  • July 30, 2025, 11:15:16 AM
Author Topic: Fuselage shape in wind  (Read 5443 times)
Offline Guy Markham
« on: June 02, 2025, 09:48:28 AM »
Why a  flat fuse side instead of a rounded  side?  the rounded type would have less wind .. resistance than flat side y1
You only have to floss the teeth you want to keep!
Re: Fuselage shape in wind
« Reply #1 on: June 02, 2025, 10:37:01 AM »
IMHO you want resistance to mitigate line tension between up and down wind.  However, I am beginning to question that for active timer electrics and think that perhaps the smallest side area possible might be the best.  :!
I have no idea if this is true or not having flown only one such plane.  In my way of thinking, if the timer is capable of maintaining line tension and you have the power then side area of any kind is a minus.  True or just another brain fart?  ???
« Reply #2 on: June 02, 2025, 12:46:31 PM »
    It's a flat fuse side because it is easier to build and align, mostly because it doesn't require molds or a complex jig.
    Whether it is better or worse, or whether the drag on the side matters, is more to the root of the question. We used to think that making the fuselage side area smaller and less draggy reduced "whip-up", assuming the cause of whip=up was lift/drag on the fuselage. That is probably a small element, but a far greater factor is the difference in load and "dynamic soaring" sorts of effects that don't care about the fuselage very much.
     Whip-up is controlled in modern IC engine airplanes by pipe regulation and low pitch/high RPM engines, and overall parasitic drag to reduce the overall change in drag due to load factor variations from top to bottom. For feedback electric systems, it appears (as a semi-outside-observer) that the you still have the same basic problem, but have different ways to deal with it. While it looks to me like the very best feedback systems (Igor's "new" controller) handle acceleration pretty well, they don't do nearly as well with velocity, whereas IC deals with velocity (and airpseed-induced load variation) very well, and not as well with acceleration. I think this is the root of my previous observation that IC seems to handle certain situations (high velocity smooth wind) better, overall, than electric, and electric is absolutely killer in others (like dead a, where none of these whip-up effects are present).
  So, it depends on what your underlying premise might be, whether the drag or side area matters.
« Reply #3 on: June 03, 2025, 06:38:16 PM »
For peasant stunt , I think the best thing to use , is side mounted , tank inboard of the NVA .
As in the spraybar goes through the intake outside of the case , rather than through the case .
That way the nose is thinner in profile ! .  S?P
« Reply #4 on: June 04, 2025, 04:59:01 PM »
Just on observation I doubt it makes a ton of difference.    But the amount and distribution of side area does, in my opinion.  The airplane isn't sitting still in the wind and much of the side impact wind is deflected rearward by the prop blast.  It still has effect.  I think side area has more importance when the airplane is flying high-above the 45 degree being used as a lifting surface to some degree.    This could amount to maybe 150 or more square inches of lifting area.   In that case the flat sides are probably more productive at keeping the airplane out and up there.   That's why I also still like my rule of thumb- at least 25% of the area in front of the CG so that rear end area doesn't work in a negative way against you.
The current trend at least in FAI are very shapely airplanes.   That isn't for aerodynamics but cosmetics.....
Online Howard Rush
« Reply #5 on: June 04, 2025, 08:27:09 PM »
One might consider feeding back ESC output current in one’s motor control system.
« Reply #6 on: June 04, 2025, 11:35:18 PM »
    Good idea, a decent analog of engine load - faster, less load. It's a bit tricky because you would have to subtract it from the "commanded current" from the controller, or it would react to its own actions. Tim and I were talking about pitot tubes earlier tonight, but I don't know enough about pitot tube dynamics to even guess if that would work.
    Maybe my blimp airfoil is OK after all.
« Reply #7 on: June 04, 2025, 11:58:34 PM »
   As far as that goes, speaking only for myself, my fuselage is designed to have a large amount of passive yaw stability and minimize sideslip, particularly slideslip from precession/power handling. That was a design goal dating back the ST46/60 days. In that, it also has the effect of reducing/minimizing any sort of lift in +-Y, since it is always trying to drive the AoA to zero. This has interesting effects at times, the only really serious problem being entering the wingover or overhead, since it want's to follow the relative wind vector - from the vector sum of the airplane motion and the wind - so it tends to yaw nose-out upwind and yaw nose-in on the downwind side.
