  • June 16, 2025, 03:05:30 PM
Author Topic: Three Surface Stunter  (Read 21983 times)
Re: Three Surface Stunter
« Reply #51 on: January 31, 2020, 04:35:25 PM »
This thread is about canards, but it might lend some insight into what happens as the airplane layout changes.
The two pictures show that max performance occurs with roughly 30-35% tail area(as a % to total area).
I've only tried that big a tail on one plane, and it was a profile carrier.
https://stunthanger.com/smf/stunt-design/mid-engine-canard/msg485836/#msg485836
Offline Wolfgang Nieuwkamp
« Reply #52 on: February 01, 2020, 12:33:23 PM »
Phil,
according to Fraserīs article, the tailplane size can be chosen freely, adapting the CG.
Equation (13) gives the location of the neutral point. The CG should be 8% of x12 ahead of that neutral point.
It works, even for tandem airplanes.
Wolfgang.
The article is too large to attach, so here is the link:
https://www.dropbox.com/s/phes1fzvact9ez7/Fraser%20Stability.pdf?dl=0
Tags: tsa canard
