  • July 13, 2025, 05:46:01 AM
Author Topic: Contest in Florida  (Read 2625 times)
Offline jetbill40
  • The fast one
    • jetbill products
Contest in Florida
« on: November 13, 2006, 10:11:03 AM »
Dave wallick and I are hosting a speed contest at his circle on April 21st and 22nd. The santion has been applied for. This is a wonderful site and there will be food and entertainment also there are cabins to rent if you want to stay on site.  JB
William Capinjola
Offline Sonny Williams
  • Control line builder and flyer since 1946.
Re: Contest in Florida
« Reply #1 on: January 06, 2007, 01:55:10 PM »
Bill,  I'm sure others will want to know as well. What are the cabin accommodiations? Bare essentials? Beds?
Toilet and bath facilities? Restaurants? etc.
Offline Scott Jenkins
« Reply #2 on: January 08, 2007, 06:51:46 AM »
Hi Sonny,
The Cabins are quite nice with all the amenties necessary for a comfortable stay.Check out the pictures of the cabins and one of your host giving a flying lesson. If you would like to rent a cabin reservations are necessary call H. David at 352-625-2156.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
