  • July 30, 2025, 08:20:19 PM
Author Topic: Any info on the new Profi .049?  (Read 10937 times)
Offline spare_parts
« on: April 20, 2023, 04:19:03 PM »
For 1/2A Proto, anyone played with it yet? https://www.ebay.com/itm/155508117994
Would the older one with the offset intake be anywhere close, I have one but haven't done much with it. I have a few Pzero, but they need the mods. I'll start with something milder as I know nothing about CL.
Greg
Online Dave Rigotti
Re: Any info on the new Profi .049?
« Reply #1 on: April 20, 2023, 07:58:30 PM »
I have one ready to fly in a 1/2A Profile Proto. I only have a few break-in tanks thru it.  I'm adding 2 head shims for a smoother NV adjustment.  I'll fly at the Dallas contest April 28-30.
« Last Edit: April 20, 2023, 09:16:53 PM by Dave Rigotti »
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline spare_parts
« Reply #2 on: April 30, 2023, 10:28:09 AM »
That looks great!. Is that the Rocha design?
Greg
Online bob whitney
« Reply #3 on: May 01, 2023, 12:33:54 AM »
looks like a PROWLER with a sub rudder
rad racer
Online Dave Rigotti
« Reply #4 on: May 01, 2023, 03:52:25 PM »
Yes. Accelerator.
quote author=spare_parts link=topic=63558.msg656591#msg656591 date=1682872089]
[/quote]
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline brian sisson
« Reply #5 on: September 03, 2023, 06:12:24 PM »
nice finish on that one. what is your finishing process and materials?
Online Dave Rigotti
« Reply #6 on: September 03, 2023, 07:58:05 PM »
One layer of .6oz fiberglass cloth adhered with Z-Poxy Finishing Resin. Dry sand with 80 grit to break the "glaze". Then 220 grit.  One additional coat Finishing resin to fill the weave.  Start sanding with 80 grit and finish up dry sanding with 320 grit.   Apply fillets (15 minute epoxy with micro-balloons and thinned with denatured alcohol to almost watery and applied with a "mono-ject" syringe).  One coat of Klass Kote Primer sprayed at 1 part primer, 1 part catalyst, 1 part thinner. Wet sanded with 320. Fill dents with Bondo putty and sand. One additional coat Klass-Kote primer.  Wet sand with 400 grit. 1 coat color sprayed as 1 part color, 1 part catalyst, 2 parts thinner. NO further sanding or clear coating.  ALL primer and color coats can be applied on same day if you get started before 9am.
There ya have it......My answer to your direct question.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline spare_parts
« Reply #7 on: September 04, 2023, 06:45:56 AM »
I saw Dave's planes at Bill Hughes event last week. The finishes really are beautiful.
Did you fly this one on Sunday?
Greg
Online Dave Rigotti
« Reply #8 on: September 04, 2023, 10:51:48 AM »
Thanks for the compliment Greg.  Time ran out for me to get an official in.  I left early due to the long drive home.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #9 on: September 04, 2023, 11:53:17 AM »
Thanks for the info. One other question are all the parts individually glassed and then assembled?
« Reply #10 on: September 07, 2023, 12:07:18 PM »
I've glassed it both ways. Probably makes the joints stronger if you glass after assembly.
My take on the Profi is that it is a high quality engine and runs well but, it doesn't have a boost port so, it won't be as powerful as other engines. That being said, it is plug and play so there's no heroic machine work involved.
MM 8)
Online Dave Rigotti
« Reply #11 on: September 07, 2023, 01:26:21 PM »
I'll answer the question myself..Thank you.....
The fuse is glassed and sanded before wing and stab is glued in.  WAY easier to sand it this way.  The wing and stab is glassed after assembly.  Epoxy/micro fillets are added just before 1st coat of primer.
Dave Rigotti
AMA 66859
Chesterland, Ohio
« Reply #12 on: September 08, 2023, 01:29:58 PM »
« Reply #13 on: September 08, 2023, 01:34:40 PM »
What kind of needle valve setup is that?
