  • June 16, 2025, 06:54:52 PM
Author Topic: Re: stock 35 stunt speed  (Read 2358 times)
Offline bob whitney
« on: April 06, 2017, 09:01:11 AM »
  going to take 90 MPH to crack the top 3 and maybe 100 MPH to win at Brodaks
rad racer
« Reply #1 on: April 06, 2017, 01:00:17 PM »
Do you mean in the Sportsman Stock event?
Speeds will be somewhat better because it's not a proto event.
Offline bob whitney
« Reply #2 on: April 06, 2017, 11:21:23 PM »
yea, that's what I ment
rad racer
Offline Bob Heywood
« Reply #3 on: April 07, 2017, 08:10:55 AM »
A Fox 35 Stunt won't crack the top 3...
"Clockwise Forever..."
Offline Bob Heywood
« Reply #4 on: April 07, 2017, 08:12:45 AM »
Define "Stock"...
Offline Ken Burdick
« Reply #5 on: April 07, 2017, 04:15:07 PM »
Just use imagination and you will have a 100 mph engine in no time
Online Carl Cisneros
« Reply #6 on: April 07, 2017, 06:57:22 PM »
here be the rules for Sportsman Stunt Speed guy:
SPORTSMAN STUNT SPEED
This is a participation event created as an alternative to Fox 35 Stunt Speed which is an engine builders’
event. The intent is to provide an event that can be flown with stock engines and existing airframes. As
such, contestants who have exceeded 90 MPH in Fox 35 Speed or who enter Fox 35 Steed at this
contest are excluded.
Airframes – This event allows on sport planes with built up or foam airfoil wings and the general
configuration of a sport plane and are capable of doing basic aerobatics such as a lazy eight of reverse
wingover. The airplane must ROG from a fixed landing gear.
Engines - Only stock plain bearing baffled-piston engines of the nominal 35 size are allowed. Since
venture size data for the whole world of engines is unavailable, any fixed venturi is permitted. The
suction fuel requirement effectively limits choke area. All Johnson and Supertigre engines and Foxes
other than the 35 Stunt are excluded.
Lines and Laps.
 Perky: .014” x 52’-6’’ - 16 laps.
 Sportsman Stunt Speed: .015’ x 59’-6” - 7 laps.
 Fox 35: .016” x 60’-0” - 14 laps.
Fuel  10% nitromethane with an assortment of oils; 29%, 23% and 20%
Carl R Cisneros, Dist IV
Control Line RB
