  • July 07, 2025, 05:22:07 AM
Author Topic: P-47 Warbird drawings  (Read 1708 times)
« on: January 12, 2010, 03:36:48 PM »
The drawings are finished and really came out good! They have the makings of four different Thunderbolts on them plus a cool way to build elliptical wings. I will get copies run off tomorrow. Ordered 20 shipping tubes from the PO today so there may be a few days delay shipping after I run out of the present stash.
Don
Offline Douglas Ames
Re: P-47 Warbird drawings
« Reply #1 on: January 12, 2010, 05:39:36 PM »
Don,
I bought your Corsair plans a while ago and hand cut the ribs and did a mock-up of the wing to get an idea of the span and mechanisims. I ended up with a gross incidence problem between the center rib and the crook where the wing begins to have dihedral. ENTIRELY MY FAULT as I traced the problem to me hand cutting the spar cutouts inaccurately. The outbd. panels turned out fine.
Short of a Laser cut set of ribs (Day dreaming...), what's the best way to cut the spar cuts out accurately? I thought of a rib center line and a verticle line 90 deg. to that? Can I some how stack these and cut them all at once (table saw)? Not much experience "scratch-building" large models.
AMA 656546
« Reply #2 on: January 12, 2010, 06:46:02 PM »
Doug- Wish I had some magic answer but all I can say is to be very accurate when cutting the parts. You did pick a lulu to work on.
Don
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: January 15, 2010, 09:09:03 AM »
Don: Put me down for a P-47 plan. I think you have my info. THANKS!  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #4 on: January 15, 2010, 07:02:34 PM »
About a dozen P-47 drawings are going to go out as soon as I get shipping boxes from the PO. Hopefully early next week as I am going skiing the following week! When I get back,  will begin preliminary work on the Mustang.
Don
« Reply #5 on: January 22, 2010, 06:04:59 PM »
Shipping boxes arrived today, Fri. the 21st. Boxes packed and all orders will go to the PO tomorrow. Then we are off to skiing for a week in Colorado. (If we can get there!!)
Don
Offline Bill Hummel
« Reply #6 on: January 28, 2010, 05:21:35 PM »
Don, plans arrived, beautiful job on the P-47 drawings. Thanks for your efforts!
ama 72090
Offline Ron Merrill
« Reply #7 on: January 29, 2010, 08:55:25 AM »
Don, check is in the mail. Ron.
