  • August 02, 2025, 04:29:28 PM
Author Topic: Design of adjustable elevator  (Read 2185 times)
Offline walterbro
  • walter brownell
« on: October 23, 2009, 09:50:29 AM »
 I have tried several adjustable ways to set elevators relative to flaps.
none have been easy to use. I would like to design a really easy to use
system that is safe for high wind conditions and long life. There may be
some posts on this that I did not find. Can some one steer me to a system
that really works and has been tested?
Sincerely,
 Walt Brownell
Re: Design of adjustable elevator
« Reply #1 on: October 24, 2009, 09:50:38 AM »
What have you used and what did you not like?
A slider on a slotted horn is about as easy as it can get.
Offline walterbro
  • walter brownell
« Reply #2 on: October 24, 2009, 11:12:17 AM »
Hi Keith - I have tried a slotted horn and that is OK for changing ratio
of elevator to flap movement. It doesn't help when you need  to adjust
a change in  the neutral position. For example, add a little down elevator
to eliminate inverted flight waviness. It may also be required when the moisture
level changes the fuselage length. The change in length of the pushrod is
what I want to do in an easy manner that is safe for the life of the ship.
Sincerely, Walt
Offline PerttiMe
« Reply #3 on: October 24, 2009, 01:02:03 PM »
So you need adjustable pushrod length. I think RC pattern flyers have been using threaded pushrod ends and clevises for a long time. Something like this:
http://www.centralhobbies.com/control_linkage/pushrod.html
Offline rustler
« Reply #4 on: October 24, 2009, 02:32:37 PM »
Tom Morris components assembled to his instructions give you adjustable pushrod length.
Ian Russell.
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #5 on: October 24, 2009, 05:24:05 PM »
Yep, just order a reverse thread insert and it makes the pushrod into a turnbuckle, easily adjusted with a small wrench. In a pinch the car guys also use a 4-40 reverse thread. Think it's a steering part that has a standard thread on one end and reverse thread on the other with a small hex in the middle. Problem with it is the hex part is so small you have to buy a special wrench.
Offline walterbro
  • walter brownell
« Reply #6 on: October 26, 2009, 07:54:42 AM »
Thanks Guys - I have found Tom Morris's "Nifty New Product" . This allows you
To adjust neutral and throw ratio through one small hatch without disconnecting
anything. This is what I wanted.
Sincerely, Walt
