  • July 11, 2025, 09:15:12 PM
Author Topic: Aeromodeller Engine mount article by Stuart Sherlock.  (Read 2931 times)
Offline Chris Wilson
« on: June 23, 2015, 09:00:31 PM »
Anyone read the recent engine mount article by Stuart yet?
Makes fascinating reading and leads me to believe that all beam mount model engines may be better off (from a vibration point of view) with the bearers above the lugs rather than below them Team Race style.
Thanks, Chris.
MAAA AUS 73427
Re: Aeromodeller Engine mount article by Stuart Sherlock.
« Reply #1 on: June 24, 2015, 03:50:42 PM »
On most engines, the tops of the beam mount casting is not machined level, or straight.  This is necessary to prevent undue stress on the casting.
« Reply #2 on: June 24, 2015, 10:46:15 PM »
Hi Floyd,
            if it was accepted that the bearers were better off at a higher location then I am sure that it would not be too difficult for manufacturers to machine the other side.
MAAA AUS 73427
