  • August 02, 2025, 05:29:12 PM
Author Topic: Finally got going.  (Read 7542 times)
Finally got going.
« on: October 29, 2012, 10:27:24 AM »
So, yesterday I finally got out in the shop and started drawing what I've been thinking about for the last couple of months. My first electrified plane. Pretty happy so far. Sort of combination of eras for me. It will be interesting, anyway. Should be light, too.
Offline Airacobra
Re: Finally got going.
« Reply #1 on: October 29, 2012, 11:17:37 AM »
Oh this is going to be fun to watch, love seeing your building and completion photos Randy. Good luck, Keith
Keith Bryant
« Reply #2 on: October 29, 2012, 12:18:11 PM »
Keith,
I hope to start construction in a couple of weeks. I have to finish drawing the thing.
« Reply #3 on: October 29, 2012, 12:53:54 PM »
Do we get to see sketches?
« Reply #4 on: October 29, 2012, 03:52:15 PM »
Tim,
Not yet. It's sort of a combination for my last ship, an idea I've had rattling around in my head for awhile and my Freelancer design along with some Heretic (and old design of mine - see my avatar) thrown in. Elliptical wing planform (sort of) and twin rudders with the airfoil and "numbers" from the Hooligan. Also some new stuff based on that rattling idea.
I should add that it's going to use a very different construction method than the standard layout. Again, a weird idea I've got.
Offline Allan Perret
  • Proverbs
« Reply #5 on: October 30, 2012, 05:55:55 PM »
Freelancer, Heretic,  Elliptical, twin rudders,  different construction.
I'm all in on this one, you selling plans yet ?    LOL
How about an open cockpit, that would make it complete for me. ~>
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #6 on: October 30, 2012, 06:03:01 PM »
Allen,
Ah, you could, I guess. I may have a clear canopy that will work, but if not, it will be simulated. Sort of a low rider look again, but very different from the first one. Sorta.
I'm sure Dennis Adamission will like it.
« Reply #7 on: October 31, 2012, 05:16:26 AM »
Allen,
I could say that sight unseen, will look forward to this one also...
Offline Airacobra
« Reply #8 on: November 01, 2012, 12:35:06 PM »
Ok that should indicate it will be a HIGH ASPECT RATIO WING AND IT WILL BE PAINTED PINK!!! ;D
Keith Bryant
« Reply #9 on: November 01, 2012, 04:21:19 PM »
Sort of and no pink. Sorry, Dennis.
Of course, as soon as I get going, stuff happens at work and I've been working late every night this week. I get off early tomorrow though and will be in the shop this weekend. Forecast is for rain with rain and rain all weekend so it's a great time to draw!!
« Reply #10 on: November 05, 2012, 12:44:25 PM »
OK, the plans are set. Just trying to figure out how I'm going to do things structurally. I've love to figure out a way to put the battery in without having to flip the plane over and I'm looking at a possible way to slide it in from the side without compromising the nose structure, but I have figured it all out yet. The wing and tailplane are interesting. Something I haven't done before. It's, ah, clever. Certainly it will be entertaining.
I really want to put big wheelpants on this plane too, but after my last encounter with them, I'm a bit nervous about it. It's going to be important to keep thing sucker light so I will probably build my cool looking wheelpants and a secondary gear with just skirts. I was shocked to see that I drew out a canopy (yes, real plastic) but thought I would probably have to do a simulated setup. Then, in rummaging through the canopies I have, found the perfect match. Go figure. I had also consider a fuse structure ala Al Rabe, but decided to go with fairly narrow fuse sides and molded top and bottom blocks.  I'm still thinking about wing structures but will use the tried and true Ted Fancher doctrine for the tailplane. Hope to have the plans done by the weekend and start building. I decided to put the classic plane I was finishing on hold and I'm pretty excited about this new beast.
Online Howard Rush
« Reply #11 on: November 05, 2012, 02:40:50 PM »
Allow for the battery to go higher than you think it should.
« Reply #12 on: November 05, 2012, 03:05:57 PM »
OK, the plans are set. Just trying to figure out how I'm going to do things structurally. I've love to figure out a way to put the battery in without having to flip the plane over...
Hold it over your head?
Online Howard Rush
« Reply #13 on: November 05, 2012, 05:31:26 PM »
That's not what I meant.
« Reply #14 on: November 05, 2012, 05:56:39 PM »
No worries!  I did mine, so I don't have to do any more.  I DID put a pink anti cancer ribbon on the last airplane, probably will do that again too...
« Reply #15 on: November 05, 2012, 10:32:25 PM »
And battery way farther forward as well,,,,the electrajet was carrying the cg nearly an inch forward of the "glow"calculated position.of course if you built it light enough the extra four or five ounces of nose lead won't matter all that ,much right
Online Howard Rush
« Reply #16 on: November 05, 2012, 11:31:03 PM »
Yep, forward, too.  More Mysteries of Stunt.
« Reply #17 on: November 06, 2012, 05:47:01 AM »
Or modify Dick Sarpoulis's Hanriot Biche to be a bit more modern, and load the batteries through the nose cone.
http://www.aviastar.org/air/france/hanriot_h-110.php
« Reply #18 on: November 06, 2012, 12:29:52 PM »
After talking to Mark and Howard previously, the battery in this thing will have a LOT of maneuver area. But far back and far forward. It won't be a battery compartment so much as a battery cavern. I have some ideas about battery mounting that should work well. But I am bowing to the Great Paul and using a rear mount motor.
Semi-elliptical wing and tailplane. Sorta. The key is going to be making it light. About 650 square inches and near the 50oz mark. We'll see, I guess.
