  • June 15, 2025, 03:38:32 PM
Author Topic: Engine size vs. Plane size  (Read 2844 times)
« on: November 17, 2012, 02:05:07 PM »
This may belong in the 1/2 A forum.  But I'll ask it here, anyway.
I just got a recommendation that a Pat Johnson Ringmaster 207 (with a 207 square inch wing) would work well with a McCoy or Cox Black Widow 049.
Yet, I have a plan from 1954 for a CL flying boat that calls out a K & B 19, and has a 250 square inch wing.
Why such a small difference?  Is it just that the predicted weight of the RM 207 is around 10 oz, while the Aquabat looks like it'll be around 20oz all up?  Or is a Black Widow all that more powerful size-for-size than the K & B?
Or what?
Offline Jim Thomerson
Re: Engine size vs. Plane size
« Reply #1 on: November 17, 2012, 03:11:15 PM »
I am beginning to think that weight, or, maybe more accurately, wing loading, is the important thing in determining power needed.  It is not the only factor, of course.  10 oz for a 207 square inch wing CL airplane sounds fine for something like a TD 049. I think it would need to be a couple oz lighter for a Black Widow.  As to the relative power to weight of a Black Widow vs a Torp 19, I couldn't say as I don't have appropriate engine reviews at hand.  I've flown both engines CL and find them difficult to compare.  The Torp 19 is a powerful engine (held the A CL speed record at one time).  I think the one I had would have easily flown the stunt pattern on a large Flitestreak.
The Aquabat might need more power to get off the water.   I think a 20 oz large Flitestreak with a Torp 19 would fly very well. but I would think the Aquabat more a sport model. Also, a 250 square wing is almost 25% larger than a 207 square wing.
Thinking about it, I'd probably take each airplane as an individual situation and do very little comparison with other airplanes.
« Reply #2 on: November 17, 2012, 04:28:09 PM »
Hi Tim.  Jim is right on about needing the power to get on step and off the water-in a half lap or less.  If you look in the magazines of that era there was more emphasis on speed (since stunt capabilty was marginal I guess).  Many airplanes seemed overpowered, said from a guy who puts a piped .61 in a .40 size airplane today!  I have a Torp .09 on a OT FF Megow Ranger that does a job about like I think a Tee Dee .049 would.  As a kid I had the Torp .23 in a junior Nobler that seemed like the perfect package. I always thought the Jr. Flew better than the full-size Nobler. (What did that have to do with anything?). Anyway,  engine up for the water!  Have fun with it!
« Reply #3 on: December 09, 2012, 01:27:35 PM »
Hi Tim,
There is so much to consider like Jim and Dave say.  The RM 207 was expressly designed with 1/2A power in mind.  Drag (the different types I don't know much about), wing loading, and other factors I am less knowledgeable about, all must be considered when picking an engine for a model.
I do know that many times a smaller "modern" engine will fly a model designed for a larger one.  And people will always work out ways to put larger engines into smaller models.
(personally, I feel that the McCoy/Testors .049 will be a touch small on the RM207)
BIG Bear
RNMM/AMM
Offline Timothy Payne
  • Mr Payne
  • Classic Racer
Re: Homebrew Fuel
« Reply #4 on: May 09, 2013, 04:31:59 AM »
Come on you Glowheads! Let us know any ideas/formulae you have up there for making that 1 gallon can last over winter?
« Reply #5 on: May 09, 2013, 09:35:24 AM »
Or what?
     Or what, mostly. Pat's is a stunt plane, the flying boat may have been touted as a "stunter" but that might mean it can do a loop.  1/2A's at the time had incredibly feeble power compared to something like a Black Widow. All of the Cox engines were an amazing improvement over the Infant Torpedo and the like.
Online Trostle
Re: Homebrew Fuel
« Reply #6 on: May 09, 2013, 03:06:49 PM »
Ah, I will take a stab at this and will try not to be too technical.  To make a gallon of fuel last over the winter, live somewhere North where there is a lot of snow, is really windy and really cold.  Another solution is to not fly very much in the winter.
« Last Edit: May 16, 2013, 03:52:06 PM by Trostle »
Re: Homebrew Fuel
« Reply #7 on: May 09, 2013, 04:02:52 PM »
Ah, I will take a stab at this and will try not to be too technical.  To make a gallon of fule last over the winter, live somewhere North where there is a lot of snow, is really windy and really cold.  Another solution is to not fly very much in the winter.
Or switch to electric!
Online Trostle
Re: Homebrew Fuel
« Reply #8 on: May 09, 2013, 04:09:01 PM »
Tim
I was trying to not make my answer too technical like you just did.  But technical is OK.
KT
