  • July 14, 2025, 02:37:36 PM
Author Topic: Is bigger still better?  (Read 39796 times)
Offline Mike Alimov
« on: August 06, 2018, 10:28:59 AM »
I don't think anyone will dispute the fact that if there is one clear trend in stunt from the '50s-'60s to the modern times, it is the increase in average competitive airplane size (Old Time and Classic notwithstanding, for obvious reasons).  From sub-550 sq.in. wings to 650+ sq.in. wings.  Up to the '90s, the size (wing area, weight, loading) was largely limited by availability of powertrains suitable for stunt.  As power available from the engines grew (Fox 35 -> ST 46 -> ST 60 -> OS 40 VF pipe -> etc...), so did the airplanes.
I don't think anyone will deny that the larger airplanes fly better (of course... properly designed, built, powered, trimmed).  I also don't think that we are limited by power today.  Many combustion engines in the .75 class (piped, 4-stroke) can put out tremendous amount of power, and electrics are only limited by the weight of the battery.  Yet, the growth of the average competitive airplane size seems to have stopped around 650 sq.in. (give or take, and yes there are exceptions).  Why? Is bigger no longer better? Why don't we see planes in the near-800 sq.in. area dominate the circles? Reynolds number no longer works?   ;)
The only explanation I can think of is that with larger airplanes comes more weight and therefore the pull at the handle (physical effort required to fly).  But it seems to be a moderate price to pay for presumably even better presentation than the 650-sq.in size planes.
(p.s. I hope we can keep this discussion purely technical, and not personal or political).
Online Igor Burger
Re: Is bigger still better?
« Reply #1 on: August 06, 2018, 10:41:31 AM »
My Max is smaller version (10%) of its predecessor called Next. :- )) Difference is only in wing area, not the fuselage, it is actually longer in its nose section :- ))
« Reply #2 on: August 06, 2018, 11:06:04 AM »
    I don't even buy the premise, bigger has not been better and the sizes stopped getting larger about 30 years ago. As long as there is a 70' line limitation (and there needs to be, to accommodate the flying sites that have been designed around it for half-a-century), you aren;t going to see larger airplanes. If anything, the trend overall has been downward from upper-600's-700 to 630-660, as we have gotten a grasp on how to control the available power. The larger 750-ish square inch airplanes proved to be a dead end, for the most part. Worth trying, but didn't work out.
Offline Mike Alimov
« Reply #3 on: August 06, 2018, 12:45:07 PM »
Igor and Brett - thank you for your inputs.
Igor - your reply just supported my observation that the planes are not getting any bigger (and even smaller now).  Can you elaborate on why you decided to "downsize"?
Brett - there was no premise in my message, just an observation and a question.  The observation was that for a good while (say, 1950s->1990s), the planes were getting bigger, and flew better, including, and especially, in worse weather conditions.  If there was no benefit from going bigger, most everyone at the NATS would still be flying something like a Nobler derivative, not an Impact/Trivial Pursuit/GEO XL/SV-11 etc derivative.
Then comes the question: why did the size stop increasing beyond +/- 650 sq.in. of wing area?
You mention the 70-ft  line length limitation.  How does this limit us from increasing the linear dimensions of an airplane by a mere ~10" in wing span and even less in fuselage length?  Does it have anything to do with the human visual perception that a larger airplane cannot ascribe the infamous 5-ft radius turn as well as a smaller one? (Even though they are quite capable of it, and not just theoretically, as was shown by Scott Bair and his Stunt Fire).
I'll explain the background to my question.  In support of my 10-yr old who is getting into RC, I recently took him to the local 3D fly-in.  It was then, after watching these guys do some insane 3D about 10 ft off the ground in gusty, turbulent 18-mph winds with their 1/3-scale IMAC-legal Extras running two-cylinder gasoline monsters without so much a twitch, that "bigger is better" phrase came back to my mind.  My kid's 60" foam Apprentice 15e was getting blown backwards relative to the ground when pointed into the wind at full power.
So, why are stunt planes not getting bigger, again?
« Reply #4 on: August 06, 2018, 01:24:43 PM »
Listen to Brett:  70 foot lines.  Assuming that the pilot is adding a couple of feed to the effective diameter, a 54 inch wingspan plane on 70' lines is taking up about 7 1/2 percent of the flying radius with it's wingspan.  That means that the dynamic pressure across the wingspan varies by about 15% -- very roughly, whatever slice of the inner wingtip is lifting one ounce, the same-sized slice of the outer wingtip is lifting 1.15 ounces.  The heavier the plane the bigger it needs to be, and as the wingspan grows the effect just gets worse.
We could go out and buy full-scale aerobatic planes and fly CL stunt with them as long as we could figure out where to fly on 350 foot lines, and how to cope with the increased line tension (I'm thinking a cockpit mounted on a gimbal, with a conventional seat & elevator stick for control.  Should be fun, especially before you figure out how to come out of the wingover with your head pointed up).
Offline Mike Alimov
« Reply #5 on: August 06, 2018, 01:49:26 PM »
Tim, I'll let you try the full-size Extra on 350' lines, let me know how it feels   D>K
I know you're being funny, and I appreciate that.  But seriously, I anticipated the line pull argument, and was not suggesting we fly IMAC-sized birds.  Maybe more like 800 sq.in. of wing at ~ 70 oz.  I've never been so confident in the 17 mph wind as when I flew Strega ARF with Saito 72 at a 75-oz all up weight (and no, I didn't think that ARF is a great flyer, but it deals with wind better than my 650 sq.in 60-oz birds).
I'm not sure I buy the differential lift argument.  It's easy to deal with that by making the outside wing half slightly smaller. But then, read Bob Hunt's Genesis article and how he came to fly equal-panel wings.
« Reply #6 on: August 06, 2018, 02:06:34 PM »
I don't think the line tension is a big part of it.  If it were, guys with great big biceps and lots of flying skill would be winning with big airplanes.
