  • July 12, 2025, 11:53:43 AM
Author Topic: I. C. Engine vibrations.  (Read 6400 times)
Offline Chris Wilson
« on: April 09, 2021, 04:01:32 PM »
Has anyone pondered about vibes from an I.C. engine contributing to it's aerodynamics?
I know there is some evidence that hinge lines benefit by shaking loose stiction but that's not what this is about.
Perhaps a rough shark skin surface combined with 10,000 micro movements a minute may help flow.
Now that I have thrown the meat into the lions cage let's see what comes up.
Chris.
MAAA AUS 73427
Re: I. C. Engine vibrations.
« Reply #1 on: April 10, 2021, 12:58:52 AM »
Chris.
The only thing that I personally feel that vibration *adds* is that you can see all of the loose balsa you forgot to get out of the canopy bouncing around.
I have 57 years flying IC and only 4 invested in electric.  Once I learned that the controls needed to be free of all binding because of the lack of vibration all I found was a plane that flew better, even the ones I converted.  So if vibration adds to aerodynamics then the high frequency vibration of the electrics must be even better.  I do miss the sound....
« Reply #2 on: April 10, 2021, 01:40:21 PM »
Right off, I don't know. My gut feeling is that it doesn't matter, but I would be open to contrary evidence.
« Reply #3 on: April 10, 2021, 03:18:25 PM »
It would be interesting to deliberately get away from dead flat high gloss finishes and try something similar racing yatchs riblets skin developed at Langley by NASA.
It's available in tape form and designed to reduce subsonic flow.
Chris.
https://www.google.com/url?sa=t&source=web&rct=j&url=https://www.nasa.gov/centers/langley/news/factsheets/Riblets.html&ved=2ahUKEwiJuq6j0_TvAhVegtgFHWSjASsQFjAFegQIDhAC&usg=AOvVaw1vxl2Mw_pHMwVav5k19ngh&cshid=1618091171943
« Last Edit: April 10, 2021, 03:47:19 PM by Chris Wilson »
MAAA AUS 73427
« Reply #4 on: April 10, 2021, 04:16:42 PM »
Chris.
   Or, as a smaller-scale experiment - festoon it with VGs , trip strips, turbulators, and zizag strips.
« Reply #5 on: April 10, 2021, 04:36:29 PM »
The issue I see there is that site specific application suits only a small range of use and having it applied generally with out regard of trip zones  maybe of greater benefit.
Coupled with ribs that resonate with I.C. engines would drastically increase the effective rlb size and take this discussion well outside of known research.
Ultimately I would like to see an equivalent product like Solarfilm made with a herringbone pattern on it and cover the entire model.
Such a film exists but not on a commercial level and comes from wind turbine research.
Chris.
« Last Edit: April 10, 2021, 08:59:28 PM by Chris Wilson »
MAAA AUS 73427
« Reply #6 on: April 10, 2021, 08:34:19 PM »
Could be the ' boundary layer ' effect would produce less drag but more / better ' LIFT ' , as the airflow wouldnt fall off / break away from the aifoil / flaps as easily. Maybe .
You might have to vary the surface to suit the temperature / atmospheric density . VD~ S?P
« Reply #7 on: April 10, 2021, 10:42:15 PM »
Ultimately I would like to see an equivalent product line Solarfilm made with a herringbone pattern on it and cover the entire model.
Chris.
You raise an interesting point.  None of this has anything to do with vibration but I have never had shiny clear coating and rubbing out make any plane fly better.  Score higher, yes but fly better?  It might be interesting to take a nearly finished electric and fly it with a fresh coat of unsanded filler, then sand it smooth and fly it again.
« Reply #8 on: June 15, 2021, 12:30:28 AM »
A bit more to add to the thought experiment:
(Ok, can't remember how to link one thread to another. Go look at "Energized Boundary Layer" in the engineering section--while I try to figure this out again.)
Online Jim Hoffman
« Reply #9 on: June 16, 2021, 05:58:45 PM »
It’s been my experience that hunting (low frequency pitch limit cycle)  is more often seen in E powered stunters than IC.
There are two theories (IMHO) that may explain this……
1)   Higher inertia effects from the rotational mass of the motor, crankshaft, prop and spinner in E-power planes.
2)   Some boundary layer disturbance that may exist more in IC than E-power due to vibration.
I have been able to trim both IC and E-power stunters to a reasonably high level.
« Reply #10 on: June 17, 2021, 07:26:20 AM »
I vote for #1.  I have been having great luck with thrust line adjustments to cure hunting on several E-birds lately...
« Reply #11 on: June 30, 2021, 09:16:23 AM »
Not anything to do so resurrect an interesting one.
Just looking at the planes, I'd opine that electrics may no have enough vibration to keep the controls from sticking around neutral.  Particularly, electrics may be too smooth running, and not generate really sharp vibrations that IC engines are known for.
« Reply #12 on: July 06, 2021, 10:22:24 PM »
Your actually asking 2 different questions.
Firstly..
Well it will.. its about pressure and creating a change in the pressure of the airflow. You suggestion is similar to the golf ball dimple. Not all about drag reduction but about micro pockets of pressure differences.
Many people felt open bay wings were giving some improvement vs a perfect foam wing. Again this is explained by the pressure changes that occur along the chord line.
In the past much of this has been speculation but with programs like Ansys you can see how airflow reacts to different objects.
Micro scales, if you look.at a shark skin under electron microscope they look closer to a formular front wing crossed with a 3 way vortex generator.
Even if you wanted to copy the technology,  I don't know how you might even come close to it.
I hate agreeing with brett because it happens to often.
Having studied boundaries and how they interact within certain conditions,  im not convinced that there is anything to be gained by "vibrational resonance enhancing boundary layer efficiency "
I dont think the airflow molecules stay attached long enough to the surface to be bothered by a vibrating surface. The issue is the plane is flying through a very dynamic environment with à HUGE amount of pressure change.
Im not a rocket scientist, but I figure they vibrate ALOT more than our IC or electric ships do, if vibrational resonance was a "thing" they would see it there, and Ive not read anything to suggest its even close to "a thing"
The emergence of hunting in electric is simply solved by thrust line adjustment. Electric motors deliver power to the airframe differently thus might need a tweak.. not every design hunts .. some do it worse..
There is more vibration loosening control systems than electric does.. so that's a "thing"
