  • July 12, 2025, 06:51:20 PM
Author Topic: 4" Bellcranks.  (Read 21368 times)
Offline Chris Wilson
4" Bellcranks.
« on: October 11, 2010, 09:50:22 PM »
Ok, I have read about fliers liking 4" bell-cranks but what is the big deal verses 3" ones?
I accept that the action might be smoother and the mechanical advantage slightly higher but if you are used to 3" cranks why change?
And at what model size do you NOT use them?
Thanks.
MAAA AUS 73427
Offline Dennis Moritz
Re: 4" Bellcranks.
« Reply #1 on: October 12, 2010, 01:13:38 AM »
More leverage allows for slower and more accurately placed (felt) controls. They're most useful in competition stunt planes doing the tricks for points. Sport planes don't need them, since they fly fast and get flicked about recklessly. At least I like to fly them like that. Great relief to jerk the controls on a sport plane and make it dance. Round appearing circles and 90 degree (looking) corners not an issue.
Re: 4" Bellcranks.
« Reply #2 on: October 12, 2010, 08:45:11 AM »
Typical 35/40 sport planes around 42" don't need 4" cranks. Besides on birds that size it's a pain to fit them in.
Re: 4" Bellcranks.
« Reply #3 on: October 12, 2010, 09:30:20 AM »
The best thing about 4 in bellcranks is that you lower the forces on the pushrod 33%.  Reduces wear and tear on the controls and give you the option of slowing the controls down for more precise flying.
Offline Jim Thomerson
Re: 4" Bellcranks.
« Reply #4 on: October 12, 2010, 11:22:50 AM »
I've been using handmade wooden 4 inch bellcranks on 1/2A and up to TD 09 stunt airplanes.  My thinking is that they make the controls less sensitive.  And, yes, it is a trick to get them into a 6 inch chord wing.
Re: 4" Bellcranks.
« Reply #5 on: October 12, 2010, 11:50:16 AM »
These are just estimates, bvut here's the principle as I see it:
2" bellcrank with 90 degrees total movement.
3" bellcrank with 70 degrees
4" bellcrank with 50 degrees.
The small bellcrank loses mechanical advantage toward the extremes of throw and the output looses most of its fore-aft vector at the extremes.
The bigger bellcrank operates with the output in a near-linear range.  Futhermore, a given amount of slop (compliance) in the linkage take A LOT of motion away from a tiny bellcrank, but very little from a bigger one.
Of course the thing has to fit in the model without hogging out too much structure.  There have been countless successful mdoels with 3" bellcranks before the 4' fad hit.
« Last Edit: October 12, 2010, 06:13:35 PM by Paul Smith »
Re: 4" Bellcranks.
« Reply #6 on: October 12, 2010, 03:31:50 PM »
Ok, got it now!
Very good point about the linear control staying longer with a larger crank.
Thanks guys.
MAAA AUS 73427
Offline Dick Pacini
Re: 4" Bellcranks.
« Reply #7 on: October 12, 2010, 09:07:37 PM »
The best thing about 4 in bellcranks is that you lower the forces on the pushrod 33%.  Reduces wear and tear on the controls.
Can you explain that?
AMA 62221
Re: 4" Bellcranks.
« Reply #8 on: October 13, 2010, 05:02:31 AM »
Can do easy.
The goal is to transmit a certain amount of torque to the flaps and flippers.
If you use a 2" bellcrank and a 1/2" horn, compared to a 4" bellcrank and a 1" horn, the big bellcrank will move the pushrod twice as far, but only need half the force to develop equal torque.
Attached is a sketch I did several years ago to try & 'splain this point.  You might assume that 4", 3", 2" and 1" bellcranks are being evaluated with an estimated one inch-pound of torque required.  The sketch agrees with Phil's 33% differnce between 3" & 4".
« Last Edit: October 13, 2010, 08:47:52 AM by Paul Smith »
Re: 4" Bellcranks.