Having been in a position of trying to make systems work where 1% imbalance from side to side is a humongous issue, I think a 15% difference in dynamic pressure* is a big thing.  Sure, you can make the plane asymmetrical to cope with it, but then you end up going down this path where the wings are mismatched by one factor, the flaps by another, then the plane wants to turn in on takeoff and you have to paint zig-zags on the wing so the difference doesn't show, etc., etc.  I'm waiting for someone who knows more than me (well, aside from Brett), but I think there's enough inherent asymmetry for it to be a limiting factor.
* For the non-aerodynamics wonks: dynamic pressure is, roughly, the "flat plate" pressure, i.e., what you feel when you stick your hand out of a car window at highway speeds**.
** Unless you're in the Midwest and it's hailing.  Then you feel pain.
« Reply #7 on: August 06, 2018, 02:10:04 PM »
Like Tim W. just said, listen to Brett regarding 70' lines.  Another factor and closely related to what Brett explained is that it takes more pilot skill to present a pattern with a larger airplane as long as we are confined to the 70' lines.  There was a trend some time ago to 750+ sq in wings and the top pilots were having some success with these.  When pilots with somewhat less skill flew these airplanes, there was a problem of presenting a pattern that would score well.  The larger airplanes are not a help to the less skilled pilot to get good scores.  Those larger airplanes basically put too much machinery in our hemisphere.  If you take larger and larger airplanes to some extreme level, it becomes more clear that the really larger airplane will obviously be difficult to score just because it is confined on that hemisphere regardless of the skill of the pilot.  Now with the power plants that are available (IC and electric), they can be integrated into a more "moderate" size model and will be easier to fly on our hemisphere, regardless of the skill of the pilot, and will still be able to cope with unfavorable wind conditions.  I think that is a reason we are now seeing the trend for many of the top airplanes appearing in the 650 to 680 sq in range.  Yes, there are good outliers on either side of this range flown by really good pilots, but for the state of the art now, we see this trend.
« Reply #8 on: August 06, 2018, 05:26:58 PM »
  I meant the premise that bigger airplanes fly better. I do not agree with that at all, particularly when the line length is limited. We had bigger airplanes for a while, then hit the limit, backed off a bit, and arrived at the current range. 700 square inches seems to be about the rational limit, and at seems to be true even though we have piped 88s to power it with instead of ST46s.
     In fact, at one point we all thought that 720 square inches was just right for an ST46 - and the last ST46 airplane (and arguably the best) was *610*, 15 years later.
    Change the line length to 90', then, maybe.
Online Igor Burger
« Reply #9 on: August 06, 2018, 11:13:57 PM »
That was time when some guys around asked me how to make models cheaper. I flew piped PAs and Jetts and it was simply too expensive and difficult to have that time (in Slovakia). So I decided to make airplane for LA46 which was available for good money in our shops and slim aluminum pipes. Soon my calculator for model parameters gave me numbers showing that model has too small AoA for planned corners (r=3.5m) and too low wing load making him sensitive for turbullence and "hopping" in corners, so instead of trimming by flap size or deflection I simply cut almost 10% of wing area at its tips. It gave planform which I use till now and it is used also in Max Bee. Means higher aspect ratio and sweep back. Later we found it performs very well also with ST60 as used by Richie Kornmeier and after that he won WCh, so looks like it was sucessfull modiffication.
the old model:
http://www.netax.sk/hexoft/stunt/thenext.htm
resized:
http://www.netax.sk/hexoft/stunt/the_max.htm
and the same with logarithimic flaps (making flaps move less)
http://www.netax.sk/hexoft/stunt/the_max_ii.htm
this is the model I used on my first WChamp in Sebnitz (very turbullent place) and placed 10th in finals. Except Todd Lee, all larger models and engines.
http://www.go-cl.se/wch02-f2b.html
Offline TDM
« Reply #10 on: August 07, 2018, 06:00:15 AM »
A more scientific answer is that the Reynolds numbers for bigger planes are better and that is an indication of better performance.
« Reply #11 on: August 07, 2018, 09:53:25 AM »
    Different performance, maybe, not necessarily better. Besides, what parameters do you think define "performance" in a stunt plane? Because I only have a vague idea what those parameters might be. Which ones do you optimize, and why?
« Reply #12 on: August 07, 2018, 12:11:07 PM »
  " Brett - there was no premise in my message, just an observation and a question.  The observation was that for a good while (say, 1950s->1990s), the planes were getting bigger, and flew better, including, and especially, in worse weather conditions.  If there was no benefit from going bigger, most everyone at the NATS would still be flying something like a Nobler derivative, not an Impact/Trivial Pursuit/GEO XL/SV-11 etc derivative.
You mention the 70-ft  line length limitation.  How does this limit us from increasing the linear dimensions of an airplane by a mere ~10" in wing span and even less in fuselage length?  Does it have anything to do with the human visual perception that a larger airplane cannot ascribe the infamous 5-ft radius turn as well as a smaller one? (Even though they are quite capable of it, and not just theoretically, as was shown by Scott Bair and his Stunt Fire)."
Hi Mike
I will tell you my thoughts  and  experience,  I went to a 700 sq in plane in 1973, then in 75 when I developed what would become the  Stuntcraft  airfoil system , that would then later lead-in to the  SV airfoil  system, Then the  next plane started in 1975  would be  750 sq in.  When I flew it, it was nice, except I kept feeling it was  too large for the  size of the circle I was using.  Next one started 1976 was trimmed  to 725,  this flew well  but I still got the "too large for the circle I was using"  So agin it was trimmed down in 78 to just under 700 sq in, that  seemed about right, but in the next 2 years  I wanted to try moving the  size  down again, So I designed  the  Vector and  Apex , these were just over 630 sq in,  and  right behind that  I designed the larger of the 2, The  VECTRA  DREADNOUGHT, it was  around 650 and was / is , the  size  I have settled on. It was  designed mid 1980s, this was an eliptical  wing plane  plane  and  I also wanted a straight taper one , So  in 87 I started the   SV-11 , I was very please with the  size of  the last 3 planes  in the  SV  series   so  to this day I am stuck on this  size,  I believe  its  the best size for  a  70 ft circle, and  some, even use  2 to 3 feet smaller  circle  size ( 65 to 67)
I did make  make  the later  eliptical designs,  Tempest  DREADNOUGHT ,  Cutlass, STARFIRE  etc   680 to 690 sq in  just because  of the  reverse  tip sweep.  But I would  not  go back to  the  larger  ships.
