  • June 15, 2025, 04:25:55 PM
Author Topic: Unusual design features  (Read 3438 times)
Offline Chris Edinger
  • Hawker Hurricane
« on: March 10, 2008, 08:31:13 PM »
Being lost in the 70', I see some interesting design features in the Avanti II I am building....the plans call for crankcase cooling ducts.. one in front,,, into the engine compartment... and two exiting from the engine compartment thru the side of the fuse ... the ducts measure about 1/4" OD.. that doesnt seem like much cooling to me...  the other thing is a larger horiz stab than elevator...in terms of thickness.. stab LE is 1/4" and TE is 3/8" covered with 1/16" sheeting... so.. the TE of the stab is 1/2" meeting up with a tapered 1/4" elevator... i assume it is to make the air flow.. above the elevator for some reason.. is this a viable design ????  I understand that this design won at the nats for Baron...  any feedback on this??  Thanks in advance..
 Chris
Lee's Summit MO
AMA 896082
Offline L0U CRANE
Re: Unusual design features
« Reply #1 on: March 11, 2008, 01:15:54 AM »
Chris,
The wider thickness at stab TE, than elev LE, style has been used since at least the time Baron came up with the Avanti, possibly earlier. Thee are claims that the wake off the thicker TE 'masks' the first few degrees of elev motion, or something like that. I.e., less sensitivity off the neutral mark, so less jumpiness around neutral, with no loss of effect at larger angles.
I always shudder when any of us say that a DESIGN won the Nats or any major meet. The model had to be flown by somebody... Some relatively unpromising "designs" have done very well, because of who flew them. The loose nut at the slow end of the lines is as important, probably more so, than the properly tightened nuts and bolts at the fast end of the lines. Bob B was an exceptionally GOOD flier...
Like the NYC joke about how you get to Carnegie Hall: " Practice! Practice! Practice!..."
\BEST\LOU
  • Hawker Hurricane
« Reply #2 on: March 11, 2008, 04:55:22 AM »
Lou... I whole heartly agree with you regarding the flyer..but design always plays a part... and the flyer designed that feature in to his ship... I have just never heard of it.. and was curious as to its function... Thanks...
Lee's Summit MO
AMA 896082
« Reply #3 on: March 11, 2008, 11:51:28 AM »
Actually, when Bob won the '96 NATS he was flying a slightly modified Patternmaster with a ST 60.  I launched him a few times in practice.  It wasn't an Avanti.........
« Reply #4 on: March 11, 2008, 01:03:42 PM »
Chris, crankcase cooling can be important.  Part of the "runaway" problem is due to the crankcase getting hot and reducing the charge(leaning out) going up to the combustion chamber.  sometime when running your plane, before it takes off touch a finger to the bottom of the crankcase.  In almost all cases the crankcase and main bearing will be cool to the touch.  The crankcase cooling on the Avanti is intended to keep the crankcase cool and eliminate one more reason for the engine to misbehave.
  • Hawker Hurricane
« Reply #5 on: March 11, 2008, 06:39:10 PM »
ahhhh.. makin more and more sense now.. I understand the need for crankcase cooling.. I was curious as to the diameter of the tubing.. is 1/4" enough and that appears to be OD... as for Bob winning with the Avanti...I garnered that from a post on here somewhere.... Its cool to see the improvements in technology since ive been out of the hobby,,, I Bought a Tom Morris Bellcrank for it ... lots of difference there too. Its always been fun to build.. but its even more exciting now... thanks for the input...
By the way... i read a post somewhere about a plane that had a 1/4" Longer Outboard wing  a Teoswaki i believe... and it was supposed to be better than the longer inboard wing.. has anyone tried this on one of their planes??
Lee's Summit MO
AMA 896082
« Reply #6 on: March 11, 2008, 08:23:12 PM »
Chris,
There are several TEOSAWKIs in the air.  All have the longer outboard wing... Clayton builds them all.
The misunderstanding over Bob winning with an Avanti might be because he shaped the fuselage much like the Avanti.  But is was a full size Patternmaster, and was not inline.
