer you miserable lot up for CHRISTMASS .
If not theyll be plenty to whinge about , which should keep you going ; AKA ,
critical analysis , or ' wot the hecks that , etc, etc .
Re: Pictures
« Reply #1 on: December 22, 2007, 07:28:14 PM »
HI Matthew,
I cannot find where your pictures are already posted. (??)  We could post them here no problem.
Re: Pictures
« Reply #2 on: December 23, 2007, 08:09:56 PM »
Did they turn up in your email ? programmes 'copy shop ' .
« Last Edit: January 06, 2008, 06:37:21 PM by Matthew Spencer »
Offline Keith Polzin
Re: Pictures
« Reply #3 on: January 14, 2008, 11:30:46 PM »
  Hey, if you supply link to pictures, I will post them, ok?   Keith
Re: Pictures
« Reply #4 on: January 18, 2008, 05:20:05 PM »
 Now ,Bills got the pictures , dennis has got the pictures , and Kieths got the pictures . Via E'mail .
 Now my opinion of computer assisted design ,matches the appearance of the pictures . !
 One step forward and ten steps back . To keep it plight .It would be a gross exageration to say somethings going on in this particular instance . As its fairly evient two tenths of five eigths of stuff all (as they used to say ) has gone on . As its not B..... there , or conspicuous by its absence . to be politer .
The wonders of modern tecnology .
Re: Pictures
« Reply #5 on: January 18, 2008, 06:01:40 PM »
Matt noooo oone cann figuuure out whattt yooou are speakkking to. yoU donl''tt make sEnce. I lIKe you pictures just fine. iF thEy are as gooooooog as youe rrr wrighttinG evryOONNE wil go to. yEp it is haRd to stop.Ge this is Fast.
Re: Pictures
« Reply #6 on: January 19, 2008, 06:55:02 AM »
Matthew, I cannot speak for the others, but I have simply not had the time to convert the pictures, and host them to my site.  If there is a simple *one click* operation that would make this all happen for me, I would have already had it done.
Re: Pictures
« Reply #7 on: January 19, 2008, 04:55:36 PM »
  We ?--  Schoo; fish ! .  Must be the flouride in the water . (softens the brain) . These city slickers ,
  Testing , 1/ 2/ 3/.
 Now unfortunately I detest computors . But eventually onell get these little pictures to materialise here ,
 Its not really my loss if they dont .Though the lack of flash finishes will disapoint the superficial folk.the
TOPIC is stunt DESIGN .(not ones evil designs , plotting / schemeing etc..
Think outside the square . - get a round tuit .
(possibly should be transfered to (attempts ) at humour at this stage .
Re: Pictures
« Reply #8 on: January 20, 2008, 06:22:45 AM »
Mat sent me his pictures but it took him three emails to tell me how smart he is and how brain dim I am. It took me all of 30 seconds to put his pictures here. Why not just ask for help.You might get it.
Offline Arch Adamisin
Re: Pictures
« Reply #9 on: January 20, 2008, 06:39:27 AM »
That will certainly qualify as a high aspect ratio design. What are the specifics? How does it fly?
The first photo does seem to have a thin wing. Maybe just the way the photo looks.
And Ed, thanks for helping Matt out with his photos.
     Arch
Re: Pictures
« Reply #10 on: January 20, 2008, 04:44:54 PM »
 Right . Help. What id like done is planting trees in the deserts of the planet , before we all shrivel up.
 If theres enough reaforestation 'one' wont have to suck allthe water out of the aquafiers,   So;
 Ed , Id actually said your posts apear  rational .  Which is 'kiwi-speak'  stating the obvious .
The head on shot is an MC 72 from back in 2000 , K&B torpedo .40. Probably the easiest plane (of over 100 ) ive flown to do an accurate pattern with .Though if the winds gusty it catches the floats a little,giving a bit of a weaver. misspellings probably correct . A new word ?
16 % airfoil . but its a Sesqui plane ?
57 span and Oz.  Would build one identical scaled for a .60 too.
The greeny things 72 " span . Will give a bit of a bounce if you hit full up hard out of a wingover or hopurglass, if you dont get the timing right.(about 50% which aint bad for 71 Oz and 630 Sq. In wing area.),if I leave out the yards of spruce and epoxy, 1800 grammes will be not to difficult Intresting to fly in a 20 Kt wind ,Being 11 stone with the A/C weighing 71 Oz. ,
« Last Edit: January 23, 2008, 03:24:07 PM by Matthew Spencer »
Re: Pictures
« Reply #11 on: January 23, 2008, 02:23:32 AM »
   Arf arf arf.
Re: Pictures
« Reply #12 on: April 07, 2008, 12:03:54 AM »
     Arch
     Having just flown a Cardinal and a Fancherised twister , or was it the other way ? ,
     Its not bad , though apparently your only supposed to glide one lap. Where if you pull it through the cut , itl
     do two.
     Will get the Email cafe to reduce the other pics , one day .
     Prefer the Mewgull and DeH 88 to anything ive flown. Comparable to a Norton Commando set up tight with a KR 76 front tyre.
     Have to watch were your going ,but very accurate .  Horses for courses ?
Re: Pictures
« Reply #13 on: April 07, 2008, 11:44:04 AM »
Matt,
My experience with high aspect planes suggests that a bit heavier is better to compensate for the insane amount of lift generated. A bit of weight and drag are not a bad thing.