Get ready for a spider-plane.
Offline Airacobra
« Reply #19 on: November 08, 2012, 06:48:28 AM »
I can't wait to see some balsa dust fly!
Keith Bryant
« Reply #20 on: November 10, 2012, 02:13:39 PM »
I'm on my way out now to finish the plans. then it will be time to clear the decks and start making chips.
« Reply #21 on: November 11, 2012, 07:52:55 PM »
OK, the plans still aren't quite done. I had to take some time out the a CAD program to figure a couple of things out. But I have that done and now can proceed. the nose will be interesting.
Hey Howard, I figured out a way to slide the battery both vertically and horizontally. I set it up with a pretty long nose to there will be quite a bit of range. I will depend on you to figure out an initial position.
Online Howard Rush
« Reply #22 on: November 11, 2012, 10:32:52 PM »
Give me the weights and positions of everything else, and I'll tell you where to put the battery.
« Reply #23 on: November 12, 2012, 07:12:54 AM »
...and you want him to put the battery WHERE????   :o   :X   LL~  LL~  LL~
« Reply #24 on: November 14, 2012, 12:07:46 PM »
In the nose of the plane, Dennis. In the nose of the plane.
And when I get there, I'll email you Howard.
« Reply #25 on: November 30, 2012, 11:12:00 AM »
Well, the plans are finally done. Sheesh I had a hard time getting this done. A lot of modeling to figure stuff out. Hope to copy the plans this weekend and get started.
Offline Shultzie
« Reply #26 on: December 04, 2012, 06:27:02 PM »
HEY AL RABE...KEITH TROSTLE! MOOOOOOOOOOOOOOOOOOOOOOVE OVER! HERE COMES RANDY WITH AN AWESOME SCALE STUNTMACHINE! H^^ BW@ HH%%
Don Shultz
« Reply #27 on: December 05, 2012, 05:26:16 PM »
Not scale except as a fantasy.
« Reply #28 on: December 05, 2012, 09:07:44 PM »
 When do we get a look Randy? #^
« Reply #29 on: December 06, 2012, 08:37:59 AM »
First time I looked at this part of the forum Randy as I do not design planes, but here it is December and you have not started the paint work yet?   Yes, I know it will be a simple paint scheme. LL~ LL~
« Reply #30 on: December 07, 2012, 12:38:33 PM »
Wayne,
As soon as I have something to show. I have the plans copied and templates cut out. Just need to get my bench cleared. Should happen this weekend and off I'll go. My take a pic or two as I get going.
Doc,
This plane is in danger of being a single color. And I have just the color in mind....
Offline Dave Denison
« Reply #31 on: December 09, 2012, 12:57:59 PM »
Come on now Randy, get that camera out and shoot a few pictures for us to see......inquireing minds need to know.
Regards.
  Dave.
ama 41041
ama 41041
« Reply #32 on: December 09, 2012, 01:18:56 PM »
Brother Randy,
I am overjoyed to see you "back at it".  Seems that we are nearly on the same wave length on getting back to work, albeit for different reasons.  Either way, we will all look forward to your new creations!
« Reply #33 on: December 09, 2012, 01:49:03 PM »
Dave, there's nothing to take a picture of yet. I have to finish the chairs today, then I can get at it.
Online Howard Rush
« Reply #34 on: December 09, 2012, 10:36:38 PM »
What chairs?
« Reply #35 on: December 10, 2012, 01:13:23 PM »
Howard,
I found some 1963 Ethan Allen oak kitchen chairs at a yard sale (they are stamped on the bottom). I am repairing and refinishing them for my son. Hey, woodwork is woodwork. Clear coat tonight and they are done and I can start building a plane.
Offline Mike Keville
« Reply #36 on: December 10, 2012, 06:03:05 PM »
. . . Hey, woodwork is woodwork . . .
Agreed!  I am currently sanding a couple of wood folding TV trays in prep for paint & clear coat.  It's all fun...and very satisfying.
Don't need to fuel-proof 'em, either!
Online Howard Rush
« Reply #37 on: December 10, 2012, 08:02:44 PM »
I'm building a particle board bathroom cabinet, which will be covered with Formica and be fitted with Thermofoil doors: the furniture equivalent of MonoKote.
« Reply #38 on: December 10, 2012, 10:06:30 PM »
Howard,
So ate they getting green candy before the clear ?
Oh and evacuate the bats first !
« Reply #39 on: December 10, 2012, 10:07:44 PM »
I just finished a kitchen remodel......hopefully I can now build an airplane
« Reply #40 on: December 10, 2012, 10:34:16 PM »
These are done to maintain the original look. They are, after all, antiques.
I have the jigs set up and will probably start in a couple of days. I have to put a new facet in the bathroom and do a repair on the sink itself. Interesting process, that. About half done tonight (the chairs are drying). Finish that tomorrow night and I can get on the plane. Pictures to follow in the building thread.
« Reply #41 on: December 13, 2012, 08:07:37 PM »
Doc,
Green?  LL~ LL~ LL~ Seriously, I'll look forward to seeing it. If you need a name for it, I'm available for consulting work.  y1 Steve
« Reply #42 on: December 14, 2012, 08:55:59 PM »
Thanks Steve. I just started it tonight. Finally. It may end up some sort of red but we'll see. I have been getting another idea entirely.
« Reply #43 on: January 05, 2013, 05:01:18 PM »
Randy.  You mention rear-mounting the motor.  Everyone tells me it must be front-mounted!
I'm having an awful time trying to mount my AXI2824/12 from the front. Not much to tie the firewall to.  Now thinking about rear-mounting, and just let it tear itself loose in flight (that'as what glue is for)