« Reply #9 on: October 13, 2010, 11:45:01 AM »
Bellcrank size has nothing to do with pushrod pressure, only the length of the control horn. Assuming you can get the travel desired, the bellcrank can be any reasonable size. Going from a 3 to 4 inch crank simply reduces the amount of "pull" on either line needed to steer the model.
Re: 4" Bellcranks.
« Reply #10 on: October 13, 2010, 04:45:22 PM »
Oh goody, a can o' worms again!
The way I see it here is that I want the leverage ratio be the same regardless of the actual size of the crank used so that the 'feel' is the same between models.
Now if I have a 3" crank with say a 1" arm I get a 3:1 ratio.
If I proportionally scale that crank to so that the arm centres are now 4" apart the arm is now 1.33" and the ratio stays the same.
The only difference here is that quoted ratio is only for dead neutral but when moving away from neutral the larger crank drifts away from that ratio at a slower rate.
The angular deflection with the larger system has a greater percentage of its torque going into control movement and less of it simply pushing or pulling against its pivot points.
MAAA AUS 73427
Offline Dick Pacini
Re: 4" Bellcranks.
« Reply #11 on: October 13, 2010, 10:26:02 PM »
I thought I read here somewhere that a 4" bellcrank is closer to the grip size of a closed hand, resulting in a movement ratio close to 1:1.  The goal is to reduce sensitivity and afford more precise control.  It makes sense to me.
AMA 62221
Offline Kim Mortimore
Re: 4" Bellcranks.
« Reply #12 on: October 14, 2010, 12:42:31 PM »
.....Going from a 3 to 4 inch crank simply reduces the amount of "pull" on either line needed to steer the model.
One consequence of this is that if line tension is reduced due to wind or whatever, a 4-incher allows you to maintain control of the plane with less line tension than a 3-incher requires, which might be of interest to both stunt and sport fliers.
Kim Mortimore
Santa Clara, CA
Offline Larry Cunningham
  • Red Hot Lover
  • Klaatu barada nikto my ass
    • Stephanie Miller
Re: 4" Bellcranks.
« Reply #13 on: October 14, 2010, 09:44:44 PM »
I don't EVEN want to chime in about expocranks! ;->
L.
"I may have many faults, but being wrong ain't one of them." -Jimmy Hoffa
Offline L0U CRANE
Re: 4" Bellcranks.
« Reply #14 on: October 15, 2010, 02:04:41 AM »
Chris, to your post #9...
Yes, the bellcrank and horn proportions should be the same, to have the same 'feel.' That also apples to the line spacing at the handle. I won't offer any "ideal" line separation. That is a matter of feel for each of us, and for the model we're flying.
Many handles used to day have a front frame allowing us to widen or shorten the distance beween the lines right there at the handle. Using the same line separation you're comfortable with for a 3" bellcrank would feel a lot slower for a 4" belcrank. Sure the ratio can be calculated easily, but that's just a number. Feel doesn't result from numbers; it is more direct and personal. We can explain the change in feel with numbers, yes, but not the experience of it.
\BEST\LOU
Offline Ward Van Duzer
Re: 4" Bellcranks.
« Reply #15 on: October 15, 2010, 09:47:38 AM »
Another worm...
What about the distance from the BC pivot point to the push rod pivot?
Ward-O  H^^
Offline Dean Pappas
Re: 4" Bellcranks.
« Reply #16 on: October 15, 2010, 11:10:57 AM »
Thank you, Ward!
Finally someone asks the right question: not all 4" cranks are equal.
There are at least two ways to slice this ... assuming the elevator and flap horn lengths are kept constant for the purposes of the comparison.
1) If the short to long arm length ratio is the same as a classic 3" crank, then you enjoy better linearity, especially when it comes to the difference between UP and DOWN throw curves, but no improvement in sensitivity.
2) If you run a shorter short crank ratio, then you get to fly with wider line spacings at the handle, and you back away from the Netzeband-limit problems. There is no improvement in linearity.
5" cranks anybody?  S?P
Dean P.
Dean Pappas
Re: 4" Bellcranks.
« Reply #17 on: October 15, 2010, 12:10:42 PM »
Thank you, Ward!
Dean P.
