  • July 29, 2025, 12:19:48 PM
Author Topic: Speed fuel  (Read 207 times)
Speed fuel
« on: July 23, 2025, 09:25:24 PM »
What fuel do they use for 1/2a Proto at the nats? The last time I tuned my engine the fuel was 70% nitro.
MM :)
Online Dave Rigotti
Re: Speed fuel
« Reply #1 on: July 24, 2025, 04:35:59 AM »
S&W
MM :)
Dave Rigotti
AMA 66859
Chesterland, Ohio
Online Bob Heywood
Re: Speed fuel
« Reply #2 on: July 24, 2025, 06:16:53 AM »
Spec fuel across the board:
7. Fuel
Fuel of standard formula will be supplied by the contest organizers. The
percentages of ingredients in the fuel mixture supplied must be accurate,
consistent with careful and accurate mixing techniques. Fuel for two-cycle glow
plug engines shall contain 10% nitromethane, 20% lubricant, and the rest shall be
methanol. Fuel for jet engines shall consist of 80% methanol and 20%
Nitromethane.
"Clockwise Forever..."
Re: Speed fuel
« Reply #3 on: July 24, 2025, 06:49:14 AM »
Thanks Guys, I guess I can take out a few head shims but, I'll need some new props. Do you know what the oil is, any castor in it?
MM :)
Online Bob Heywood
Re: Speed fuel
« Reply #4 on: July 24, 2025, 07:14:34 AM »
Yes, there is castor oil in the lube package. Klotz is the synthetic. The blend is either 20% or 25% castor. Racing (NCLRA) uses one and Speed (NASS) the other but I can't remember which is which right off the top of my head. I don't have time right now to dig out the information. Klotz Super Techniplate has 20% castor.
As Dave responded, S&W is the NASS fuel supplier. There is a web site but the NASS Special Blend fuels are not listed. I suggest you call Stan at S&W and ask him.
Re: Speed fuel
« Reply #5 on: July 24, 2025, 09:15:02 AM »
Just as a interested spectator, I looked at the speed & racing fuels.
They are identical except that racing gives 1/2A a break allowing unlimited fuel.
Speed makes 1/2A's use the same 10/20/70 as all the others.
I remember a racing contest that tried to make 1/2A's burn 10%.  They put the rule aside before the end of qualifying.
Per The Rule Book, the 20% lubricant can be anything.
Online Bob Heywood
Re: Speed fuel
« Reply #6 on: July 24, 2025, 09:58:12 AM »
The regulations don't specify a particular lube package as a matter of convenience. The respective SIG's settled on a blend for the fuel each provides for contests. It would be next to impossible to manage that level of detail through AMA.
Re: Speed fuel
« Reply #7 on: July 24, 2025, 05:30:34 PM »
Thanks Bob.
