Hi all,
I'd like some comments, on the 'correct' location for Adjustable leadout guides,
noticed some ( read a lot) of designs show the LO guide mounted in the tip rib,
this is fine if the tips narrrow i.e 1" block tip etc, but other larger tips are in the
3" ~ 4" range this is a decent distance from that tip rib
apart from the obvious line 'sawing' that could occur in this area, another thing is
how these 'loose' lines affect the models stability.
for mine I'd try & mount the LO guide as far as possible out in the tip itself , not
the tip rib
