  • June 13, 2025, 10:52:52 PM
Author Topic: Moulded fuselages  (Read 4440 times)
Offline Geoff Goodworth
Moulded fuselages
« on: September 27, 2021, 01:18:34 AM »
I'm currently detailing a design with a moulded fuselage and the engine centreline, wing and stabliser all on the one line.
Al Rabe, Chris Cox and Paul Walker all split their moulds vertically but for a design with the wing at mid-fuselage, it seems to me that splitting on the horizontal centre line then cutting a bit out of upper and lower moulds to mount the wing would be easier.
Does anybody experienced with moulded fuselages think there is a problem with this approach?
Offline Robert Whitley
Re: Moulded fuselages
« Reply #1 on: September 27, 2021, 10:54:24 AM »
If you watch his videos Al built his later models essentially top down due to his using the pocket hole fuselage former jig system.
It looks like a very good way to do it.
Offline James Mills
« Reply #2 on: October 03, 2021, 09:40:22 PM »
Joe Daly did a write up in Model Aviation not to long back with a similar technique, good read.
James
AMA 491167
