  • June 23, 2025, 03:45:11 AM
Author Topic: Nelson Plugs  (Read 2027 times)
Offline Jim Damerell
Nelson Plugs
« on: May 14, 2019, 07:28:29 AM »
I will ask this question here, hoping someone here will know. How do you tell the difference between a Nelson Hot, and an HD? I have been told the shape of the tip is different, a ball on the hot, a point on the HD. I have also been told the bore around the element is bigger on the HD. I have just bought Hot plugs from a reputable vendor, and they have the small (.090) bore and the pointed tip. Is there a way to check the resistance?
Any help?
Online kenneth cook
Re: Nelson Plugs
« Reply #1 on: May 14, 2019, 02:35:36 PM »
          You can also identify the difference of the opening where the element is located. The hot plug has a larger opening.
