  • July 15, 2025, 06:07:24 AM
Author Topic: Perky Rules  (Read 2392 times)
Online Robert Zambelli
Perky Rules
« on: February 01, 2011, 03:13:34 PM »
Where can I find a copy of the rules?
I'm curious as to any building restrictions. For example, can we carve a fuselage or does it have to be built up?
Same with wings and tail surfaces.
Can anyone help?
Offline rustler
Re: Perky Rules
« Reply #1 on: February 01, 2011, 03:23:02 PM »
Just checking my Perky plan - "Built as per plan outline. Construction modification allowed".
Ian Russell.
Offline LARRY RICE
Re: Perky Rules
« Reply #2 on: February 01, 2011, 09:39:50 PM »
PERKY POSTAL RULES
First place trophies for each of 3 classes
Ignition engine
Diesel engine
Glow engine
Engine sizes:
Glow .14 to .15
Diesel .14 to .15
Ignition .19 to .23
Lines:
Control lines, plus lead outs must be .015 or larger
Two line control system only
Line length from center of handle to center of plane 52' 6"
Intake and Exhaust:
Suction feed only
No tuned pipes or performance enhanced exhaust systems
Construction:
Model built to plan outline
Builder must fly and submit times
Two wheels of at least 1 1/2" diameter required
Bellcrank mounted to motor mount (Recommended but not enforced as a rule)
Recommended fuel 10% nitro or less
Flight Procedure:
16 laps (one mile) timed from standing start
3 entries per contestant allowed
Winner is the closest to the average time
In case of tie best time under average time wins
No entry accepted with speeds over 90 mph
No trophies or awards for the highest speeds
Mail all entries to - Black Hawk Models, 300 East Arbor Street #42, Long Beach, CA 90805 - All entries must contain:
Name
Address
Type and name of engine used
Date of flight
Flight time/speed
Optional photo
LARRY
Offline Joey Mathison 9806
Re: Perky Rules
« Reply #3 on: February 02, 2011, 05:49:26 AM »
perky rules are posted at the nass web site clspeed.com
200 mph man ama#9806 joey mathison
Offline PerttiMe
Re: Perky Rules
« Reply #4 on: February 02, 2011, 06:40:05 AM »
http://www.clspeed.com/Perky_Rules.pdf
1. The Model must be built to the out line of the original 1946 Megow Perky design. Construction modifications allowed.
... aha!
13. The Pilot is not required to use the AMA Speed Pylon.
Re: Perky Rules
« Reply #5 on: February 02, 2011, 08:17:00 AM »
Thanks guys, just what I needed.
I also just found out that they are posted here:  http://www.brodak.com/fly-in.php?id=34
Offline LARRY RICE
Re: Perky Rules
« Reply #6 on: February 02, 2011, 09:04:10 AM »
Bob,
     You are aware that Black Hawk Models produces a Perky kit that is used by most entrants to the contest.  Just checking.
Larry
Re: Perky Rules
« Reply #7 on: February 02, 2011, 06:51:25 PM »
Larry thanks for putting that kit out there. It would be real nice to see you do a Dale Kirn Torkey kit.
Offline ray copeland
Re: Perky Rules
« Reply #8 on: February 02, 2011, 08:42:23 PM »
Larry, has Black Hawk models made a mod to the kit to accomodate a Brodak fuel tank?
Offline LARRY RICE
Re: Perky Rules
« Reply #9 on: February 02, 2011, 09:37:56 PM »
     I worked out a mod to fit a Brodak 1oz tank in but then I was reminded that for the race you only need a 3/4oz tank at the most.  A simple solution is to remove most of the motor mounts aft of the bulkhead, then there is plenty of room.  A more complex solution, but more awarding, is to move the bulkhead forward to the rear of the engine.  In this way the landing gear is also positioned further forward for better landings.
Larry
Re: Perky Rules
« Reply #10 on: February 03, 2011, 07:56:47 AM »
I thought I had picture of my tank, but can't find it.  It mounts between the engine, bulk head and engine mounts.   H^^
Offline John KruziK
Re: Perky Rules
« Reply #11 on: February 03, 2011, 05:39:53 PM »
Doc I've been waiting to see those tank pics since te last perk thread
AMA 874027
Re: Perky Rules
« Reply #12 on: February 04, 2011, 03:46:21 AM »
Here's my fix.  Build the plane with a top and (wooden) bottom, like a pan rat.
Three bolts, #1 through the bellcrank, #2 behind the wing, and #3 tail.
ps:
In a contest with a speed limit and the winner is closest to average, I wouldn't worry too much about a Perky being disallowed for some minor deviation from the rules.
« Last Edit: February 05, 2011, 07:34:33 AM by Paul Smith »
Offline PerttiMe
Re: Perky Rules
« Reply #13 on: November 06, 2011, 05:39:06 AM »
I was wondering about one point in the rules:
Flight Procedure:
or:
12. The Model will be timed for 1 mile, 16 Laps from the point of release.
Does the timing start from the Timer's signal, or does the Timer start the clock when he sees the model move? Or does it matter?
Offline LARRY RICE
Re: Perky Rules
« Reply #14 on: November 06, 2011, 05:58:43 AM »
Let me answer the second part of the question first ... No it doesn't matter ... you are aiming at an Average time compared with other submitted times.
Now, the first part of the question ... you decide.
Larry