      The latter is definitely a positive, it relieves some of the line tension in the "low" maneuvers. The former, you might think would be an advantage, by increasing the line tension on the upwind side. That it does - until you try to turn a corner upwind, then, the sudden added tension of moving the controls, whips the nose in a bit, the airplane slows down and thus increases the angle of the relative wind vector, so it tends to yaw back and forth a few times on the way up. The workaround it to be very careful not to hammer the corner too much.
      If you look at the Linheart Smith picture of my airplane starting the wingover at the 2006 NATs, you can see this effect, it has already whipped in and then rebounded nose-out. The wind was not particularly strong, maybe 5-8 mph (it got a bit more later). And you can also see that these upwind corners, which looked bloopy marshmallow soft to me by design, is still pretty snappy. The fuse is vertical at maybe 12-15 feet and you can see that there is still substantial control deflection (which is going to be snapped out of there as fast as my little fingers can move a few tens of milliseconds afterwards).
« Reply #8 on: June 05, 2025, 01:48:39 AM »
Yep . To big a fin , and they weathervane nastilly , upwind . And Down .
theres a thing about side area Fwd. to help keep the nose up , in overheads . Eights & the like .
« Reply #9 on: June 05, 2025, 12:55:06 PM »
      But that is also unstable all the rest of the time. Right or wrong, I am doing my best to not use the lines to restrain it in yaw (or roll) to the extent possible. Unstable or marginally stable systems require the lines to provide the restoring force. Igor posted a force diagram describing it, somewhere. here:
https://stunthanger.com/smf/at-the-handle/leadout-position-66742/msg684636/#msg684636
    The problem with using the lines to stabilize an otherwise unstable system is that it keeps trying to push on the lines, which rings them up, and goes completely unstable if you get enough upset to lose line tension entirely. Putting in intentional nose-out yaw aerodynamically, stable or not,  (i.e. rudder offset) causes the airplane to yaw around as the the line tension changes, and also, heavily couples the axes due to the products of inertia trying to rotate around an skewed axes.
   Again, this is just my approach, I am sure there are legitimate differing opinions - and lots and lots of stunt BS.
« Last Edit: June 05, 2025, 11:29:01 PM by Brett Buck »
« Reply #10 on: June 05, 2025, 06:31:59 PM »
I learned the hard way NOT to make large radial cowls for stunt in the wind-and it didn't take much.    I'd like nothing better than to make a series of radial engine semi- scale airplanes.   You can sort of fake it with an oval shape to a degree but they are like a large mouth that gets hooked and pulled by wind gusts.   Even if you make large exit air openings it does little to solve the issue.   If you can incorporate a large spinner which deflects a good portion of the air you can get away with it to some degree.   There just weren't many radial fighters with large spinners.   Massive power with large engines might overcome some of it.
Online Igor Burger
« Reply #11 on: June 06, 2025, 01:26:40 AM »
This is very complex stuff. No only shape, but also area distribution, LO position to that shape, thrust offset and especially SIZE of the model. I think I wrote something about it in the past when we developed indoors. That makes it very very visible.
Since one thing will work on large models flying on long lines at relatively high speed as Brett wrote:
It will not work on small models:
Those indoors have little larger nose area than necessary for neutral yaw stability (as I used on my MaxBee which is designed only microscopically stable, but controlled by ridder). Plus they have LO position aproximately 20 degrees aft of the CG position. Result is permanent 20 degrees in-flight yaw making enough fuselage area to make safe line tension overhead (remember the lap time is equivalen of lap time of large models - it is designed to teach kids all figures -or even slower) on only 5m long lines. Centrifugal force (centrifugal acceleration) is far smaller than Gravity, so line tension is really maintained by only fuselage lift and motor thrust.
That extra nose area is necessary in case when modes slows overhead, lower line tension stabilizing yaw will cause nose yaw even larger so that prop thrust will cover lower fuselage lift during slow flight. Who tried those models, will tell you funny effect, that since you must run when model stalls overhead, indoor pilot can simply wait and it will once go over the head.
Those models do not have articical yaw stabilization by controlled Rabe rudders, so result is some yaw problems because of precession of that large 10" props and especially by corners causing inward yaw (I am not sure with english terms - inertial torque caused by rotating around non-pricipal axis ?)  But looks like it does not have too much problems in turbulence free air in gymn, pilot can easily adapt.