Fascinating.  I was aware of the sensitivity factor in relation to arm length ratio, but the linearity vs. sensitivity compromise is new to me.
5" cranks sound like a great idea.  With correct control arm lengths, would they allow less compromise than 4-inchers?
Also, Dean, would you like to say a bit more about UP/DOWN throw curves?
Great stuff.  Thanks.
Kim Mortimore
Santa Clara, CA
Online Tim Wescott
Re: 4" Bellcranks.
« Reply #18 on: October 15, 2010, 12:46:07 PM »
To really know how this works, dust off your geometry and trig knowledge from high school (you remember -- you were 15, and supposed to be studying the curves on the board, not the curves on the girl next to you).
Don't forget to take the nonlinearity of the handle-to-line interface into account, or the effect of the leadout spacing.
Online Howard Rush
Re: 4" Bellcranks.
« Reply #19 on: October 15, 2010, 01:45:06 PM »
We tried doing that, and it's too hard.  Somebody should write the formulae for control linkages.  For extra credit, figure out how to do Igor's flap mechansim with a four-bar linkage.
Re: 4" Bellcranks.
« Reply #20 on: October 15, 2010, 02:08:28 PM »
   Gosh, that had never occurred to us! Amazing that we stumbled along doing things at random all these years without complete disaster and appropriate technical instruction.
    Note endless SSW posts and several SN articles on this topic.
Re: 4" Bellcranks.
« Reply #21 on: October 15, 2010, 04:07:04 PM »
Tim,
As W.C. Fields would say, "Ahhhh, yes, I remember it well."  Mr. Euclid and his pals were hard put to compete with the songs of Sirens. Wasn't there an early seventies girl-band called The Sirens?
Kim Mortimore
Santa Clara, CA
Online Tim Wescott
Re: 4" Bellcranks.
« Reply #22 on: October 15, 2010, 04:21:05 PM »
Not to mention that when you're done you still have a pile of flight data that only partially supports (and possibly partially contradicts) what the math is telling you.
Blech.  That's starting to sound like work.
Post a link to Igor's flap mechanism?
Online Howard Rush
Re: 4" Bellcranks.
« Reply #23 on: October 15, 2010, 09:22:54 PM »
Online Howard Rush
Re: 4" Bellcranks.
« Reply #24 on: October 15, 2010, 09:56:11 PM »
Most of what I've seen has been bogus, intuitively obvious, or some linear combination thereof.  Has somebody written down the equations for stunt plane control linkages?   I remember Serge taking a stab at it awhile back.  So did I, but it was too difficult.  I looked on the web, figuring that there would be some general mechanism stuff and maybe a Java application.  There are some mechanism programs, but people want actual money for them.
But back to 4" bellcranks.  I recently figured out the leadout paths for 4" bellcranks in several wings.  Accommodating a big bellcrank travel sure requires big slots in wings and the left wing spar shear web.  I wonder if a bigger bellcrank with less travel would actually be easier to fit into a wing.  As with the mechanism problem, I would like one of you people to figure it out for me for free.  No fancy Greek letters either, particularly the Worm.
« Last Edit: October 15, 2010, 10:17:00 PM by Howard Rush »
Re: 4" Bellcranks.
« Reply #25 on: October 17, 2010, 11:28:07 AM »
I would say the amount of non-linearity for the small amount of control travel we use is insignificant. And of course the controlling entity is also non-linear, plus it possesses a tremendous ability to compensate for such anomalies.
Don
« Last Edit: October 17, 2010, 03:40:50 PM by Don Hutchinson AMA5402 »
Re: 4" Bellcranks.
« Reply #26 on: October 17, 2010, 07:13:12 PM »
Another worm...
Ward-O  H^^
I was running under the assumption that since this was never part of the original question it would never have to be considered.
A 3" crank with a 1" 'BC pivot point to the push rod pivot' gives a ration of 3:1, simply scale that same crank up to 4", use the given ratio and the arm comes out at 1.33"
The ratio (whatever it is doesn't really matter) should be a constant, the variable here is the distance between the lead-out centres.
