Design => Stunt design => Topic started by: Chris Wilson on June 23, 2015, 09:00:31 PM
Title: Aeromodeller Engine mount article by Stuart Sherlock.
Post by: Chris Wilson on June 23, 2015, 09:00:31 PM
Anyone read the recent engine mount article by Stuart yet?
Makes fascinating reading and leads me to believe that all beam mount model engines may be better off (from a vibration point of view) with the bearers above the lugs rather than below them Team Race style.
Thanks, Chris.
Title: Re: Aeromodeller Engine mount article by Stuart Sherlock.
Post by: FLOYD CARTER on June 24, 2015, 03:50:42 PM
On most engines, the tops of the beam mount casting is not machined level, or straight.  This is necessary to prevent undue stress on the casting.
Post by: Chris Wilson on June 24, 2015, 10:46:15 PM
Hi Floyd,
            if it was accepted that the bearers were better off at a higher location then I am sure that it would not be too difficult for manufacturers to machine the other side.