An now to the point - we tried to fly it also outside in little wind. It was very surprizing that wind does NOT accelerate it like large models, it slows it. And it does to the point that flying is impossible, it will simply stop on tops of loops. Later we found that it is much easier to fly on upwind side, where wind DOES accelerate it. It is caused by that extreme permanent yaw, the fuselage works like wind mill in the air. The same will work also on large models (that why I use relatively large yaw angle on my MaxBee = LO far aft of standard settings), but it work only little bit on large models. May be I had to write some paper about all of that, but retired people have very limited time during days :-P  Most of that is already distributed on this forum, or it was onstuka, may be it is ebough just collect some knowledge base from such threads.
That means something else will work on large models, somthething totatlly different on extremaly small models and something different somewher in between.
« Reply #12 on: June 10, 2025, 12:51:25 AM »
Champs this weekend , blustery rolling turbulant air . ( cancelled after one round )
All were bouncing , rocking & rolling  .
The Square ( Fuse ) ships more sharply perhaps and the round more smoothly . But ALL to the same extent . more or less .
These were faster / sharper - so maybe less duration . The better adhearance  ? or the atmosphere to the rounded ( Yatsenko owners club ) planes perhaps gave greater duration of the shudder & shock ,
the amplitude being pretty much equal . tho Id say the snappier action of the square things gave it 10 % less , but sharper . The less instantaeneous bit made the action less sharp on the rounded suckers .
In Roll , the Sq ones might have been shifting more degrees .
this is when the all got caught in rottery whirling cross winds . Casual observation - as indrawn spectator breaths had you automatically looking to see what was up .
that there was Saturday , F2B . the Combat Flyers over nearer the gum forest , were saying it made a differance , being blown about at times .
Monday , The Classic were in a bit less wind , tho Franks Bearcat ( with a Satio 72 was rocking & corkscrewing , The Gypsy less significantly , or signficantly less .
The Lighter O T S stuff were bouncing & rocking / yawing . the snappier sharper trip again . Had me thinking they FLEW more back then , and allowed for ' all weather ' flying . sharp Controls .
most of em were brave in frontingt up to it , and got a lift out of it . Adrenalin , sense of achivement , overcoming the odds etc .
The More expensive F2B stuff in the bit stronger conditins , hadem wondering if it wernt a lottery , so topssed it in before there were to many holes in the ground .
SO , if you wanna give it heck in a gale , CONTROL AUTHORITY  is the key requirement . And a 17.5 to 20 a Sq ft loadings gunna giveit better ' penetration ' , tickly if you cock up .  :-X
Horsepower To Match .
Probly the low pitch prop bit come about  as SILENCED you dint get the instanteaneous Load Responce of a olde nitro burning fire breather . The gotta get the revs up now , for em to snap about like that .
had me thinking I need to resurect the low sleeve HP Rear Intake , And Chop the middle out of the Big ( 66 inch ) folkerts wing . BUT , th3e tape measure says 57 or 60 if I do , AND the Caudron 561 drg. was tucked in the wing . So We'd still need mega grunt . was fine last time in a blow . But lost a few blades next time out and spontaeneously disentegrated the fuselage .
So , another POINT is when its working ( the prop ) like that . the Loadings on the prop , Shock & stall , are double too .
Last point being I cant get a 30 or 36 inch C F Helicopter boom , for a aft fuse . And a Kiwi won the event centuries ago , or last century , when it was unflyable ( Half Field destroyed ) with a Combat Wing .
« Last Edit: June 10, 2025, 01:10:17 AM by M Spencer »
« Reply #13 on: June 10, 2025, 01:19:49 AM »
SPEAKING OFF WHICH
Four types of local winds are sea breeze, land breeze, mountain breeze, and valley breeze. The sea breezes and land breezes are opposites, with sea breeze occurring during the day and
So , Again , Its WHAT is WIND .
This bloke seems to be having fun ,
up to a point .  :(
Brings up wind Flyer Gene romero , um - Shaefer , and his Hallmark . FUSELAGE SHAPE . And John Havle's Folkerts . Designed as a ' wind capeable ' ship . Both similar side profile . They mustve considered APPROPRIATE .
« Last Edit: June 10, 2025, 10:27:45 PM by M Spencer »
« Reply #14 on: June 11, 2025, 11:04:35 AM »
  Right. People did a lot of things in the past that they thought were good ideas, which have later been superseded by other, newer, ideas. The "skinny fuse" thing for "better wind performance" was one of those.