And it still seems to me that the ONLY thing in favour of a dimensionally larger crank setup is that it operates closer to linear fashion - for longer - than a smaller setup.
Now is a linear setup more desirable over exponentially decreasing one?  Given that the human body is never linear in its output I am not sure why approaching a linear system would in any way be desirable.
Thanks.
MAAA AUS 73427
Offline Serge_Krauss
Re: 4" Bellcranks.
« Reply #27 on: October 17, 2010, 11:04:49 PM »
One consideration is not so much linearity or its lack, but asymmetry: the amount of up vs. down with equal handle displacements. For some common  geometries and component placements this can vary some between zero bellcrank rotation and some predetermined deflection, like say +/- 30o, were you set your flap or elevator displacements equal. I played around with this on a calculator furnished to me by Larry C., who had received it from someone else. I don't remember how large the asymmetry ever got, but it was interesting that it wasn't always worst for our "uncorrected" rod/horn angles. The calculator seemed valid, but did not account for all the adjustments we can make, like tilted bellcranks. I think I posted some graphs on SSWF, but someone who should have made more effort sort of discouraged me from following up. 'didn't need the grief. I'd think that the larger bellcrank might lessen that problem as well as easing the "Netzeband wall" problem. I can say from experience though that finding room in small stunt wings is a challenge. 3.5" is better for my latest (well 'late' has a dual meaning here).
SK
Re: 4" Bellcranks.
« Reply #28 on: October 17, 2010, 11:16:28 PM »
Hi Serge,
Strangely enough my proposed Freebird diesel powered stunt models are going to use exactly this size crank and I am sure that it will work out just fine.
Cheers.
MAAA AUS 73427
Re: 4" Bellcranks.
« Reply #29 on: October 18, 2010, 07:20:50 AM »
SK
Hi Serge,
This is where I get lost.  As a descriptive question, rather than a mathematical one, if there is Up/Down asymmetry with a centered bellcrank and 90-degree rod/horn angles, what is the source of the asymmetry.
Thanks.
Kim Mortimore
Santa Clara, CA
Re: 4" Bellcranks.
« Reply #30 on: October 18, 2010, 09:48:04 AM »
Thanks.
Kim-
Well, I probably should answer this in another thread - we're getting a bit off topic here, but I'll risk this one post.
I think the best answer is that the angle is 90o only at zero bellcrank deflection and that the angle changes a different amount per degree of deflection in each direction, in a complicated way, since the bellcrank horn/rod pivot moves laterally as well as longitudinally and the flap horn attachment point moves vertically and longitudinally, changing the rod's angle relative to just about everything.
I just opened that control-geometry program and used the smallish dimensions for my plane (which tend to exaggerate the effects, if you use the larger plane's bellcrank and flap horn sizes, with a shorter rod for a smaller plane). The differences in up vs down handle or bellcrank movement needed to achieve equal up and down flap deflections for plain perpendicular (un-biased) flap horns increased from 00 at 00 flap deflection to about 9o at 45o flap deflection. That shows that the rod length would have to change with bellcrank rotation, for symmetry without flap horn offset.
It turns out that you can use flap horn offset to choose a symmetrical flap deflection for one particular value, but that it will be asymmetrical for all other flap deflections - greater or less. Characterictically, the asymmetry will be relatively small (needing more down input than up) between neutral and your chosen deflection, but then increase rapidly (needing more up than down input) for greater deflections. At extremes, the asymmetry diverges rapidly in one direction or the other. Interestingly, the ideal flap horn bias comes close, but does not make the rod and flap horn perpendicular to each other at neutral. Tom Morris' 7o  angle seems good for the large stunters, while 9o  was better for mine.
Others:
As usual, if I'm hard to understand or incomplete here, chalk it up to lack of writing skill, but remember that this is why graphs were invented. We can have fun without them and do pretty well, but if we really want to know why or how things work, they help a lot. The offending post, which showed all this convoluted grammar in graphs is here:
http://www.clstunt.com/htdocs/dc/dcboard.php?az=show_topic&forum=103&topic_id=328113&mesg_id=328113&listing_type=search
SK
Re: 4" Bellcranks.
