  • June 18, 2025, 09:40:20 AM
Author Topic: SOP Propylene Oxide any good?  (Read 1406 times)
Offline Rob Roberts
« on: April 07, 2013, 06:31:27 PM »
Has anyone tried this Propylene Oxide  www.motorsportsracingfuels.net/index.php?productID=128  if so was it any good?
Online bob whitney
Re: SOP Propylene Oxide any good?
« Reply #1 on: April 08, 2013, 09:39:02 AM »
  Prope is well known in racing and speed flying ,until a few years ago it was a big part of the pulse jet fuel , but they had trouble getting it in Calif . speed now has a 10/20/70 % nitro, caster, methanal rule.  in racing the 1/2 A class still has an open fuel rule most run around 50 % nitro ,and they seem to run better replacing the methanal with prope .  more responsive and easier to set the needle.
  the big problem with prope is that once opened it evaporates very fast . unless totally resealing the container, usually just enough is mixed to get through the contest    ,i dont think there is any advantage  to using prope for stunt
rad racer
Offline Rob Roberts
« Reply #2 on: April 08, 2013, 10:20:21 AM »
Thanks Bob for the info but in this case the prope would be beneficial for stunt. Its going to be used in Dan Banjock's jet stunter.
 http://stunthanger.com/smf/index.php?topic=28983.0
Online bob whitney
« Reply #3 on: April 08, 2013, 10:44:33 AM »
a little diff  deal,,the jet guys are now using  nitro/ methanal combo, Joey can give the %'s i think it starts and runs better than the prope, but needs a larger tank
rad racer
Online bob whitney
« Reply #4 on: April 08, 2013, 04:43:47 PM »
  Ha Ha, yea, i have seen that thing fly  the speed guys have trouble getting 10 good laps and he dose most of the pattern  . i cant believe he runs that whole tank out
rad racer
Online bob whitney
« Reply #5 on: April 08, 2013, 10:22:48 PM »
  only from a distance.. his Bi-Slob is crazy
rad racer