Bill <><
Offline Al Rabe
« Reply #7 on: March 28, 2008, 08:32:13 AM »
Chris,
The wider thickness at stab TE, than elev LE, style has been used since at least the time Baron came up with the Avanti, possibly earlier. Thee are claims that the wake off the thicker TE 'masks' the first few degrees of elev motion, or something like that. I.e., less sensitivity off the neutral mark, so less jumpiness around neutral, with no loss of effect at larger angles.]
I don't know who used this empannage configuration first, but it happens to be the configuration used on my 1972 and 1973 Nats winning Sea Furys.  They were designed in 1970.  The stabs were built with a 3/8" core. The elevators used 1/4" cores.  they were all sheeted with 1/16".  A photo of these cores was in the "Go for Broke" Sea Fury article in March 1973 American Aircraft Modeler.
In the Mustang article "Evolution of a Thoroughbred" there is a photo of what became my standard stab and elevator construction.  My stabs are typically built using a built up spar consisting of a 1/4" x 1/8" balsa web with 1/16" x 3/16" spruce top and bottom spar caps.  The ribs are aerodynamically contoured, about 1/4" thicker than the trailing edge and about 5/8" at the root .  This gave the sheeted stab about 3/4" thickness at the root with 3/8" elevators..  This was a 1973 design, and the configuration I still use today.
This stab/elevator configuration wasn't detailed in the articles as I didn't see anything that unusual in them.  It was a full scale aircraft practice and only seemed worth incorporating on stunt ships.
The intent, of course was to soften elevator response around neutral using this configuration instead of the then more common practice of using "slop" in the elevator horn bushing.
Al
« Last Edit: March 28, 2008, 09:37:31 AM by Al Rabe »
Offline rustler
« Reply #8 on: March 28, 2008, 03:33:43 PM »
I've never quite been convinced about the working of this "thick tailplane/thin elevator" theory. Using my own ignorant layman's understanding of aerodynamics, when all is said and done about t/p's, what makes the plane go up and down is a pressure differential between the topside and underside of the elevator. Up elevator leads to increased pressure on the topside which pushes the t/p down which points the nose up. I suspect a thinner elevator is not working in some sort of shielded environment which renders it less effective due to being shielded by a thicker t/p. Certainly the airflow will "rareify" a bit as it spills past the hinge line, but the degree of rareification must depend on the angle of the elevator. If there is any +/- angle to the elevator it will affect the degrees of rareification (i.e. pressure) above and below the elevator and therefor give a definite up or down control input.
Well, I know what I am talking about anyway.
Ian Russell.
  • Hawker Hurricane
« Reply #9 on: March 28, 2008, 07:47:45 PM »
Al
Thanks for the information...  very enlightening ...It makes sense now.. and I am building the plane as per the plans.. Its interesting that this is a product of the 70's  as I seem to be finding out.. many things are but highly refined in todays modeling..
Thanks again to everyone who posted to help me with my questions
Chris
Lee's Summit MO
AMA 896082
« Reply #10 on: March 28, 2008, 08:57:29 PM »
Regarding crankcase cooling:  All the really "hot stuff" is happening above the exhuast port, the bottom of the cranckae is actully gettng cooling by the constant flow of fuel through the crank.  Nest time you have an engine running on the bench CAREFULLY reach around behind & underneath the case, it often will feel cooler than ambient.
However, heat rises. On a inverted cowled in engine that heat can rise and basically get trapped by stagnant air around the crankcase.  Poking a hole in there lets the heat keep rising right out - probably pumped out by some left-over cooling intake air.
Empirical data suggests some engines/installations seem to respond to it more than others, but putting an exit vent pretty well settles the issue!
« Reply #11 on: March 28, 2008, 09:38:53 PM »
There is a nice little single seat light plane designed by a man named Molt Taylor, called the Taylor Monoplane. It has a very thick stab, and a much thinner elevator.
Small single seat racer types typically have super sensitive reactions to stick inputs. I have flown a few different designs and know it to be true by personal experience.
This Taylor Monoplane is very tiny, yet the action of dampening by this aerodynamic technique keeps the pitch sensitivity to the level of an airplane with much longer moments.
Because there are many designs that have flat plate control surfaces, one cannot dismiss control surface deflection as a part of the total aerodynamic action taking place.
This, along with Al's, Bob Whitely's and many more designer's using the fat stab/thin elevator technique, has convinced me that it works.
Chris...
