Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
June 15, 2025, 06:39:50 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
Airspeed and line tension on top of circle
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Airspeed and line tension on top of circle (Read 3012 times)
Peter Germann
Trade Count:
0
Captain
on:
July 07, 2017, 05:48:22 AM »
With centrifugal force changing with the square of speed, overhead line tension primarily depends of the actual speed of the airplane when it flies along a wingover path through the top of the hemisphere.
One may assume that this speed is lower than in level flight, but does this take into account the reduction of induced drag resulting from the wing no longer generating lift in knife edge flight?
Logged
Peter Germann
Wolfgang Nieuwkamp
Trade Count:
0
Commander
Re: Airspeed and line tension on top of circle
Reply #1 on:
July 09, 2017, 02:50:08 PM »
Assuming that the lift in horizontal flight is 18 Newton, and that the span is 1,5m, the induced drag is only about 0,23 Newton. This is a small force compared to the drag of the plane and the lines.
Wolfgang
Logged
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Design
Stunt design
(Moderator:
Paul Taylor