« Reply #31 on: October 18, 2010, 10:06:50 AM »
I want a circular 4 inch bell crank with a gear on top to mate with a gear rack on the end of the pushrod to give linearity at the bell crank.  How come no one has taken up this wonderful idea? Z@@ZZZ
Re: 4" Bellcranks.
« Reply #32 on: October 18, 2010, 11:06:20 AM »
Serge,
Very interesting.  I think some of this is starting to sink in.  By the way, the writing skills seems just fine to me, and this is a complicated subject to write about.
In the attached post you say, "...raising a standard level bellcrank probably helps regain some symmetry."  What if, rather than raising the bellcrank, which would not be a fun (or maybe even practical) installation, you attached the rod to the bellcrank using a raised post (the Primary Force ARF uses such a post, tho it's not a flapped plane) so that the flap rod is parallel to the fuselage centerline in side view, and the rod/horn angle is 90 degrees with no horn bias?  Fore and aft forces trying to move the post out of vertical might have to be dealt with (the Primary Force's post is fairly wide at the base).
You also say, "Basically, the driving question reduces to, 'What control angle asymmetries become noticeable?'"  Good question.  Is there a signal to be heard within the noise, or is it just a pea under the mattress (to mix metaphors), making the issue one mainly of  theoretical interest?
« Last Edit: October 18, 2010, 11:41:16 AM by Kim Mortimore »
Kim Mortimore
Santa Clara, CA
Online Howard Rush
Re: 4" Bellcranks.
« Reply #33 on: October 18, 2010, 12:54:57 PM »
You may not want linearity.  Look at Igor's plane, second in the 2008 world champs.  You may not even want symmetry.  I flew another airplane that came in second at a WC.  It had significantly asymmetric control.  Think of hinge moment and the relationship between loop radius and line tension at constant handle setting.
Re: 4" Bellcranks.
« Reply #34 on: October 18, 2010, 01:09:01 PM »
   I believe that both John Miller and Larry Cunningham have written pretty extensive SN articles on the topic.
Re: 4" Bellcranks.
« Reply #35 on: October 18, 2010, 03:14:10 PM »
Kim-
I think there might be some problems with the bellcrank being more torqued to twist of rock. Maybe a better approach would be to do something like Brian Hampton did: run a separate arm off of an upward-extended bellcrank center bearing. Keeping it light with strong Materials (CF?) might be a challenge, but it could otherwise be kept simple, if a tube were sleeved over a typical 1/8" bellcrank support shaft, with the bellcrank in the middle and the arm raised. This would restrict any rocking motion of the bellcrank more than usual. Remember though that there still might be a more optimal height than that for a 90o juncture at neutral.
You know, I'd think that an Excell spreadsheet might be used to compute this without the need to actually solve any equations or combine complicated expressions. I'm pretty burried now wih a couple other things that would also seem a waste of time, but I think this can be done. meanwhile, I've dug up an image of the input diagram fro the software by Mr. Herbron that I used for those graphs scanned to fit the <50Kb limit on SSWF. Maybe it will be legible. Note from the input window that some of these bellcrank rotations are larger than practical to get the really large deflections (It 'only' takes 38o to get 30o flap deflection with those dimensions.).
SK
« Last Edit: October 18, 2010, 03:41:00 PM by Serge_Krauss »
Re: 4" Bellcranks.
« Reply #36 on: October 18, 2010, 03:38:20 PM »
I had a plane that felt okay controlwise for Down, but for Up it was dead around neutral, with gradually increasing response as it moved away from neutral, until it was very sensitive at full throw.  Made me crazy (or crazier).  I sold it to a friend (with full disclosure) who is so accustomed to and adept at adjusting for all manner of oddball ooblygooblies that he didn't even notice and used the plane to quickly make significant strides in his pattern development before the plane started to wear out.  Wouldn't it be nice if we could install dials that would allow us to adjust each parameter independently?  I guess learning about cause and effect is next best.  I have emailed Larry and John asking for SN article dates.  John says sometime in the early '90s for his SN article.  I see Larry has an earlier post on this thread.