I will also tell you  that , to me, it looks like  Les McDonald  sorta  did the same thing, He had  a  600  or so size  Stiletto , then 1975  showed up with a  700  sq in version, right after that  came  the  660 Stiletto ,  I have his last one  here  and  it looks to  be  640ish ,  You may see other around the  country that also  followed  this  trend
Regtards
« Reply #13 on: August 07, 2018, 01:41:34 PM »
The ones that Paul Walker tells me to, because if I don't the entire Seattle-area contingent will beat me up.  I live in fear of those Washington guys.
« Reply #14 on: August 07, 2018, 04:06:49 PM »
We were discussing this very topic at the field last weekend.  Since I have yet to build my PA ship for next year I am torn between building a smaller (630-650sq) for an 46 size engine or 670-700sq and get one of the 60+ engines.  So, my question is - does it really matter how big the plane is?
« Reply #15 on: August 07, 2018, 06:11:58 PM »
    My airplane is about 660 square inches and was designed around a OS40VF. I currently fly it with a RO-Jett 61, and people have flown them with Jett 76s. As long as you use a conventional piped stunt engine, I think anything that will fit will work.
« Reply #16 on: August 08, 2018, 07:48:21 AM »
My choice has been to design (or Choose) the airplane around the engine I want to use.  Thats the first choice to make.  Today I think your best choices are going to be the RO Jett .61 or .67 or PA .65 or the larger class RO Jett .76 , PA .75, K77.  My own experience would have me choose about 640 to 670 sq, for the .61-.67 and 670 sq. to 700 for the larger class.  It's not much but noticeable .  I've scaled my airplane up and down to best sense this.  You can absolutely put the larger engines in the smaller airplanes but they weight a little more and might require more fuel that will change trim and ,in my case , made the airplanes less friendly to trim and fly.  You can drop the smaller engines in the larger planes and they do OK but loose their edge in the wind and overhead.  You can run the engine harder but I don't care to hear the engines jumping in and out of cycles constantly and still the plane feels underpowered.  There really aren't many engines these days under the .61 that I feel are competitive-if you intend to compete.  If you wish to go smaller I think electric might be better given what engines are readily available .
So is bigger better?  I think so up to the point where we are to take the best advantage of the power plants we have and the line length we fly on.  When I drifted back to the contest circuit about a decade ago I was flying a superb set of RO Jett .40 airplanes but found I was simply outclassed on the LPad.  Hate to say it-but size, or the lack of, isn't too impressive next to larger airplanes.  They CAN fly as well and maybe present better square maneuvers in the given space.  They just won't get you much score.
« Last Edit: August 08, 2018, 08:07:18 AM by Dave_Trible »
Offline Mike Alimov
« Reply #17 on: August 08, 2018, 10:56:17 AM »
Thanks to all who have replied so far.  It was very surprising to read, to be honest.  In this day and age, when the stunt community is discussing the most seemingly minute aspects of airplane design in an attempt to eke out some competitive advantage, and is capable of numerically modeling virtually every parameter (e.g. pitching force due to propeller gyroscopic precession and the compensating downward pitching due to landing gear drag); when we know how to adjust engine compression, prop pitch, and nitro content for a given density altitude...  we seem to pass on (I think) the granddaddy of them all, the Reynolds number.
To summarize what I've heard so far, the stunt planes don't grow bigger anymore because:
- they feel too large for the 70' circle; (didn't stop Paul from taking B-17 to the Worlds)
- others have tried to go bigger about 50 yrs ago with ST-46 power and backed off;
-  smaller planes fit better in a pickup truck (true);
- bigger planes require bigger engines which cost too much ( very true! Not to mention fuel costs);
- and then there's Tim,  who was forced at gunpoint by the Walker-led Washington cabal to promote the "differential dynamic pressure" conspiracy theory.
« Reply #18 on: August 08, 2018, 11:12:21 AM »
And you just confirmed our conclusion.  It is not the plane, it is the judges.  If you want to win you need to be big.  Flying well is not enough, you have to do it with a big airplane, or should I say a big engine.
« Reply #19 on: August 08, 2018, 05:24:03 PM »
In a nutshell that's mostly true..  It's still an impression game.  You still have to fly that larger airplane very well.  Just being big isn't a gimme', but being small is a give-away.
« Reply #20 on: August 08, 2018, 05:26:20 PM »
So, if you already knew the answer, why did you ask?
« Reply #21 on: August 08, 2018, 07:31:25 PM »
   It has *never* been an "impression game". I have spent about 40 years hanging around with, coaching, judging, and competing with some of the most successful people in the history of the event. You know how much time we have spent discussion "impression" and/or "presenting",or whatever mysterious "X" factors that "everybody knows about"? Virtually ZERO. The only time this topic is ever discussed is when someone else mentions how important all these secret magic factors are, and we tell them to go fly more accurate patterns instead of worrying about "impression".
     My advice to everyone, even Mike who already knows better - build and fly whatever results in you flying more accurate and mistake-free patterns. If you want to know "what the judges are buying" I will tell you the big secret - the judges want to see accurate geometric shapes of the right size and positioning. or in other words, something that looks like the drawings provided in the rule book. . It is nothing more complex, or ephemeral, than that. It's hard to achieve but you should *always*, repeat, *always" make decisions that result in superior and more accurate patterns - and do not waste a lot of time worrying or considering these crazy theories of what "presents" better or gives better "impression". If you can do more accurate patterns with a Shark 15 than you can with a Sweeper, then you will *get better scores with the Shark 15*.
