  • July 06, 2025, 07:00:03 PM
Author Topic: ? about nationals stunt winning models.  (Read 3524 times)
Offline jim gilmore
« on: May 16, 2008, 02:24:54 PM »
I am curious. Of the conventional/or modern type P.A. national's winning models . What was the Largest model to win and what was the smallest model to win?
Offline gary tultz
Re: ? about nationals stunt winning models.
« Reply #1 on: May 18, 2008, 08:54:25 PM »
I think Werwage's P 47 Razor spans 63".Though not NATS, it did win WC in 04. Not sure of the spans of the T.P., Star Gazer,Impact and Infinity. I'm trying to go from 1990 up.  D>K
« Reply #2 on: May 19, 2008, 10:38:23 AM »
I'm thinking Bob Gialdini's Eclipse (1965) may have been the biggest in wing area.  The smallest post OTS era; probably Gieseke's Nobler, or (if you include Junior & Senior Walker Cup winners) Werwge's Ares (1959?) or Palowski's Atom (1958).
Offline jim gilmore
« Reply #3 on: May 19, 2008, 12:05:14 PM »
Thanks guys
I would think of modern as 1970 something.
I was thinking that Gene Schaffers' STUNT MACHINE, might be at the smaller end but wasn't sure. While Al Rabes' SEA FURY was on the large size. Though I was not sure if any other stunter were Bigger either in wingspan or pure mass.
I was curious if any small models have worked well enough to compete against the 40+ powered stunters. No particular reason but curiosity here.
« Reply #4 on: May 19, 2008, 02:03:56 PM »
I would imagine Windy's Russian Sweeper was the biggest in the modern era (and very cool, too), though he didn't win (placed 4th or 5th, I think). Paul's B-17 is more than 900 square inches, but he didn't win with it either. The Spectrum, Impact, TP, Infinity are all around the same size wingspan wise (within an inch or two), though I think the TP is around 660 squares and the Impact is near 700. Hard to tell the smallest, but I think the above is probably right. A Nobler derivative of some type.
« Reply #5 on: May 20, 2008, 05:21:00 PM »
[/quote]
The Impact is 675 according to Autocad by 6 decimal places. H^^
« Reply #6 on: May 20, 2008, 06:35:38 PM »
Thanks guys
(clip)
Your question was about the sizes of Nats winning airplanes.  Though Gene Schaffer and his Stunt Machine were a formadable combination, Gene never won the Nats.  He is often credited to be one of the best, if not the best flyer to have never won the Nats.  He did place first at one of our Team Trials.
Offline Jim Oliver
« Reply #7 on: May 21, 2008, 03:43:47 PM »
I don't remember the exact numbers, but for the last few years, the larger planes/engines have dominated the higher classes at the Nats-----according to the stats published in SN.  Larger planes would be 625 sq. in. or bigger; larger engines would be > .51.
Not sure this means anything, but is sorta interesting.
Cheers,
Jim
Jim Oliver
AMA 18475
Offline peabody
« Reply #8 on: May 24, 2008, 12:40:11 PM »
I would wager that ob Baron's Patternmaster as the largest to win.....
Probably the smallest recent winner was the Geiseke (?) Nobler....
« Reply #9 on: June 22, 2008, 12:28:03 PM »
I agree.
« Reply #10 on: August 01, 2008, 03:19:28 PM »
>>The Impact is 675 according to Autocad by 6 decimal places.<<
Depends on which one. Paul's last year's version (2007) was 750 square inches. They have varied between 675 or so and up to 750. But the most common one is the 690 square inch one. Pretty much the one he is currently flying at the World Champs.
Offline Jeffrey Olijar
« Reply #11 on: September 26, 2008, 12:20:46 AM »
Is there a limit to how big or small the airplane is?
If it ain't broke, fix it till it is.
Offline Jim Oliver
« Reply #12 on: September 26, 2008, 08:35:00 AM »
On the AMA site, I see a weight limit of four pounds for control line models.
Didn't see a size limit, but could have missed that part.
Cheers,
Jim
Jim Oliver
AMA 18475
« Reply #13 on: September 30, 2008, 01:01:43 PM »
Cheers,
Jim
Paragraph 8 of the General Control Line section of the AMA rulebook states "Unless otherwise permitted under specific event rules, no Control Line model shall have a flying weight of more than four (4) pounds."
In the Control Line Precision Aerobatics section of the AMA rulebook, there is a statement at the bottom of the line size and pull test chart that states "Maximum model weight is 3.5 kg (7 lbs, 11 0z)." Also, Paragraph 2.4 also states "Maximum model weight including any batteries but excluding fuel is 3.5 kg (7 lbs, 11oz)."
It is sometimes worthwhile to read all of those areas of the rulebook that affect this event.
(edit for typo)
Offline Jim Oliver
« Reply #14 on: September 30, 2008, 02:01:30 PM »
Keith is correct----and I should have posted all the info concerning weight, or none of it. :-[
At only 6 feet and 200 pounds, I ain't quite big enough to fly a 3.5 kg. CLPA model........... :o
Cheers,
Jim
Jim Oliver
AMA 18475