Serge,
I was writing this while you were posting your latest, so will take a closer at it.
Kim Mortimore
Santa Clara, CA
Re: 4" Bellcranks.
« Reply #37 on: December 06, 2010, 12:30:59 PM »
A bunch of far-out and unnecessary ideas here, which basically hover around the real reason for using 4" bellcranks.  It is because we are used to lots of wrist movement in order to get the usual 30 deg. of elevator/flap throw!  And that's it!
So it's really about what we are used to.  If you are used to "quick" controls, you can still fly a smooth pattern, because your muscles are "trained" to move less.
I watch the plane when I fly, not my wrist.  My wrist moves in whatever way required to match the plane's path with the ideal path I have stored in my memory.
Online Howard Rush
Re: 4" Bellcranks.
« Reply #38 on: December 06, 2010, 02:24:17 PM »
No, it's about aerodynamic hinge moment.
Online Howard Rush
Re: 4" Bellcranks.
« Reply #39 on: December 06, 2010, 03:46:25 PM »
Having said that, I can't justify it.  I should do some ciphering.
Offline L0U CRANE
Re: 4" Bellcranks.
« Reply #40 on: December 06, 2010, 06:48:33 PM »
Howard, Serge, Floyd, Chris, Brett (...forget anyone? if so apologies...) I'll be  brief.  (Yeah, right...)
Study Serge's diagram. The bellcrank plate is mounted parallel to the span and the long axis of the model, which creates much of the difference in response either way from neutral. (Which is small, and we've been been able to manage it, by feel, ever since...)
A way to reduce that geometric "error" is at the flap horn, where the line from the pushrod connect to the flap hinge, at neutral, should be perpendicular.  This still has that forward and back discrepancy from the 'flat' bellcrank plane of rotation.
Now, what if you mounted the bellcrank plate tilted so it and the rod from bellcrank to flap horn were parallel at neutral? It won't stay that way over the full bellcrank rotation, of course. Perhaps put the rod parallel at about 5° to 10° each side of neutral?  That should minimize ONE distortion...
Another view of things? View the model from the top. (Never considered this view? Hmmmm...?)
In the top view, and for the same reason we'd want the flap pushrod to make the least up and down deviaton, wouldn't we want the least  'off-axis' sideways motion?  ...The flap hingeline is almost always perpendicular to the fuselage long axis, or for a swept hingeline, the angles away from pependicular are the same to each side.
If we must put the flap horn on the fuselage centerline, THAT determines where we should mount the bellcrank pivot (in the top view.) For the inboard bellcrank-to-flap-pushrod connection (UP line forward) we'd need to mount the bellcrank pivot further outboard. Or, if we MUST put the bellcrank pivot at a certain place, THAT determines where the flap horn goes, across the fuselage width. The same +/- 5° to 10° offset used for the side view can help keep the center (neutral) 'off-axis' motions small.
Summing up:
1) In the side view of the fuse, tilt the bellcrank mount so that it and the bellcrank-flap pushrod are at -or near- parallel at say +/ 5° to 10° from neutral?
2) In the top view, 'center' the bellcrank-flap pushrod's sideways swing the same way.
I have gunned up a spreadsheet documenting the deviations using this "aligned" bellcrank/flap horn idea. A monster which takes me several minutes to 'get back into' every time I consult it... Anyway, the deviations caused by different bellcrank-out and flap-in arm radii are very small from neutral to ~30° each way, then they start to diverge, gradually but increasingly. (The graphs of the deviations impress me!)
Final thought: If we keep the "response relationship" the same with a larger bellcrank arm radius, we have to increase the flap and elevator horn radii to preserve that relationship. It will 'feel' slower because we have to move the handle further to turn the bellcrank to comparable angles. Effort applied to the handle will decrease, because of the longer lever arms, but to turn the flaps and elevators to the same angles, the bellcrank must turn the angles we used with 3" bellcranks. Torque depends on force and arm length. Any change in one demands a compensating  change in the other.
