Speed,Combat,Scale,Racing => Speed Talk => Topic started by: Robert Bolton on September 25, 2007, 03:31:38 PM
Well all things going well I will test fly my new sportjet this weekend Just a quere whats a good starting point for the metering jet on a sidewinder??? Model weighs in at just under 28 oz's
Thanks in advance
Robert Bolton
ps: The new fastjets for next year are under construction and should raise a few eyebrows 8)
Nice looking airplane, Robert. I'm not certain about metering jet size for sidewinders, since all my Sport-Jets (both of them) have been uprights.
What lines do you use? Length, and engine centerline offset from the outboard end of the uniflo breather will all affect centrifugal fuel head and ideal m-j size.
Best of luck,
Will Stewart
Robert on sidewinder with a Bailey about a .048 JB
Robert also that vent line looks a little big is that 1/16 OD JB
JB thanks for the metering jet size... The vent pipe is copper so has a smaller ID but is the same as the ID of 16th OD brass tube. Hopefully the wind dies down so we can go flying this weekend.. #^
Robert
ps: line size over here is 0.8 monoline or .5mm 2 line with 19.9 m length or 65 feet. there is no different class for sport or fastjet.. This model is going to be set up to fly on your 60 feet lines as thats what its going to flown on at your nats
Robert,
My TARFU Sport Jet normally uses a .043 or .044" metering jet. Nice looking ship. I'm looking forward to hearing your flight report. I've been thinking real hard about starting a TARFU Fast Jet. Joey needs something else to hang on too. I'll probably have him do the check out flights at least.
Jim Rhoades
Robert,
The change in fuel flow resulting from head pressure difference, between 60 and 65 foot lines, is just under 10%. THis is assuming the same speed and metering jet.
Will
Wet and windy today so no good for testing or any flying will have to wait till next weekend HB~> At least it gives me more time to build ..
Robert
