  • April 25, 2024, 07:00:07 PM
Author Topic: Philly Fliers 1st Sportsman Speed Event  (Read 1006 times)
Offline Skip Chernoff
« on: March 12, 2019, 08:22:58 PM »
Check it out: June 2nd 2019
Sparks Field 2828 Charter Rd .Phila. Pa.
Starting time around 9am
 Novice and Expert Classes
 Novices will fly 14 upright laps timed from flying start
 Experts will fly 7 upright laps ,then 7 inverted laps....no proxies
Lowest time wins,prizes will be awarded
Airplane Specs: Any Airframe,but no combat wings,or dedicated racing type planes. Looking for Busters,Shoestrings, Clowns, Ringmasters, FlightStreaks,Cosmic Winds.....stuff like that!
Engines : 35 only,bushing type,baffle piston,side exhaust. No pipes or pressure systems. Mufflers not needed (Muffler Pressure is ok if you're using a muffler)
Fuel 10% Nitro ....you're on the honor system. Bring your own.
Line length : 60' plus or minus 6" c/l of plane to c/l of handle
This is a club sponsored event, not AMA sanctioned deal
Come join us for some fun...........The Philly Guys
« Last Edit: March 12, 2019, 08:49:48 PM by Skip Chernoff »
Re: Philly Fliers 1st Sportsman Speed Event
« Reply #1 on: March 13, 2019, 09:59:51 PM »
There is an asphalt area for take off,but most flying is off grass. The "Sparks" field is located near Red Lion Rd and Roosevelt Blvd......real easy to find. Yes ,we will allow that ST 35. I have one as well and would like to try it out on a Flite Streak. It should be a fun event,join us!
« Reply #2 on: March 17, 2019, 07:54:26 PM »
It's the grass field on the Sparks property. They hold combat meets there as well. Roy,Phil,and Larry Wilks run those.