\BEST\LOU
Online Howard Rush
Re: 4" Bellcranks.
« Reply #41 on: December 06, 2010, 08:25:59 PM »
I spent a couple of days on my new plane figuring out this stuff by brute force with Cad.  I got the slanty bellcrank and the slanty slots in the wing laser cut.  I probably should figure it out all over, now that I decided to reverse the sign of engine torque and may shift the CG.  I'd sure like to see that spreadsheet (after it's documented, of course).  I'm not smart enough to make my own.
Online Howard Rush
Re: 4" Bellcranks.
« Reply #42 on: December 06, 2010, 08:37:01 PM »
Now that I think about this, I think there's a business opportunity.  It should be pretty easy to attach some clinometers to flaps and elevators and make a handle mover with an angle encoder, then record all three with my LabJack.  For example, I could put this rig on Doug Moon's airplane and charge him $1 for a plot of his control response.  Then I could charge about a dozen other guys $5 each for the plot of Doug's plane.
Offline Russell Shaffer
Re: 4" Bellcranks.
« Reply #43 on: December 06, 2010, 09:51:34 PM »
I'll give you $10, but I wouldn't know what to do with it.
Russell Shaffer
Klamath Falls, Oregon
Offline L0U CRANE
Re: 4" Bellcranks.
« Reply #44 on: December 06, 2010, 11:04:28 PM »
Howard and Russell,
1) Document it? Ouch!!! It is in Excel 2007, compatible to 97-2003, and minimally protected - just to prevent inadvertent corruption of formulae. No accesss password - go through the simple UNPROTECT SHEET steps to access the formulae.
2) If I ever do, it won't be for sale. Only copyright-asserted against commercial use without my agreement.
3) After about 30 years since I first laid out my handle theories, I now accept the thinking of Brett, Ted F and a few others on the position of the handle w/regards the model in flight. I may have been more limber back then, but today I find that holding a "half-curl" position - elbow bent up to allow equal up and down handle movement - has definite advantages. I no longer have as much up-flex from my wrist, so the tilt upwards from elbow to wrist compensates.
Old dog, gotta learn new tricks... It was much simpler, in the mid 1950's,  when I learned what I know about doing CL flight. The U-Reely was heavy. Allowing my arm, elbow and wrist to form a relaxed catenary with the lines to the model worked -still does - BUT...
With my old approach, the relaxed, about waist-high, handle let the model carry some of the weight of the handle. ...Like riding a bicycle, the less you think about what you are doing, the less likely you are to lay it down, painfully, on the pavement... You think what you want the model to do, and the instinctive, learned, motions instruct the model to go there.
Anyhoo, using the  XY and XZ plane aligned linkage approach can be done with CAD, or even with a straight-edge and compass, and get much closer than the "standard" pushrod setup.*
*(Defined: Surface horns perpendicular to surfaces; severe upward pishrod slant from (flat-mounted) bellcrank to flap horn; severe down psuhrod angle from above the flap chordline to below the elevator chordline at the elevator horn.)That kind of offset is used in RC aileron linkages to get DIFFERENTIAL angles!
Intentionally!
We don't (supposedly) want that. We want equal response both ways from neutral, so we don't have to take a 1/10th second correction that may be needed.
\BEST\LOU
Re: 4" Bellcranks.
« Reply #45 on: December 07, 2010, 09:12:29 AM »
Why wouldn't it work to just bend the pushrod to go vertically up to the horn height and then horizontal to the horn?  Brace the 90 degree bends to avoid flex.  Or do I not understand the problem?
                        ___________________________
       ___________|
Russell Shaffer
Re: 4" Bellcranks.
« Reply #46 on: December 07, 2010, 10:45:39 AM »
Dear Brother Howard,
Since, in actuality, my ubiquity is substantially a nihilism, I will have to leave all the advanced mathematics to you scientific guys.  I only taught "beginner math".
Big Bear
Offline L0U CRANE
Re: 4" Bellcranks.