  No one ever wants to believe it could be that simple, so I know it will just bounce off again. But if you want advice on how to become competitive in stunt, that's it.
Offline Chris Wilson
« Reply #22 on: August 08, 2018, 11:19:08 PM »
He asked the question on post 1 and summarised it on post 18.
He didn't know originally and now he does but are you claiming that he knew before post 1?
MAAA AUS 73427
« Reply #23 on: August 09, 2018, 08:43:45 AM »
Looks like I need a bigger truck.
Very true.  That and/or a trailer.
Offline Mike Alimov
« Reply #24 on: August 09, 2018, 09:29:49 AM »
I did not know the answer when I asked, and I still don't.  But I do listen (despite the impression), and in fact after all the replies I got so far, I'm seriously reconsidering that 800-sq.in project I had in mind.
What I was trying to say is that none of the arguments for not going beyond 650-700 sq.in was technical in nature.  I expected something like this:
"Per the model scaling rules, the weight grows as a cube of linear dimensions while wing area grows as a square, so bigger planes inevitably build heavier.  At ~800 sq.in. size, the resulting expected ~15 oz/ft^2 wing loading is too large to allow the plane to fly anywhere close to the rulebook (5ft ?..) corners..."
-or like this-
"At 75-80 oz flying weight, the line pull will create physical loads that will result in too much pilot fatigue to fly 5-10 flights a day."
-or even the least plausible-
"According to a  NACA paper from 1965, the Reynolds number and its effect do not apply to wings between 650-1000 sq.in area, so there was no additional benefit from increasing the size beyond 650".
Instead, it all came down to "they feel too big".
Hence my hesitation as to the validity of such conclusion.  But then again, the stunt folklore and people's practical experiences all carry a grain of truth to them.  I'm trying to find that grain.  That's all.
Offline Mike Alimov
« Reply #25 on: August 09, 2018, 10:20:17 AM »
[snip]
[snip]
[snip]
[snip]
On 7/20/18, Paul Walker posted the following in the thread "The corner conversation" on the General Forum:
"I learned clearly in 1990 that it is not how tight your corner is, but the illusion of that. In 1990, VCR's were available and good enough to record stunt flights. That happened at the 1990 Nat's. I thought I had a tight corner, but judges and other pilots told me that Jimmy did. I was puzzled.
Once home with a  copy of those flights I played them over and over tracing the path of both Jimmy's and my plane. It wasn't even close!!!
My plane turned a much tighter radius, BUT Jimmy's looked tighter due to its paint scheme and speed. It flew faster and that made it look tighter also. I have never forgotten that demonstration and used it to fashion my corner presentation. I further worked on the stop of the corner to be as abrupt as the start. That also adds to the illusion."
« Reply #26 on: August 09, 2018, 10:26:55 AM »
-or like this-
The 15% difference in dynamic pressure from tip to tip wasn't technical enough?  Would you feel better if I'd said :
The spanwise dynamic pressure gradient of an aircraft flying a 72 foot diameter circle is found by solving the following equation for point-wise dynamic pressure, taking the derivative, and then normalizing for angular velocity:
pd(x) = 1/2 rho v(x)2  (1)
where x is the distance from the center of the circle, rho is the density of the air, and v(x) can be found from
v(x) = 2 * pi * w * x  (2)
where w is the angular velocity in radians per second.
Substituting (2) into (1):
pd(x) = 1/2 rho (2 * pi * w * x)2  (3)
Taking the derivative and simplifying:
d/dx pd(x) = 4 rho pi2 * w2 * x  (4)
Taking x0 as 22 meters and evaluating (4) and normalizing, we find that the pressure density gradient at the nominal maximum aircraft flight radius is
(4 rho pi2 * w2 * 22m)/(1/2 rho (2 * pi * w * 22m)2), or about a 9% change in dynamic pressure per meter.  For an aircraft wingspan of 1500mm, this variation is quite significant.
Does that help?  Does one egghead with a whitepaper that's composed of a kernel of supposition surrounded by a blizzard of mathematics supersede the testimony of the practical experience of dozens of actual practitioners?  And in a sport that's as touchy-feely as stunt, why should we trust hard numbers anyway?
One thing I've learned in almost 30 years of being an engineer: if it's been tried a dozen times and failed every time, then barring you doing something quite different, there's very little chance that you're going to be lucky 13.  Unless you've got a really compelling reason to think that you've discovered a loophole, if you go down that path chances are you'll fail, too.  You should always listen to the egghead with the whitepaper, in case they've found that loophole -- but you ignore your end-users and your service personnel at your own risk.
« Reply #27 on: August 09, 2018, 10:35:58 AM »
I think a look at the results of this years’ World Champs might lead one to think visual impressions count.  Those “hot #+?!! High tech, snot mobiles” got better scores-deserved or not.
« Reply #28 on: August 09, 2018, 11:22:13 AM »
Bob Gieseke told me he cut the top off of his rudder and always painted a white stripe on the side to draw the judges attention to his flats.  He never said it was to draw attention away from the corners but it is hard to watch one thing when you are attracted to another.
Offline Mike Alimov
« Reply #29 on: August 09, 2018, 11:31:01 AM »
[snip]
[/color]
Does that help?
--(MA) Thanks for running through the calc, Tim, but no, it doesn't help.  It shows that the outer console of an airplane with equal wing panels experiences more pressure than the inner one, which is not an unwelcome effect if I want to keep the plane from turning in on me.  It can only go so far, being constrained by the leadout guides. Introduce unequal panels, and the effect can be mitigated or eliminated.
Plus, no one else has brought up the differential dynamic pressure as a factor.  If that was one thing that kept us from going bigger, it would be mentioned more than once.
