  • August 02, 2025, 04:26:12 AM
Author Topic: Fox Stunt Speed AND Perky speed line wrapping question......  (Read 2207 times)
Offline Dave Rigotti
« on: March 19, 2021, 03:16:55 PM »
Rules state .014 solids at 52' 6" centerline model to centerline handle for Perky.
Using Figure #1 loop construction from AMA rule book page #4 my question is:
What "A" dimension do I use?
Same question for Fox stunt Speed using .016 by 60'.
Dave Rigotti
AMA 66859
Chesterland, Ohio
Re: Fox Stunt Speed AND Perky speed line wrapping question......
« Reply #1 on: March 19, 2021, 04:42:20 PM »
Perky uses .15 engines and is thus an "A" event.  Dimension A is therefore 1".
Fox 35 Stunt is a class C event so dimension A is 1-1/4".
Dimension A is the length of lines wrapped by copper wire at the the termination.
These rules were made for all-out high performance planes that can go 200 MPH.  Perky & Fox only go half of that, so you're plenty safe enough.
« Reply #2 on: March 19, 2021, 05:00:59 PM »
Thanks Paul!
Dave Rigotti
AMA 66859
Chesterland, Ohio
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #3 on: April 28, 2021, 07:44:46 PM »
This is the video I did on how to wrap solid or braided lines. I never have measured the "A" dimension on my lines
Fred Cronenwett
AMA CLSCALE7 - CL Scale
