Id think the span / weights quoted dont quite match .
Nobler size start getting a bit mushy at 50 Oz, longer lines get a bit more room / speed / lift .
55Oz is Bill wewages Hot Thunderbolts weight . He went to a bit of trouble to get it that light .
Building a plane around a hard straight grained 1/4 sheet spar , tip to tip , is one way to carry the load .
you can get a bit of give for the gusts . where a C - ' D ' tube if very light is more ridgid before it brakes
IF you try and ' bow ' it .
I recomend I beams for scareing peole , Fuse across knee and pull the tips , bends like a strip . if youve
done the centresection ply doulers ending progresively / tapered over a few bays .
You cant get a D tube to bow like that .
A lot of Jack Sheeks designs will build light . You dont need a W. C. 1st place Capeable plane for ' intermediate .
You need the lines tight , and something that will rotate hard to avoid terra firma , as in excess lift.therefore it wont drop out of the sky doing a avoidance . I think the detroiter type works more like a sail or this ,
where the D tube can get semi stalled and awkward .
Things like not haveing tractor mufflers hanging out the inboard side , square wheels and bits of lead strewn about things help. Theyre all counterprodutive .
40 ships were traditionally bigger than 35 sized . The Engine WEIGHt bing one consideration .
chopping the nose shorter with a heavy 40 in a Noble sized airframe saves weight .
Big lumps of weight in small aeroplanes produce inirtia , you dont want to acentuate that .
they should pull 55 inches if theyre built clean aerodynamically, but keep the all up weight
under 50 ounces f you want the performance the bees knees .
This modern clear plastic might give the structural reinforcement properties of a good ole finish .
floppy soggy film doesnt help at all . The covcering should be a TAGHTENED SKIN
its a large part of the torsional stability under load of the aeroplane .
A flexi wobbly soggy airframe wont fly like a taughttensioned / with a bit of give / bow - one .
Select the spar wood for straight consistant clean unknotted grain , BEFORE weight .
usually 6 - 10 Lb woods good for detroiter wings , it works like a good sword blade .
not a fenceing sword whipping aboutthough .
Stiff Pushrods arnt a bad idea either .
Have a ook at some of the old 60s McCoy 40 & Adaminson stuff , too . They were in the ' 40 ' game then .
& a FPS isnt a piped 40 VFR , it needs a aerodynamically clean lean machine to fly sleek like Sheek !
![Hoff H^^](https://stunthanger.com/smf/Smileys/classic/hatsoff.gif)
These blokes know their wings .
![](http://www.control-line.org/images/800X600/eod8j7rxu4.jpeg)
![](http://www.control-line.org/images/800X600/8hdg1pknrll.jpeg)
Id thought the USA1 , Shark 45 , Novi IV , and Mr Towell's Caudron the personification of all things wingey ,
as a Lad .The USA 1 theres was alledgedly G-21 - 40 ST. if so , a FP cant be far short in output .
Best shot of the prop of champions , of the era , yet . too. All the PAMPArites will know the credits ,