--(MA) If the kernel contained in a whitepaper is valid, it should not contradict the experiences and empirical findings of the dozens of actual practitioners; instead, it should explain them, and (hopefully) offer a vision on how to improve/expand upon them.  Einstein's theory of relativity explained phenomena that Newton's laws couldn't.  It doesn't invalidate them, but can only be observed/measured at distances and speeds that were unthinkable in Newtonian times.  But I digress...
--(MA) Because only hard numbers can explain what we feel at the end of the lines. I didn't understand that for a long time, and it wasn't until I started re-weighing and re-measuring my old airplanes and crunching some numbers that I began to understand why some flew better than others.  It's all about physics laws in action, and precision in implementing them into hardware.  Ted crunched quite a few numbers for his Imitation article, and Igor runs an even more (I think) comprehensive calculator.  If that wasn't the case, they'd be spending that time playing with vivid paint color schemes in Corel Draw.
Of all people, I didn't expect you to make that argument.
--(MA) As an engineer with 22 years of experience, I could not agree more on that. (The key phrase being "barring something quite different").
--(MA) I'm not ignoring the end users. In fact, I'm the end user myself.  But if the answer to the question "why are you doing things this way?" was always "because we've done it this way for years", the technology around us would not progress much beyond Edison's incandescent light bulbs.
In this particular case, yes, I think there are reasons to re-visit this argument.  What has changed since the 1970's and 1980's:
- composites and vacuum forming technology is now accessible to home modelers like myself, not just defense contractors; this allows to build stronger, lighter, more accurate structures;
- available power plants are abundant, the limit on combustion engines was lifted from 0.60 to 0.90 cu.in, and more importantly, our knowledge of how to control that power is greater than ever;
- our understanding of control line aerodynamics is better than ever before, which means we can design to achieve certain positive effects  and trim out the negative effects.
« Reply #30 on: August 09, 2018, 11:43:44 PM »
There's a simple test for this conversation.
Build a straight, well trimmed Brodak Nobler, drop in a well broken in LA .46, clip on a set of .018 X 40' cables and go fly against Dave, Derek, Paul and the rest of the current best.
In fact;in turn, give each of them a dozen flights to get comfy with the Nobler and then have a flyoff with the others flying their own ships, each developed to maximize their performance in the airspace allotted by the rule book.  Add up the number of times the Top Gun flying the Nobler on  40' lines comes out on top.
Ted
p.s. try to get some of those cool tracer videos of the Nobler's 45 degree square eights
Offline Mike Alimov
« Reply #31 on: August 10, 2018, 06:37:05 AM »
Ted, now we are talking about the human factor.
An assassin with a katana and an empty-handed hero square off at a sushi bar.  Assassin swings and misses, and the hero stabs him in the eye with a dirty chopstick.  We all know how this movie ends; the hero always wins due to his sheer skill and prowess (and because the truth is on his side!).
No argument there.  (Although... are you volunteering David's plane if I build him a Brodak Nobler?  I've always wanted to try a celebrity plane, so I'll take you up on that   #^ )
To be a little more serious, if we eliminate the "pros vs amateurs" factor from your hypothetical competition, then such thing already takes place - every other year - and it's called Worlds.  I doubt David, Paul, Derek, etc would take a Nobler to represent the US against the best of the rest.
The question is, what could our Top 3 take with them to the Worlds to stem the composite Shark infestation?
« Reply #32 on: August 10, 2018, 07:55:53 AM »
Mike,
From what you have written on this thread, it seems you have not read nor comprehend what has been mentioned several times.  There was a trend for some of the top pilots to use larger airplanes approaching 800 sq in in area.  These top pilots were successful because they had the skill to present these large airplanes in our 70 foot radius hemisphere.  When pilots with comparative lesser skills in trimming and flying tried these larger airplanes, were disappointed with their results.  Then, with better power plants available (IC and electric) the trend has been to use more power and the models appear to be maxing out usually to something less than 700 sq in.  This combination of size and power has the ability to perform in various weather conditions.   This is the trend for the top pilots and the masses seem to also be more comfortable with this size.
One exercise some time ago that is interesting to consider.  A top pilot/competitor designed and flew several airplanes that were around 1,000 sq in or more.  These models were not successful in any major competition of which I am aware.  Obviously, those things were just too big and too much machinery to be flying within the confines of our 70 foot radius hemisphere.  Models of that size cannot possibly make a presentable square loop that is confined to a 45o segment of the circle with an elevation of 45o as specified by the rule book.  So, is 650 sq in, plus or minus the optimum size for our current power plants, maybe not, but that is certainly the trend for the top flyers.  The field is open for naysayers to prove the experts wrong.
Offline Mike Alimov
« Reply #33 on: August 10, 2018, 09:58:01 AM »
Keith, thank you for all your replies.  I read every post very carefully (and try to comprehend to the extent of my ability).  Moreover, I'm not the kind that posts questions only to rebuke everyone and proceed to the contrary anyway.
As I mentioned earlier, it was because of all the replies I received (and yours specifically), I am re-considering starting a near-800 sq.in project I had in mind.  Your statements, along with a few others, reaffirm my earlier understanding that how our planes actually fly and how they appear to fly when viewed from outside the circle are often two different things.  This is not a knock on judges.  I've judged myself, and I know that every honest judge strives to score only the flight path, and ignore the plane shape and paint scheme, plane finish and pedigree, pilot's reputation, etc. etc.  But if one looks in any college psychology textbook, they learn that human perception is susceptible to deceiving visual effects which are near impossible to overcome.
Here's what it translates to: if I show up at the NATS with a 800 sq.in airplane and fly rulebook corners, it will likely be perceived to fly larger corners, thus scoring lower; there is historical evidence to that effect.  Correct me if I'm wrong, but that's how I understood you.  And I now see how that is very much possible, which is why I'm no longer headed in that direction.