  • Hawker Hurricane
« Reply #12 on: March 28, 2008, 09:46:55 PM »
Dennis
I kinda figured on the basic air movement over the engine.. but never gave much of a thought to the inverted engine senario.. and the outlet ports for the ventilation are higher than the engine..... I just finished carving the ventilation ports this evening... Thanks much
Chris
Thanks too Chris M.    All you fellas are quite helpful...
Lee's Summit MO
AMA 896082
Offline John Miller
« Reply #13 on: March 29, 2008, 11:42:30 AM »
For the last 10 or 15 years, I always showed a thinner elevator section, vs's the stab, for the very reasons mentioned in this thread. It does indeed work to soften the controls around nuetral.
I do believe there's a drawback to the practise though.
As I gained more experience, I found it difficult to do extact transitions from insides to outsides in the Eights. I had to anticipate the intersection or I would tend to get a flat spot, and the outside tended to be larger in radii than the inside.
Lately, at the suggestion of my mentor and flying buddy, Gordan, I started going to 3/8" stabs and elevators. We found that by utilizing proper incidences, as suggested by Bob Whitely, and, building as straight as we could, that the plane will groove very well without the slop, either mechanical, or areodynamic.
It became much easier to hit the intersections in the Eights. The transition from inside to outside were smoother, and resulted in even sizes between insides and outsides.
At least, that's what we found for us on our airplanes.
The latest plans I've drawn all show equal thickness for the stab and elevator.
Offline Gordon Tarbell
« Reply #14 on: March 30, 2008, 08:01:35 AM »
Are they airfoiled or flat? 3/8 leading edge and trailing edge or just 3/8 at hinge line?
Gordon Tarbell AMA 15019
  • Hawker Hurricane
« Reply #15 on: March 30, 2008, 06:58:19 PM »
actually... on this plane.. they are 3/8" at the LE.. and 1/2' at the TE.. the LE is sanded down and rounded and the TE is not sanded.. just 1/2"
Chris
Lee's Summit MO
AMA 896082
Offline John Miller
« Reply #16 on: March 31, 2008, 10:56:03 AM »
The shape of the stab leading edge, as well as the elevator has been so variable over the years. I've seen about everything from flat plate style, (only rounding of the edges) to beautifully airfoiled. There are adherents to about every scheme out there.
Some, in my opinion, seem to work better than others. Some years back Dave Fitzgerald, and others did a lot of testing on stab shapes, to the point that my personal favorite is an airfoiled stab, with a sharp entry point, and an elevator that straight tapers back to a sharp cornered 1/8" flat at the extreme rear edge. H^^
Offline Leo Mehl
« Reply #17 on: April 02, 2008, 12:07:39 AM »
I am not sure whether Thinner elevators and sloppy pushrod holes help anything. I think the most important part of any plane is how strait it is. The other thinks work ok but You have to trim the setup to work the way you intended. A lot of these things I have tried over the years and the only one that I think is worth while Is making the elevator thinner than the stabilizer. Onther thing that really orks good is positive incidence in the stabilizer. This was done4 by David fitzgerald so I tried it on my Odyssey. This plane really sits in the grove both directions.
« Reply #18 on: April 02, 2008, 02:33:25 PM »
Keep in mind(just for more confusion),  the stab is flying in the downwash of the wing.  The air coming off the wing flows downward(to produce lift)  very slightly down in level flight, probably 8-10 degrees down in a hard maneuver.  The stab incidence mainly lines the stab/elevator up with the airflow so that the stab is actually at 0 deg. to the flow in level flight.
Also, as the RC pattern guys have found, the relative position of the thrustline, wing, and stab, and even the size and shape of the fuselage profile, affect the airflow and the tendency of the plane to turn either towards the canopy or gear when the wing is unloaded, as in a wingover.  The common layout of a thrustline raised half an inch or so and the stab pretty much the same turns out to be very close to ideal to keep the handling neutral in a wingover.
Offline John Miller
« Reply #19 on: April 03, 2008, 02:28:23 PM »
Leo,
Like you, I no longer like the idea of sloppy controls to mask or "fix", a flying problem.
Since I've been using down and a little right thrust, coupled with slightly possitive incidence at the stab, I've not felt the need for loose, sloppy controls, or the need to use a thinner elevator.
Straight airplanes, with proper incidences built in, usually fly great.
