Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 11, 2025, 04:30:33 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
Just how big an engine......
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Just how big an engine...... (Read 1293 times)
jim gilmore
Trade Count:
0
Admiral
on:
July 16, 2009, 06:39:36 PM »
Ok well here is where my question gets a bit hazy. If I go with an .09 or .10 that should be close to the right size. If I go with a .15 it might be a bit large but I'm guessing that by prop and venturi selection it can be run at what ever speed needed to fly The model at the right speed. The weight difference is less than an ounce I belive.
Logged
Geoff Goodworth
Trade Count:
0
Captain
Re: Just how big an engine......
Reply #1 on:
July 17, 2009, 05:30:57 AM »
Jim
Which model? If it is the Akro, 1oz in the nose requires 2.2oz at the tail to balance. 3+oz of extra weight may make the wing loading pretty high.
Cheers, Geoff
Logged
jim gilmore
Trade Count:
0
Admiral
Reply #2 on:
July 17, 2009, 08:05:38 AM »
Aside from adding weight. Couldn't wing position be moved to adjust the balance within reason. I'm not talking about drastic changes here. And I know weight considerations are an issue. I'm not aiming to build a rock on a string. Though I could end up with one. I'm just trying to find ouf if a slightly larger engine would be able to slowed down/or controlled to fly at a slower speed through the use of prop and venturi size.
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
Jump to:
=> Stunt design