To Ted, Brett:  if I understand your argument correctly, it can be formulated as following: "We've done the work for you.  Stop wasting your time trying to design your own world beater.  Just take one of the top existing designs, build it well, and fly the socks off of it."  I hear you as well, and it is a very solid argument.
As far as I'm concerned, I have my answers, and the topic can be closed now.  I'd like to thank everyone for their input.
« Reply #34 on: August 10, 2018, 11:00:29 AM »
Well put.  I believe I have my answers as well.  The topic seems to have split into "Do larger planes FLY better" or "do they PRESENT better".  I agree that the 700sq limit that, IMHO changes a "Maybe/Yes" to a "No/Maybe".  Right now I have two competitive planes.  One is an 500sq 36oz 35 powered ARF Nobler that all I have done to it is change the flap/elevator ratio.  The other is a 630sq 52oz 46 powered ship with modern ratio's.  I have measured the minimum turning radius without a stall on the 500sq ship to be around 10' and the 630sq to be around 12'.  That is nearly a 10% difference in the length of the flats yet which one PRESENTS the squares better - the big one.
One other observation from my judging days - In a crowd of larger ships, the elevations of the smaller ship will appear larger than they are .
« Last Edit: August 10, 2018, 11:18:07 AM by Ken Culbertson »
« Reply #35 on: August 10, 2018, 11:50:55 AM »
(Clip)
(Clip)
From your viewpoint, you may sense that the larger model "PRESENTS" better.  With that argument, then bigger is better.  However, go a step further.  Take that 1,000 sq in beast with a fuselage that is well over 4 ft long.  How is that going to "PRESENT" in a square 45o loop on our hemisphere?   It will not do well, regardless of the skill of the pilot or even if it has some magical quality to turn a corner that really looks tight, even with the advantage of superior Reynold's Numbers.  I think there is a limit to how big these models can get and still "PRESENT" well.  Right now, that limit seems to be in the 650 sq +/- arena.  Of course, an enterprising designer may take a departure from this with his own innovative "larger" design and show that there is another way to get a "larger' model to "PRESENT" better.  Please show us the way.
By the way, how are you able to measure 10' and 12' radii on your turns?  Those are impressive!
« Reply #36 on: August 10, 2018, 01:12:15 PM »
No, the size range tops out at 700.  Within that range bigger presents better.
The corners were measured by slow motion video and I cranked it as hard as I could without stalling.  You can measure the distance traveled from the point the turn starts till the nose is pointed straight up.  In real life I would probably be kinder to my flap horn and make them around 14.  On 65' lines 14 looks really tight at full speed.  I have always been able to do real tight corners.  It is what's in-between them that sucks!  What astounded me the first time I watched this was the difference in the lower corners and the upper ones.  If you are turning hard, the 6th and 14th corners in the Square 8 actually appear to approach that impossible 5'.  It is like the nose stops going up and the whole plane rotates around the CG and drifts up some as it rotates.   I have noticed that on a lot of other vidio's of some of our top fliers too.  Love that YouTube slow motion!
« Reply #37 on: August 10, 2018, 01:14:27 PM »
  That is absurd. Your basic idea is wrong, and your concern over "impression" and that it is enhanced by larger airplanes is also, probably, wrong, and you are getting offended over the fact that we do not agree with your pseudo-question  (which wasn't really a question, but an assertion that had a question mark after it).  So you are mis-stating our position to mock it.
   You are, and anyone else  is, absolutely welcome to build any airplane you want and compete and fly with it in any way you want. No one at all wants to stifle your creativity and you can explore any avenue you want. Usually, when people go out of their way to ignore everyone else and "show us all" it doesn't work out, but we could be wrong. The rules permit essentially anything aside from limiting the line length to 70', so it's wide open.
     By way of advice (and I think it is highly relevant and critically important, a lot more important for success than almost any other aspect of stunt), a  hallmark characteristic of most/all of the winners over the last 35 or so years has been their almost complete disinterest in "impression" or "how it presents", in favor of more fruitful pursuits like trimming, engine setup, coaching, and other items that result in superior accuracy and precision of the flight compared to the rule book. An even more important characteristic is listening to (if not always following) advice from people with vastly more experience and success, and studying how each other approaches the problem. Those, too, could have been mere coincidences - but you know they aren't.
   This approach has been so successful that at one point, it was considered a conspiracy. And *no one* wanted or wants to believe the truth, because it's so simple that is seems impossible.
    But, it's just advice, no one is compelled to take it.
   So, bottom line - anyone can do anything they want, any time they want, with very few restrictions. We have a very accurate and repeatable test method to determine who is right and who is wrong, so we can all see the results. Good luck!
Online Howard Rush
« Reply #38 on: August 10, 2018, 01:45:28 PM »
This is one of the cool things about model aviation.  You aren't bound by what the boss wants.
Online Howard Rush
« Reply #39 on: August 10, 2018, 02:00:31 PM »
Without giving this much thought, two things come to mind:
First, a given corner radius will be a different fraction of airplane size for different size airplanes. Brett observed awhile back that tail length may be determined by corner radius.  For example an airplane that's too big may have to operate at extreme tail angle of attack in corners.
Second, perhaps powerplant selection determines airplane size.  If the best powerplant is a PA .75, one might size an airplane for a PA .75.  Electric power might make for a different size airplane, but from what I've seen so far, competitive electric and acoustic airplanes are about the same size.
Offline Mike Alimov
« Reply #40 on: August 10, 2018, 04:54:38 PM »
I was just about to congratulate everybody on keeping things civil, and now this.  This post once again reminded me why I (and many others) usually stay away from the forums.  It all started with a purely technical question on why not take advantage of better Re numbers, in order to improve airplane behavior in bad air (and not chase some sort of *impression*, I never alluded to that).  I was not asking about what my creative freedom limits are (but thanks for the reminder, anyway). So far, Howard remarked about critical tail AoA, and Keith commented that very large planes simply look too large in the limited hemisphere, and require a lot of skill to handle.  Your point was that it's been tried and abandoned. Ted pointed out that the Top 5 (10? 20?) can beat the rest of us with a Nobler, no matter what we fly.  All points taken.