« Reply #47 on: December 07, 2010, 12:54:00 PM »
Russell,
The crucial relationship in the control system layout is the straight line from eye to eye: e.g., from the bellcrank's flap pushrod hole to the flap horn's pushrod hole. If you mounted a 'transfer shaft' to raise the flap pushrod to the height of the flap horn hole you create a new pushrod driving 'eye' in a better location for linear response. You have to be careful doing that  - it has to be strong enough to carry the loads and stay in the right position and "shape."
Whatever the shape of pushrod, the force acts from eye to eye. Think of an "in-line" model: a flapped model with the wing and stab chord lines at the same height...  The cables used as pushrods in RC don't have any easily understood eye-to-eye pieces, or perhaps just the locations where the cable enters the sheath, then where it leaves it, relative to the servo at one end and the control horn at the other...
* the bellcrank is typically flat, on the rib centerline.
* the flap horn is above the rib centerline, where the hingline is.
* the elevator horn is below the stab/elev centerline, where its hingeline is.
The flap pushrod has to tilt up to meet the flap horn's pushrod hole. The elevator pushrod is most often driven from the flap horn, above the flap hingeline. The elev pushrod has to slant down to enter the elev horn hole.
From the side view, the flap and elev horns rotation is visible. The bellcrank's is not. Viewed from above, the bellcrank's rotation is visible, but flap and elev horn rotation is not.
Angling the flap horn 'point-to-point'  - bellcrank pushrod horn placed where the line from it to the flap hingeline is at right angles at neutral flap - helps quite a bit. The 'golf-club' or 'cobra' shaped horns provide a rough approximation of putting the pushrod tangent to flap horn pushrod hole tangent to the arc it traces as flaps are deflected.
Similarly, where the elev pushrod hole in the flap horn is placed should be angled to fit the slant down from there to the elev horn's hole. And the elev horn's hole should be angled so that this pushrod is tangent to the arcs they trace at neutral elev. These arcs follow pushrod travel pretty closely around neutral, with a deviation growing modestly for 10° to 20° each way from neutral. The discrepancy gets significantly worse from a bit under 30° either way, on up.
The bellcrank output hole motion causes that end of the pushrod to move sideways across the fuselage; the flap and elev horns don't shift in that direction.  The bellcrank is usually mounted flat - in line with, or maybe parallel to, the rib centerline. That affects the 'linearity' of pushrod  motion; the geometry when the pushrod hole moves forward is diffferent from when it moves back. Not much, particularly near neutral... Which is why I suggested tilting the bellcrank to be parallel to the (straight) pushrod eye-to-eye line at neutral. That makes the error almost disappear.
Now, the thought of shifting bellcrank pivot, and/or flap horn position across the fuselage width... If the pushrod, at neutral, is slanted - seen from above - that will also introduce some non-linearity of response. Further, if the bellcrank output hole is tangent to bellcrank rotation, and inline with the flap pushrod there, ALL bellcrank rotation adds an error, slight but increasing with rotation angle.
Since the error is very small around neutral, I suggest moving the bellcrank so that the pushrod hole "slices" an arc 5° to 10° 'below' its arc.
What'd-he say???
Try it this way: mount the bellcrank so the flap pushrod is in-line with the flap horn when the bellcrank is rotated that 5° or 10° either side of neutral. I think this extends the "very linear" rotation range. The sideways motion is very slight (Cosine of angle * arm radius) at small angles, and this shift of the bellcrank put part of the error on the 'other' side at neutral, then it crosses 'just-right' before continuing to grow with more rotation angle.
Similarly, it should be a good idea to do the same with the flap and elevator pushrod holes...
\BEST\LOU
Online Howard Rush
Re: 4" Bellcranks.
« Reply #48 on: December 07, 2010, 02:22:26 PM »
Huh?  I was proposing to measure control systems experimentally: no math required.
Online Howard Rush
Re: 4" Bellcranks.
« Reply #49 on: December 07, 2010, 02:31:06 PM »
       ___________|
This might work if the bottom two legs are fixed to the bellcrank and the joint between the vertical leg and the one to the right has a pin joint, but it might not be the lightest way to do it.
