  • June 13, 2025, 07:48:59 PM
Author Topic: different size flap  (Read 2204 times)
Offline bob whitney
different size flap
« on: April 25, 2025, 04:12:30 PM »
what happens if the out side flap is 2 in shorter than the inner flap
rad racer
Re: different size flap
« Reply #1 on: April 25, 2025, 05:45:53 PM »
likely hinging - Ken
Please don't tell me you put flaps on an All American Sr.
« Last Edit: April 26, 2025, 07:52:14 AM by Ken Culbertson »
« Reply #2 on: April 25, 2025, 07:05:09 PM »
  I'll say that what happens depends on the chord of the flap, and how much it deflects. The inboard wing tip is flying a shorter distance and slower than the outboard, and if the outboard flap is shorter near the fuselage, it can have an some influence.
   Next question is, how did they get that way??
« Reply #3 on: April 25, 2025, 07:31:41 PM »
   You end up putting a gigantic tab on it?
« Reply #4 on: April 26, 2025, 07:36:56 AM »
Sounds like something that might have happened in the earliest days of stunt where the thinking was that the inboard wing needed to carry the weight of the lines so had to generate a tremendous amount more lift than outboard-ala the All American.   You sure would have zero tip weight.  It would be a task to trim this thing to anything like modern standards.  If it were a modern mess-up,   fix it.  I actually have a slightly larger outboard flap at least in chord width (3/32").
Offline bob whitney
« Reply #5 on: April 26, 2025, 02:58:49 PM »
i am not aloud to be in the same room with any measuring instruments
rad racer
« Reply #6 on: April 26, 2025, 08:40:22 PM »
   So what you are saying is, you cut it off twice and it's still too short?? Measured once and cut thrice?? That ok, we still love you RAD!!
Offline bob whitney
« Reply #7 on: April 27, 2025, 09:10:26 PM »
who needs stinking plans, RAD
rad racer
