CLICK HERE--><--CLICK HERE
Ted's Tucker Special Ballast Experiment
Started by Kim Mortimore, September 28, 2013, 12:25:18 PM
Previous topic - Next topic
0 Members and 3 Guests are viewing this topic.
Scott Richlen
QuoteHold on - WHAT!!!??? "Brett and Ted" are not and have not "recommended" anything like that.
Consider what I wrote a "first draft".   ;D
I went back and fixed it.
Mike Alimov
Scott, I once had a Tucker Special at 48 oz and powered by a stock OS40FP, spinning APC 10.5-4.5 prop.
It flew very well (until a horn failed...), and did not lack in power at all.
Good luck with your build - it is a beautiful airplane, and one of my favorites.
P.S. definitely make sure at least one of the horns is adjustable in a wide range
Tim Just
Brett,
Regarding your recommendation to add 8 oz. (actually .249 slug) to a stunt
plane, should I distribute the added mass to preserve the existing principal
inertial axes, or should I take advantage of the ability to skew them?  If
the latter, which way and what should I do to retrim the airplane?  Also,
adding .249 slug to my 2.207-slug airplane will increase the natural
frequency of the lines by 5.5%.  I'm up against the 70--foot max line
length, so I can't make the lines longer to compensate.  Should I look for
.019"-diameter lines, rather than .0i8", or is it worth the bother?
Respectfully,
Tim Just
Scott Richlen
QuoteP.S. definitely make sure at least one of the horns is adjustable in a wide range
Thanks Mike!  Good idea on making the horn adjustable.
Any pictures of your Tucker Special you can post?  See you at Brodaks?
Brett Buck
The problem here is that this is yet another bit of what I thought was good and useful information, both about the Almighty Ounce, and about how to address trim issues as they exist, not as a hypothetical. But like several other things, it has now morphed into something unrecognizable, a bad "recommendation" that I never made, being attributed to me and carrying whatever influence I might have about it. Several other examples:
Bellcrank - bellcrank design provided, extremely bad copies made, Chris Rud's airplane crashed when bad copy collaped, after already having to have been repaired. "Brett Buck Bellcrank Failed!"
OS-20FP - very extensive testing done over period years, intricate and 100% complete directions given (which could not be simpler). People "try it", "It doesn't work!!" including hostile and foul-mouthed emails about how I "scammed" everyone and I was "Anti-American". Inquire further, ST spraybar and tongue muffler, Top Flite 10-6.
Tail incidence - fairly careful experiements over years, suggest that there is tolerance in the positive direction and zero in the negative direction, and maybe you should shade it just enough to make sure you don't have any negative, 1/4 degree (.016" over a typical stab chord), and use a airfoiled tail.  "It doesn't work! My airplane is junk! And it's your fault!" Someone built in 2 degrees with a flat stab. My fault, somehow.
Tucker Special - as above, we take a super-light copy with a powerful modern engine and no way to adjust the controls, it flys *vastly better* with 1/2 lb of ballast, it's not close. Now we are "recommending" building a 4 lb model with an OS-35S
PA Needle Valve counterbore - barely mentioned but I guarantee multiple people have tried it and ruined their spraybar by drilling out the seat (just like David did on the first try)
   There are several other examples but this illustrates the point.
   I am not blaming the people who went off the rails, Scott least of all, he's a good guy and pretty knowledgable. But even he has somehow taken the information and wildly misinterpreted it, fortunately before he has seriously committed himself (unlike many of the examples above).  In other examples, these misinterpretations have results in crashes, year-long builds that failed miserably, damaged engines, etc.
    I am torn - I thought I was providing a service and helping people, relaying a lot of these things I (and others) have discovered over the years, and only those I have a very clear working theory and multiple examples of success. But the result is frequently serious harm/cost/wasted time. I think I explain things pretty well, and in cases of direct recommendations, I am very careful to supply very detailed instructions. I am noted, professionally, as a very good technical writer. But despite all that, these disastrous problems keep happening.
   So I don't know how to proceed, maybe what I am trying to do is causing more harm than good.
Brett Buck
Quote from: Mike Alimov on November 14, 2024, 03:18:23 PM
   Using a 40FP and using a OS-35S are two wildly different things, of course.
Howard Rush
I think you're not charging enough for consultation.  Consider how accurately your day-job advice is taken compared to your advice here.  My vortex generator sales dropped way off after I got my own printer and started giving them away.
Scott Richlen
QuoteNow we are "recommending" building a 4 lb model with an OS-35S
Now Brett, my 64 ounce models have either ST-60s or PA-61s in them.  You must have missed the lines where I spoke of using an LA-46 instead of the 35-S in the Tucker, particularly if it weighed (deliberately) around 46 ounces (which you and Ted did not recommend!)  ;D
I have an FP-40 but they do not seem to run as stabily as the LA-46, although much better than the FP-35.  I re-timed one of my FP-40s (per the Bob Hunt video where his RC buddy (drawing a blank on his name) showed how to tear down and re-time it.)  It really ran great after that, but then I gave it away to one of my flying buddies.