« Reply #15 on: June 13, 2025, 07:33:20 PM »
Seeing ' wind ' , ' round fuelage ' , & ' wind ' were mentioned !
essentialy , eliptical cross section . bar the mullet head top front. which I got wrong . full Size the tops just narrower than the curved sides . steps out over the exhausts .
Tony Effilanders ' Freebird ' twice U K Nats winner , was designed for the wind . As was the Smoothie/y ? . But former & Tango were where it was cribbed from .  Tango
primarilly .
The Video , He is on DOWN elevator , where the Gyro's Nose In . Any sharp control movements , gets sharp Gyro reultant . POWER helps tho , looked like he was battleing .
This thing , A few experimental things , The Elevator Aerodynamic Balances . Ends of stab. move with elevators to counter loads . So its ' trimmed ' in the rounds , and snaps into squares . Usually . *
A 10 mm Aluminum Tube Pushrod,  about 1.5 m.m. wall . Tho its not heavy its not light . Was something like double the heavy ! C.F. one . So thought ' Why Not ' .
The '  G - control counter balance ' being thought about. Full Size , C.G. aft , at speed , a pilot could pull excess G with divergance . It would ' overturn ' putting a weight that neutralised the controls under G was the remedy , at that time . Mk IX or VIII Spit . SO , in use ; puttering , in calm , the weights discernable . You can fell ' throwing it ' at the lines. In Squares . If you pay attention . SO , in the Rounds , it sits where set
and tends to keep deflection as set . Being a  ' handle input ' load , it gives a sort of measure of corrections , when altering of its ' set radius ' ( Corrections for eggig in steady smooth wind , etc ) and I think worth
its weight , as there are benifits. Counter to lightest pushrod attainable .
Bugbears were three inch ( o.k. 2 3/4 I think , baloon . Youd feel the tailplane snap thru the wheel wake , halfway down , on hard inside , squares . ( Which a Veed tail;plane isnt IN the wingwake altogether . to
sidetrack .
Horns were Dual 3 ? 32 ' K ' --- centerline ( horn ) at the flat across dual center , so horn has two adjacent 3/32 holes for the wire . Elevator prety stiff tosional . side to side . the Longer cross piece on flaps allowed greater side to side ' twist ' . But ONLY the same of 98 % of planes ive checked since . A few being 20 degree under soft thumb twist , both held . Most are say 8 Deg. under a excuseable on somebodyelses plane twist .
AND the Balsa was New Guniea Jungle Balsa . So the lightish tailplane was as stiff as rocks . Quater Grain all surfaces . Tight close quatergrain darker than the average balsa . Now you know .
This thing ripped round in gales . F2B pattern . Regularly . 20 to 30 marine  forcast often per season . Coastal . THEN the stiff cold air across  the deck ( Field ) could ' layer ' it , holding it down .
FULL UP aproaching downwind , im pretty sure the controls were held flkat , til a bit past downwind . Which can throw your timimig . ( Mannels placement advice proved out ) Presumably the
wire was where the give was , as there was none elsewhere . And hence the 2 mm steel bellcrank . ( Scaled up reversed Brodak Alloy offset type ) .
The Lines , in a gale , could thrum , just one. .018  7 strand steel  . At the square outside lowers , and inside lowers , Control Posn. variability in rounds was Via the lighter side , as you ' anchored ' through the other .
Never looked like hitting the deck . Till the rear wire off pushrod split bending for neutral . Sounded like the engine graunching, flying it . Till it SNAPPED . Bother ! .
Once , Id looped 3/4 ounce of lead , around the outer tip . Way Steadier , like a normal ' stable ' one . Till t fell off in the squre bottom , and got toeyer again . Left it off . So technicvally was underweighted in the tip .
For the Record .
Could need both hands and feet / heels kicked into the turf , or it'd pull you . On occasion . Above 25 K. say . So we found some spiked golf shoes .
Point Being . Elip. Fuse . Hurumph . Mainly for cleaner sharp turn. ?   the WING LAYOUT is obviously  efficent at higher winds , for consitance / workability / tension . A profile for comparison . And Urtnowskis is square .
Thereabouts . ( Box Fuse . )
« Last Edit: June 13, 2025, 11:49:47 PM by M Spencer »
