  • June 16, 2025, 03:33:47 PM
Author Topic: New Tip Weight Material  (Read 2487 times)
« on: May 06, 2008, 10:39:49 AM »
I just found a great idea for making tip weights, especially for the equal panel length fans and the scale-like stunters.  Since lead is so heavy, use aluminum instead!!
Offline Jim Oliver
Re: New Tip Weight Material
« Reply #1 on: May 06, 2008, 12:10:22 PM »
Wow---what a great idea!!!
Would it work for nose or tail weights???  No telling how much that will save........ S?P H^^
Cheers,
Jim
Jim Oliver
AMA 18475
Offline Steven Kientz
« Reply #2 on: May 06, 2008, 02:01:01 PM »
Phil
 If you use it on combat models and paint it to look like lead the other contestants could be fooled into using too much tipwt. You could win on air time alone.
Steve Kientz
AMA 855912
« Reply #3 on: May 06, 2008, 04:18:21 PM »
Uh, yea. Sure.
Offline Nils
« Reply #4 on: May 06, 2008, 09:39:15 PM »
Leave out the tipweight entirely. Fill the inner wing panel with helium instead.
Offline Roger Vizioli
  • CLiner
« Reply #5 on: May 07, 2008, 05:37:58 AM »
Nah, you have to put it in a sealed tip weight box, Helium will find any leak path and leak out!  LL~
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline don Burke
« Reply #6 on: May 12, 2008, 10:21:18 AM »
lead is roughly 2 lb/cubic inch, alum about .1.  So 20 times the volume of alum needed to equal lead.  A 1/4 ounce alum tip wt would be a 5/8 square bar about 2" long.  Quite a blob, but easily installed inside a PA or Combat wing.
don Burke AMA 843
Menifee, CA
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #7 on: May 12, 2008, 03:35:32 PM »
If you use aluminum the resolution for fine tuning tip weight would be much higher.
Offline Leo Mehl
« Reply #8 on: May 21, 2008, 02:15:32 PM »
Gee, I thought the tip weight went on the inboard wing!
Online Howard Rush
« Reply #9 on: May 25, 2008, 03:10:19 AM »
The Jive Combat Team uses gold.
« Reply #10 on: May 25, 2008, 02:44:49 PM »
Howard...what does the Jive Stunt Team use for tipweight?  LL~ Steve
Offline Stan Bidowski
    • Winnipeg Perfect Circle Flying Club
« Reply #11 on: May 26, 2008, 07:10:36 AM »
Everbody knows that a 1/2A plane usually uses 2 pennies for tip weight.  So for bigger planes one can
use five dollar bills.  If a couple of those doesn't work, take em out and use 10 dollar bills, or 20's etc....
I tried blobs for tip weight too, but the problem is the whole plane will turn into a blob.
If you want to save weight for the tip weight, use water.  Eventually it will evaporate, and will weigh
nothing.  Bottled water is probably better.  But money seems to work better, although it's value
changes throughout the day.
  Has anyone tried diamonds?  Is it safe? Is it safe?
Stan Bidowski
MAAC 17167