And just to remind all the *elite* flyers: the rest of us, "les stunt miserables", also work on trimming, engine setups, and coaching when we go flying.  Occasionally, doing so causes questions, which people then ask, including on this forum.  And this is what they get - someone completely losing temper, just because they've been misunderstood, misquoted,  given evidence that somehow invalidates or undermines their opinion, or simply hurts their fragile ego.
 It's no wonder, then, why people prefer to fly at Brodak's over NATS.  It's this. Attitude.
So long, gentlemen.
Signing off - for a long while.
« Reply #41 on: August 10, 2018, 08:42:56 PM »
The short answer is in RC is, yes. "Bigger flies better" in that arena has been undisputed for 'like forever". But for obvious reasons, not in our world. I personally have built A LOT of 750sq ships. I currently have 2 at home with me right now. But as for me, the approx. 650sq. class seems to fit me about right. We started at around 550sq. class in our world, went to 650sq class., tried 750sq class. and to no surprise "up the middle" for most of us seemed to work out best.
« Last Edit: August 11, 2018, 06:04:51 AM by proparc »
« Reply #42 on: August 11, 2018, 04:11:09 PM »
Hi Mike,
I think you missed my point...although, after re-reading it, I didn't make the point all that clear so, for that, mea culpa!  Below in red, I'm reasonably certain, is the sentence to which your post was addressed:
"In fact;in turn, give each of them a dozen flights to get comfy with the Nobler and then have a flyoff with the others flying their own ships, each developed to maximize their performance in the airspace allotted by the rule book.  Add up the number of times the Top Gun flying the Nobler on  40' lines comes out on top."
The phrases "...in turn..." and "...others flying their own ships..." did, in fact refer back to the previous paragraph's "...go fly against Dave, Derek, Paul and the rest of the current best...".  I agree the meaning of the paragraph was open to interpretation.
The intent of the "test" I suggested was that each of the Daves, Dereks, Pauls and/or other current top guns would take turns getting used to the Nobler on 40' lines and then compete with it in a judged contest against the other Top Guns flying their own "designed, built and trimmed for the available airspace" ship.  The question was: After each "top gun" had his/her opportunity with the big airplane on short lines against the other "top guns" with their own equipment,  how many would have won the competition when they flew the Nobler on the short lines?  My guess would be a big fat zero.
If my suggestion of the old as the hills Nobler instead of their own Impact/Thundergazer etc. is your concern I feel the outcome of each flyer flying "his own" ship on 40' lines would be the same; zero wins.
I was trying to demonstrate--rather than pontificate--that the amount of airspace available is among the most critical factors to be considered when developing a competitive stunt model.  Was it an extreme example?  Yes, and purposely so, so as to make the cause/effect obvious.
Re your Reynolds number observation...
Although I recognize the validity of Reynolds numbers and the desirability of greater chord length in the pursuit of performance I think its  importance vis a vis stunt ships confined to neighborhood park sized flying sites pales in comparison to other factors, specifically aspect ratio of area appropriate wings and appropriately configured high lift devices (flaps and...I guess I have to throw them in...vortex generators [icccck!] I said it).  Within reason, I don't feel today's competitive stunters have a wing loading which is restricting our turn radii.
There was a period of time in what is now almost ancient stunt history where many thought we should be flying 725+ square inch stunt ships on S.T. .46s. While some success was achieved the "appropriate" (yeah, I recognize the ambivalence)  size was more like 650 square inches.  What we even later learned was that even with .75s and .82s we were still comfortable with airplanes in the 650 to 700 square inch range.
Of pertinent interest is that since the advent of that revolution (the .45/6 generation) we've increased the size of the powertrains but not found much to be gained by making ships bigger.
I know, TMI Mike.  My only real purpose in the lengthy explanation is to hopefully help you to understand that it was never my intent to suggest that what I called "Top Guns" could whip the not quite yet top guns flying an overpowered Nobler on 40' lines.
Quite the opposite, my intention was that whichever T.G. was flying the airplane too big for the available airspace was going to lose big time.
Ted
p.s.  Just as I was about to post this novel I noted a post from Proparc in the "topic summary" below this window saying pretty much the same thing in less than three lines.  Now, I could'a done that too but I get a little teary eyed thinking about all the letters and punctuation marks that would never have had their chance to shine.  thus, I'll post it anyhow. Z@@ZZZ Z@@ZZZ
« Reply #43 on: August 11, 2018, 05:30:15 PM »
A better test (although it would be hard to talk Paul et all into it) would be their own ships on 40' lines vs. either whatever they purpose-design to fly on 40' lines or one serious 1/2-A ship on 40' lines.  The smaller plane would win, I think.
« Reply #44 on: August 11, 2018, 10:57:51 PM »
Really?  When I want to fly, and the boss wants us to go talk to the contractor, I'm pretty bound if I don't want cold food and dirty clothes building up....
Mark
« Reply #45 on: August 11, 2018, 11:32:16 PM »
Mark
Is Howard Single?
« Reply #46 on: August 12, 2018, 01:23:32 PM »
Exactly my point, Tim.
One could illustrate the same thing by suggesting flying a full size 747 on 40 foot lines and trying to do a pattern.  The quantity of airspace in which one has to work is probably the primary element necessary to be considered when speaking of designing for constrained flight aerobatics.
p.s.  Another element that I feel is worth considering when speaking of line length (and, thus, airspace) is that the shorter of "competitively compatitble" line lengths for a given ship should be seriously considered as a possibly better choice  than just assuming max line legal line length as "optimum" for a "modern sized" competitive stunter.
To go "tiny' one last time; a  competitive stunt ship capable of performing controllably on, say, 10 foot lines would be much easier to hit bottoms with than an equally competent ship flown on, say, 100 feet of wire.  The closer the plane is to the pilot the easier it is to "place the ship" accurately at the five foot/45degree/90degree definitions by which we attempt to comply with the rule book.  (Note that the 10' number was used to make the point as to the ability to accurately "place" maneuver segments.  It was "not" intended to be a "for real" suggestion!  Lots of reasons, none of which would be worth discussing due to its absurdity.
The only .40+ powered ship I ever flew on max length lines was the original Trivial Pursuit...for very distinct reasons.  Let's just say it would have never floated with a "child's" life vest.  It did, however, have a reasonably distinguished record despite what was, at the time, considered to be an un-competitive wing loading (~72 oz on ~650 sq").  It placed 2nd at it's first Nats in 1992 and won the 1993 Team Trials powered by a piped .40VF.
Ted
Offline Curare
« Reply #47 on: August 12, 2018, 11:23:35 PM »
Ted
OK Ted, you can't throw a statement like that out there and not have someone bite! What benefit did you get out of flying on longer lines with a heavy TP? Was it merely to get the thing flying faster, but retaining a 'sensible' lap time?
Enquiring minds want to know!
Greg Kowalski
AUS 36694
« Reply #48 on: August 14, 2018, 12:37:15 PM »
Hi Curare,
Per the highlighted quote above: BINGO!
In my defense, however, it's important to recognize that the TP was my first ever voyage into the wonderful world of tuned pipes (early 1990s and the powerplant du jour was the "little" OS .40 VF right in the heart of the East Coast love affair with the big bore ST .60s).  When the ship tipped the scales at levels felt, at the time, to be uncharted territory and unlikely to be successful let alone competitive my approach to flight trim/airspace was precisely driven by the substance of your observation.  If the pig was going to get off the ground let alone "compete" it was "obviously" going to have to do so at a brisk pace.  The natural approach was exactly as you suggested; hang it as far out as legal and fly it fast.
Ultimately I learned a lot about the chutzpah contained in that little .40 coupled to the tuned pipe and a "very" low pitched prop spinning at massive revs.  At the '92 Nats I didn't yet even borrow let alone own a tachometer of my own nor did I check lap times for the same reason...no stop watch.  I was spinning some kind of 12+ in X 3 something prop at ear splitting revs and the thing flew like a nimble truck on the end of the lines.  Years later Randy Smith commented to me that he had filmed/taped (???) many flights at that Nats and the TP was the slowest of the bunch at (he said) 5.8 sec/laps.  I remain a little skeptical to this day but I don't question that the lap times were modest and extremely flyable.
Just FYI, after the success of the ship with that sub 4 pitch prop I started what turned out to be a fairly lengthy exchange with  Brian Eather down in Sydney about getting some of his beautiful three blade props in that 3.5 or so pitch range (edit! Just went to the shop and dug out a huge box of props and found them…labeled 3.25).
He made some and mailed them to me and I took them out to give ‘em a try.  Damn! They barely got the hoggish TP in the air and lap times fast enough to maybe make the thing “stunt” a bit weren’t obtainable.  I went back to the two blade that had worked so well.
Just diddling around with the prop one day I noted something odd and laid a straight edge chordwise across the back side and noted light passing between the prop and the straight edge.  The danged thing had undercamber.  Briefed Brian during my next layover down under and he said “mail ‘em back to me!”.  I did so and a week or two later got them back with under-camber (~3/64" or so sanded into the back of each blade) and a request that I retest them.
I did so and it was more or less like magic.  Excellent performance! For some time Brian was selling both flat back and undercambered 2 and 3 blade props and I’ve got probably two dozen of them in my boxes of stuff.  When I re-engined the TP with-first-Randy’s .61 and later with the Ro-Jett I slightly preferred-I was running under cambered 12” diameter props with pitches of 3.25-3.5 increased to 3.6 to 3.75 for the last inch or so at the tips.  Those were the props I used on the TP for the next couple of years plus several rebirths due to the loss of later models .
Overall that overweight pig flew at seven Nats finishing 2nd four times, 3rd and 4th once each and 7th once: three Team Trials, 1st once, 4th once and 7th once.  It flew in its first Nats in 1992 and it’s last in 2007, I’m guessing one of the longest “career” records of any one off stunter!  I had a few arguably “better” airplanes in those years all of which met untimely demises due to lousy structural engineering by the designer or dumb mistakes at the stick by the same guy.
Bet you’ll never ask me a question again, huh!  Good catch, by the way.
Ted
p.s. Most of those years it flew on 66’ of wire just slightly less than whatever it took originally when it flew on max handle to centerline that first year.
p.p.s. There were some interesting “other” developments during the TP’s career related to the wing loading issues and creative corrective mods that later raised their heads more prominently…like turbulators (different forms of airflow modifiers now represented widely by VGs) and non conventional variations of flap/elevator ratios, optimal CGs, pitching moments etc. but I think I’d best shut up instead.
p.p.p.s A big thank you to one of the Stunt world's biggest heroes, Wynn Paul.  The data above on the TPs competitive record was available solely because he was kind enough while working on his hopefully soon to be published Stunt History to send me a breakdown from his records of my national and international history clear back to my first Nats as a Junior in 1959.
Offline Curare
« Reply #49 on: August 14, 2018, 03:46:32 PM »
Thanks for elaborating Ted, I'm sure I'm not the only one who likes to read your stories, a lot of posts are one liners, and may or may not be helpful, but yours (as proven) always contain nuggets of gold and are not only entertaining, but well worth reading.
Stuff like this is very encouraging for those of us who consider ourselves stunt pilgrims, it's good to know others have walked the path, and been horrified when they've built overweight models, and that all is not necessarily lost if we do, and not only do you take the time to explain the problem, the where's and the hows of the fix are also equally important to me.
Dont stop!
Greg Kowalski
AUS 36694
